Old 02-02-2012, 11:59 AM   #1
Camber!!!!!!!
Please if anyone knows How to do real good camber work please let me know! Or any shop in the IE please let me know as well. I'm stuk at school with a flat tire! Located in San bernardino please help
banshee_rider909 is offline   Reply With Quote
Old 02-02-2012, 12:02 PM   #2
What?
msglength
di-devol is offline   Reply With Quote
Old 02-02-2012, 12:07 PM   #3
Guess it wasn't clear. I just got a flat due to serious camber wear. I bought used tires with about 90% of life no more than a month ago and and today my tires (front tires) are extremely worn out from the inside due to camber wear ...upgrades (front) Megan racing tie rod and tie rod ends, d-max coil overs with adjustable camber, Godspeed control arm, Godspeed tension rods. Please If anyone knows how to do camber work please help or if anyone knows of a good shop that specializes in Nissan let me know please
Old 02-02-2012, 12:23 PM   #4
........Lol.
zeebrah is offline   Reply With Quote
Old 02-02-2012, 12:25 PM   #5
Nissan Fan
Incorrect toe is wearing your tire out faster then the camber. I run alot of camber up front and tires will last about 8 months.
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
Old 02-02-2012, 12:27 PM   #6
Mine didn't even last a month!!! I got it aligned and all too but it still wore out
Old 02-02-2012, 01:18 PM   #7
rcdad123's Avatar
take it back and have it realigned. ask for a print out of the alignment after its done.
rcdad123 is offline   Reply With Quote
Old 02-02-2012, 01:43 PM   #8
Nissan Fan
Then you have serious problems! I do my own aligents without any special tools and have no problems. If a shop did yours then something else is up, or they suck.
Old 02-02-2012, 01:53 PM   #9
Darren's Avatar
They'd have to suck pretty bad to screw that up!
Darren is offline   Reply With Quote
Old 02-03-2012, 10:35 AM   #10
Solution..I just took it took Nissan dealer Cause pow (from Godspeed) recommended me to go there
Old 02-03-2012, 10:38 AM   #11
I </3 VA
fliprayzin240sx's Avatar
If alignment is good (which I highly doubt), do you have a welded diff? That would be the next thing causing you to eat tires.
CLICK HERE!!!
Old 02-03-2012, 10:40 AM   #12
Idk if it does or not but it's just the front tires. The rear is fine
Old 02-03-2012, 11:35 AM   #13
rcdad123's Avatar
i would not take it to the dealer. their labor price is pretty high.
Old 02-03-2012, 12:04 PM   #14
yeah it's kinda high but when you don't trust shops and don't know any good one in the IE or LA area then i have to reside to the dealer and plus POW from Godspeed recommended me so its all good..im willing to the pay the price for a good and right done job with warranty
Old 02-03-2012, 03:08 PM   #15
I </3 VA
If its the front, you're bushing are probably done. They probably aligned it to specs, but the moment the car moved, alignment shifted due to fucked up bushings.
Get a measuring tape, see if the wheels are parallel to each other. Basically, measure the front wheels on back and front of the tires at roughly the same height, if they're not even, then your toe is off. You can adjust the tie rod end to correct them until they're even.
CLICK HERE!!!
Old 02-03-2012, 03:34 PM   #16
WIKID S4TEEN's Avatar
^ yeah measure like this http://www.youtube.com/watch?v=snhxNQgmwYU
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 02-05-2012, 11:47 AM   #17
Thanks everyone especially or the video helped a lot!!!!!! Now I know what to do if this ever happens again!!!!
Old 02-05-2012, 11:55 PM   #18
240sohc's Avatar
IE alignment
I just got an alignment this past tuesday from Fontana Nissan for $80 flat. The service writer gave me a coupon otherwise it is more like $120. They also warranty it for 12,000 miles/ 12 months. Car feels good so far.
240sohc is offline   Reply With Quote
Old 02-06-2012, 12:48 AM   #19
I was charged 139 due to a full aftermarket suspension front and back and man does it feel like a champ now lol
Old 02-06-2012, 05:14 PM   #20
240sxdrifted's Avatar
shake down the front end, check for any play
Side to side play may be inner tierod, outer tierod end
Up and down may be ball joints/bushings
Up and down and side to side may be a bad wheel bearing
or multiple parts
Also is anyone telling these alignment techs what specs you want or are they setting to oem specs? always ask for a printout...otherwise they probably didnt do a precise alignment
240sxdrifted is offline   Reply With Quote
Old 02-11-2012, 10:51 AM   #21
Send a message via AIM to rakooda
Glad yours enjoying the car.. I put that suspension together myself.. (minus the stuff you swapped out and replaced) Should've hit me up.. could've given you the specs I was running. FYI the diff in the car is OS Gieken, unless you took it out.
Out of curiosity.. you ever gonna hold up your end of the deal? Lol
I'm kinda like herpes. You may lose track of me, but I'll always be around
rakooda is offline   Reply With Quote
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
