| | #1 |
Trader Rating: (0) Feedback Score: 0 reviews | Fresh KA-T... SAFC II yes or no??? Just about done with my KA-T build. With the fallowing set up. Rebuilt balanced, honed, decked, cleaned ect... oem internals .50trim T3T4 Sr 370cc Z32 Maf stock pump Z32 fuel filter large fmic 3" turbo back aftermarket like Godspeed's intake mani other little things but anyway. So im not looking for anything crazy like 250-275 @ 5-8psi just a solid running KA-t. Now when I bought the car, it had a Apexi SAFC II, I never touched it, but now that Im almost done with this build Im not trying to blow my motor up. Ive done a retarded amount of searching/research, and its 50/50 with people saying to ditch it, and others with very similar set ups saying that it worked great for them. I know i cant get much out of it and i know its not "tuning" I know how it works I just want some feed back since Ive never got to in depth with the "tuning" side of things. I can diagnois the sh*t out of cars but this is new to me. Trying to learn!!! PLEASE! dont give me the bs reply, its not what im here for. I know that with nistune,emance,enthlapy ect im better off. Just had my first born and I need to finish this project. In short keep, dont keep it? and if so how should I set it up? Thanks |
| Sponsored Links | |
| | #2 |
Trader Rating: (0) Feedback Score: 0 reviews | Here is the link to my NICO forum. This is my build so you can see what Im working with. Again thanks for any help. Hello! Our KA-T Build. : 240sx General Discussion |
| | #3 |
| Premium Member ![]() Join Date: Dec 2005 Location: Venice, Fl
Trader Rating: (17) Feedback Score: 17 reviews | If you plan on rebuilding again soon, then yes go a head and keep it. If you'd like to keep it together for awhile, you'll get a real tune and trash the SAFC. In short, if you've done you're research, you know what you need to do. Sell it, buy Nistune and be happy...
__________________ VVL S14 in the works... |
| | #4 |
| Zilvia.net Advertiser ![]() Join Date: Dec 2010 Location: Nazareth, Pa Age: 27
Trader Rating: (1) Feedback Score: 1 reviews | Agreed. Nistune is the best bang for the buck. Though you will either have to tune it yourself or pay to have someone tune it.
__________________ www.anarchyperformance.com - Your source for 240sx Performance! Email: sales@anarchyperformance.com |
| | #5 |
| Post Whore! ![]() Join Date: Jun 2004 Location: West Arkansas Prefecture
Trader Rating: (2) Feedback Score: 2 reviews | eh.. i wouldn't do it on a fresh motor. i'm going to use an SAFC on my car, but it's not my primary car, and it'll probably spend most of it's time in a garage. one other thing: you need to get a bigger fuel pump. that will blow up your car well before an SAFC does.
__________________ Pure Electricity... In My Pants |
| | #7 |
| Zilvia Member ![]() Join Date: Aug 2011 Location: France - Toulouse Age: 31
Trader Rating: (0) Feedback Score: 0 reviews | SAFC allows fine tuning your fueling. Do you have an AFR wideband gauge and sensor ? If the answer is no, then you cant use it, no matter what you think. The thing is, if you ask about this, you dont know how to tune, which will lead to killing your engine. First, learn how an engine works; when you know the "how and why" about fueling, timing and how forced induction fits in there, it means you can understand how to map. Knowledge comes first, if you just trial and error, it will lead to engine death. Also note there is no power gain in fueling, it is more about not losing power and not killing the engine. Working Values are well known, get 12:1 AFR @ WOT and when spooling (although there are 2 schools regarding spool time: lean and timing retarded gives boost sooner, but no power; rich and a more agressive timing gives power, but boost comes a bit later and that can also lead to detting. I prefer the power so i map mine rich, but then i use E85 so no risk of detting ), get 15:1 on idle and cruising, job done. Power gains are seen when tuning ignition timing, not fueling. An SAFC cant tune that. So dont use it. |
| | #8 |
| Zilvia FREAK! ![]() Join Date: Jun 2008 Location: virginia beach Age: 25
Trader Rating: (15) Feedback Score: 15 reviews | why don't you use an n60 mafs since its airflow increase is the same as the fuel increase via the 370cc's. then use the safc to fine tune it? which iirc will be very very minimal considering the the airflow increase is equal to fuel increase. |
| | #9 | |
| Nissanaholic! ![]() Join Date: May 2003 Location: Orange Park, FL
Trader Rating: (0) Feedback Score: 0 reviews | Quote:
Fuel is rarely the cause of blown motors. Timing is the usual culprit. Fuel is the easy part. Timing is the important part. Ditch the S-AFC. With a proper tune, on a MAF-based engine management system...then there's no need for you to fine tune the fuel. If it's too rich, then you have a boost leak, or a shitty tune. - Brian
__________________ www.KA24DEvelopment.com | |
| | #10 |
| Zilvia Junkie ![]() | "Sr 370cc" If you are running these injectors, you should be keeping the boost below 7psi. At 7psi, there is nothing wrong with using a SAFC, as long as you retard the timing at the distributor a few degrees, and use only 93 octane. I have dismantled an OEM KA24 running 370cc/SAFC @ 7psi on a T04e 50 trim with 280,000 original miles, of which 28,000 miles was turbocharged, and I saw no indications of detonation. you should use a wideband to dial the A/F a bit richer than 12:1. I would shoot for 11.3:1 or even 10.8:1 as long as it doesnt misfire. Take every precaution. Use colder plugs. Ensure there is no oil leaking into the combustion chambers, check the plugs for sign of oil deposits. Oil in the combustion chamber will increase the chances of it detonating. -I am never one for recommending a SAFC, however, at a mere 7psi, it should not be a problem. on OEM internals you dont want to be making big power anyways. |
