| | #1 |
| Zilvia Junkie ![]() Join Date: Dec 2010 Location: En mi casa Age: 21
Trader Rating: (7) Feedback Score: 7 reviews | Happy Sunday fellow Zilvians. ![]() About a week ago my S13 failed emissions. In an effort to save time before trying to replace any expensive components(IACV, TPS etc.) i've narrowed down the list of possible culprits: -Spark plugs (Checked #1, gap at ".51.) -Spark wires (Ohms are at about 8.5) -PCV hose (Coming from the head cover to intake; it's cracked and leaking oil) I'm also concerned with an idle problem i had during the summer(Well still have actually, but it was more of a problem back then.). Whenever i would turn my A/C on my car would either drop below 500 RPM or just totally die when i let go the gas to stop at red light or just stop in general. I adjusted the throttle cable to set my idle at about 1,000. This was just a temporary solution so i wouldn't die of dehydration in the Arizona heat, i went to emissions like this though. Any chance this could make my car fail emissions? The other thing is i tried readjusting the cable back to normal but now it won't go back! I start the car(I have to gas it sometime so it won't stall, any input on this?), and it idles normal at 700 but when i gas it and let go it never drops down under 900-1100. I was thinking of cleaning the throttle plate and maybe changing the IACV and/or TPS but it's kind of an expensive solution to start with. Am i on the right path to pass emissions? Any help would be awesome i need to pass because i'm running on 30 day tags and this is my DD!! If i remember i failed the load and idle Hydro Carbon test and the load Carbon Monoxide test. I passed the idle Carbon Monoxide test. Stock KA24DE ![]()
__________________ Live large, Floss daily. |
| Sponsored Links | |
| | #3 |
| Zilvia Junkie ![]() | search for the thread "how to pass smog". you can clean the throttle plate with a can of carb cleaner and a steel brush and a rag. high hc is caused by unburned fuel. check your ignition system and replace your oxygen sensor. |
| | #6 |
__________________ |
| | #7 |
Trader Rating: (7) Feedback Score: 7 reviews | AZ doesn't check for Nox, just HC and CO. Also i don't think my car is running rich. Also it doesn't seem to be misfiring, the tailpipe sounds steady
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/tech-talk/433950-emissions-idle-problem.html | ||||
| Posted By | For | Type | Date | Hits |
| Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum | This thread | Refback | 02-05-2012 01:18 PM | 2 |
