| | #1 |
| Zilvia Member ![]() Join Date: Sep 2011 Location: New York Age: 19
Trader Rating: (3) Feedback Score: 3 reviews | ok, SO.. Im looking for a system that is most beneficial for speed & can shoot flames for fun occasionally. I've tried researching all the products above but would like some opinions before i make my decision. Bee-r seems cool because it has more settings then the rush system. however the WOT box [wide open throttle box] which allows you to keep the gas peddle at WOT as you shift seems to be the best as you can hold most of your boost as you shift.. this would be my first anti lag/2step ever and its going on my redtop SR. WOT BOX:wotbox - www2 Rush Racing Anti-Lag:Rush Racing Development - Antilag Launch Control Units Bee-r Rev Limiter:Bee-R Rev Limiter |
| Sponsored Links | |
| | #2 |
| Nissan Fan ![]() Join Date: Jun 2010 Location: Alamogordo, New Mexico
Trader Rating: (15) Feedback Score: 15 reviews | None of those are a true anti lag system, they are for show or WOT shifts. To have a rally style anti lag you would need a turbo and manifold that could take the abuse. Just copy what Dent Sport Garage has done to their SR20. Anti lag How Anti-Lag Systems Work - autoevolution Dent Sport 240RS Maxi DSG - DENT Sport Garage
__________________ |
| | #3 | |
Trader Rating: (3) Feedback Score: 3 reviews | Quote:
| | #4 | |
| Cool Story Bro ![]() Join Date: Dec 2007 Location: Moorpark/Thousand Oaks, Newbury Park CA Age: 21
Trader Rating: (8) Feedback Score: 8 reviews | Quote:
__________________ | |
| | #5 |
| Premium Member | Oh man. Sounds like you want one for the wrong reason. Only having a redtop and assuming you have it pretty much stock, none of these are going to make your sr any faster. Just be forewarned this post is going to cause some drama. Do yourself a favor and just don't get any of these you are just going to wreck your motor. |
| | #7 |
| Zilvia FREAK! ![]() Join Date: Mar 2009 Location: Yuma, AZ Age: 21
Trader Rating: (4) Feedback Score: 4 reviews | I no lift shift my Sr all the fucking time with none of that crap, don't shift like a damn grandma and smack the limiter once when you shift, holds boost and all that shit. Don't waste your money on stupid crap. Last edited by TheRealSy90; 02-06-2012 at 05:56 PM.. |
| | #9 |
| My Little Pony ![]() | You can set the BEE*R limiter for flat shifting as long as you wire it to the clutch instead of the hand brake. I have a BEE*R limiter because it makes cool sounds and drifting more exciting. That's all I care about.
| | #10 |
| logica ante affectus Join Date: Jul 2009 Location: Houston, Texas Age: 23
Trader Rating: (0) Feedback Score: 0 reviews | Like other have said if you have an antilag or similar system make sure the turbo and manifold can handle it. I would worry more about the turbo myself as antilag can be very hard on the exhaust turbine if this is just for show you might want to skip over it. I don't believe the stock redtop t25's were built for that type of punishment. Also remember that these systems (if I am thinking of what you are talking about) were designed and derived from rally cars which have the budget to replace turbo's when they blow out and only have to run for hours not years. Edit: ( I think the OP might be talking about a two-step not an antilag I am not completely sure at this point) |
| | #11 |
| Zilvia FREAK! ![]() | I have the rush racing unit, and I use it to try and get an advantage over higher Hp'd and Awd cars. With boost set at 14psi I was able to leave the line with 11-12psi not an anti-lag system, launch control Hmmmmmmm OKay when you slip the clutch properly it's very effective. Everyone keeps saying these are not true anti-lags system and that is ture, so why may I ask is it that you think the damage a real anti-lag system causes will be caused by these units. We aren't dumping continuous amount of fuel into the turbine housing or manifold. The worst case I can think of off hand is, if your base timing is wrong then yeah maybe. And I'm not saying they are safe for your engine or turbo, I'm am saying, that these don't operate like true anti-lag system so why compare the stress level to one another? The sound is more scarier, than the damage being caused. You can wire the RR unit as a no lift shift option too, It's just that you launch would be set at the same RPM that you normal shift at. You wire the trigger to both clutch switches.
__________________ LoverTechnologies "Half Broken Things!" |
| | #12 | |
Also I'm planning to run this setup on a 2871 375hp setup | |
| | #13 | |
| | #15 |
Trader Rating: (0) Feedback Score: 0 reviews | ive had the Bee*R for a hole yeah with plenty of abuse and didnt damage turbo nor manifold but my engine is built and on the stock manifold and stock but rebuilt T25 when all was put together...it works for me, does build boost of the line and makes drifting interesting...I love it but wouldn't mind trying the WOT box |
| Sponsored Links | |
| | #16 | |
| | #17 |
Trader Rating: (0) Feedback Score: 0 reviews | mmmm naaaaa, check it out at the start of vid....i was trying to blow my tires when they were getting ready to go after a wile of drifting so i can change to another set CCM11 Drifting (Low Quality) - YouTube |
| | #18 | |
| | #25 | |
| My Little Pony ![]() | Quote:
Thus making drifting more exciting. Something Formula-D lacks.
| | #29 |
| Zilvia Junkie ![]() | i used to drag race in the all motor class back in the day and if you did not speed shift (shifting at WOT), you are more likely going to lose the race. i was driving a Honda CRX and i would shift at 9,200 rpm and it would hit 10,200 before i was able to release the clutch completely. we did not have a WOT box or anything like that. you just slam on the clutch and release really really fast. also used to drag race a turbo acura that had a MSD DIS 2 that had 3 rev settings(burn out, launch, and redline). i would engage the 2 step for launch as soon as the 2nd staging lights come on. i would usually see 5-7 psi before launching. |
| | #30 | |
| Zilvia FREAK! ![]() | Quote:
When I first got it, I played with it a lot. Mostly on back roads trying to get it right. It's set at 4500rpm now, but 5500rpm is where it makes me a supppa star! Pissed off neighbors, Angry Vette owners confused cats, dogs and squirrels. If you mean engine damage or turbo damage none as of lately, but i did just break my drive shaft, probably from years of abuse and not the massive 350ft I be puttin down. my power and torque, at the time was 355hp and 310ft deep 12's on a good day! Stock internals and greddy easy cams + rocker arm stoppers
__________________ LoverTechnologies "Half Broken Things!" | |
| Sponsored Links | |
| Bookmarks |
| Tags |
| 2 step, launch control, rev limiter |
| Thread Tools | |
| Display Modes | |