| | #11 | |
| Zilvia.net Advertiser ![]() Join Date: Jul 2009 Location: South El Monte Age: 26
Trader Rating: (27) Feedback Score: 27 reviews | Quote:
I too say ditch the S-AFC. Like everyone has said, there are two parts of the equation when it comes to tuning. Timing and Fueling. In theory when it comes to tuning, you are suppose to "retard" timing when you go into boost. An SAFC does completely the opposite, it will advance timing. All an SAFC does is trick the ECU. From my understanding, the stock KA ecu is tuned to advance timing as load increases. SR ecu's have the "proper" timing curve which is why I believe people can get away with using the SAFC on those ecus.... Here is an example. Godspeed Project 18G Turbo Dyno Pull # 3 - YouTube *shameless plug* In this video we have a stock sr20 ecu tuned by an SAFC. Car is running 550cc injectors, Z32 Maf and Godspeed Project TD05-18g at 1 bar. It makes a reliable 300hp to the wheels. This car is actually owned now by Dai Yoshihara, he was running the same set up for a while. (I believe he swapped in s14sr so I don't know if he is running the same turbo set up). I recommend a rom tune by Enthalpy or JWT at the minimum or Nistune if you can find it used or wait for the amount of time it takes to get to you. *another shameless plug* KA24DET Chris Billedo @ Adams Motorsports Park. Drift - YouTube This car runs 550cc injectors, z32 maf, and a Godspeed Project TD05-18g at 1 bar lbs and makes 325hp easily on an Enthalpy ECU. As you can see the driver is just off the rev limiter like its nothing! Hope I helped and sorry this was SO LONG! haha - Chris
__________________ Chris @ Fatboy Garage Motorsport Inc. Godspeed Project 2518 Continental Ave, El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject | |
| | #12 |
Trader Rating: (0) Feedback Score: 0 reviews | Thanks well due to the response ive decided to: upgrade fuel pump lol and ive been on the phone with Jason from Emance and decided to give it a go. Thanks again for imput |
| | #13 |
| Zilvia FREAK! ![]() Join Date: Nov 2004 Location: Alberta, Red Derp Age: 31
Trader Rating: (0) Feedback Score: 0 reviews | Can't speak from first hand experience, but many other KA-T guys have hated the SAFC for tuning. its a band-aid.
__________________ KA-T ORG-Function over Flush |
| | #14 |
Trader Rating: (15) Feedback Score: 15 reviews | i guess it really decides on your setup. for instance i'm using it on a stock s15 spec r motor with just basic bolt ons no issues and made 250whp/250tq @10psi (i kept it conservative because its an safc). |
| | #15 |
| Zilvia Member ![]() Join Date: Aug 2008 Location: huffman,tx Age: 35
Trader Rating: (8) Feedback Score: 8 reviews | NOooooooo! Don't full with emance. Jason will take your money and then will give you bs reasons why he hasn't delivered what he originally told you he would give you. Long time ago I waisted $100 on an e85 mapfrom him. His k-value was calculated in the total opposite direction of what it needed to be. My car run good on 310 k value and he sent a tune with like 160 as the k value. Just search emance on here and Ka-t.org you will see some pissed off customers. Also look at his ebay feedback. Just get nistune and start tuning yourself.
__________________ |
| Sponsored Links | |
| | #16 |
Trader Rating: (8) Feedback Score: 8 reviews | Try efi specialists he does a great job and he will talk to you over the phone for troubleshooting. http://www.efispecialist.com/store/i...d&productId=12
| | #17 |
| Nissanaholic! ![]() Join Date: Dec 2003 Location: In a place, near a river, over a lake Age: 25
Trader Rating: (16) Feedback Score: 16 reviews | I tried this a few years ago with my t25 ka-t and even with a base timing adjustment and colder plugs, you can't safely time the car with only fuel adjustments. If you value reliability, you have got to make some map adjustments to the timing. Consider I was only around 210whp to. I'll vouch for the Nistune system, I run that on my 500hp SR and its done great. Get it!
__________________ Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
| | #18 |
| Zilvia Member ![]() | you really dont need the safc unless your over 600cc injectors just get a better fuel pump, adjustible fuel regulator, and a turbo timer to see fuel ratio and tune it |
| | #20 |
| Zilvia Junkie ![]() Join Date: Mar 2010 Location: Granada Hills, CA
Trader Rating: (6) Feedback Score: 6 reviews | ^^^ what he said..ive heard Jason @ emance is good with ka-t tuning but his customer service can be lacking. Im planning on using him because i live in socal and can drive down there. I dont think id use him if i lived in another state or far like the OP would rather spend the lil xtra on enthalpy or JWT or nistune to get it quickly.. and I would get one of the above and keep the safc for fine tuning n have it dyno tuned as well Last edited by mkezzo16; 02-05-2012 at 01:32 PM.. Reason: mistake |
| | #21 | |
Doing that just prevents det@ WOT. It also completely decrease efficiency everytime you are not @ WOT, and it affects idle and cranking too. Best way to lose power is to do that, really... these cars have maps that can easily be modified, dont just offset them by badly setting the distributor, that is the shitty way to do things. | |
| | #23 | |
| Zilvia Junkie ![]() | Quote:
6* of timing will not hurt fuel efficiency that much during idle. amirite? And everywhere else, remember that the SAFC adjusts the parabolic voltage of the maf sensor, giving the ECU the impression that less air is being ingested, that will actually add quite a bit of timing to everywhere on the map, thus requiring the static reduction at the distributor. So, what we are saying is that the SAFC will work, at 7psi or less. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
