Old 02-01-2012, 06:46 PM   #1
HATchTRICK's Avatar
S14 sr20det won't run
Ok here's the deal.
95 240
S14 sr20det
Full race turbo with t3/t61
Greedy intake manifold.
Dwerk's 660cc injectors
Z32 mafs
3" turbo back exhaust
Waldo fuel pump
Pulley kit
RS Enthalapy rom tune ecu
That's about the just of the main components.
Car will start and stall within 5 seconds .
Unplug Mafs and it idles perfect but won't rev past 2000-2500 then starts backfiring. Plug mafs back in and car dies right away and will not idle. I have NO vacumn leaks. With mafs unplugged vacumn is 19-20 psi.
All my grounds and hooked up.
Mafs is wired correctly ( checked it 3 times).
Does anybody have any ideas?
HATchTRICK is offline   Reply With Quote
Old 02-01-2012, 06:54 PM   #2
Chay G's Avatar
Send a message via MSN to Chay G
maybe your maf is out of range
Chay G is offline   Reply With Quote
Old 02-01-2012, 07:05 PM   #3
HATchTRICK's Avatar
Out of range???
What does that mean and how do I test to find out?
Old 02-01-2012, 07:24 PM   #4
ultimateirving's Avatar
maybe ur maf is bad? Did u just upgrade to z32 maf? how was the car running before or is it fresh swap?
Sr20det,K-Sport Kontrol Pro Coilvers,Isis tension/traction rods-Rucas, Megan Toe rods, freddy intake manifold, 850cc incjectors,Walbro 255, hks wga,Adjustable fpr,z32 maf,Innovate lc-1,Greddy type-s bov,E-mance Rom tune for 91@20psi, 3inch turbo back no cats, ISIS RS3871 turbo j30 shimmed vlsd.
Old 02-01-2012, 07:33 PM   #5
jr_ss's Avatar
Sounds like a dead MAF...
VVL S14 in the works...
jr_ss is online now   Reply With Quote
Old 02-01-2012, 07:34 PM   #6
HATchTRICK's Avatar
Brief run down of what went on here.
Swap was done like 7-8 years ago.
Removed motor for a complete vehicle make over 6 years ago. Got pushed to back burner with lot of other things going on in my life for a while. Now I'm back to working on the car again.
Motor was removed for body work and painting the engine bay. While the motor we out I got a full race turbo kit, greddy intake manifold, 660 cc injectors, enthalapy rom tune, new inter cooler piping, z32 maf, pulley kit, and other minor upgrades.
The mafs was a refurb from autozone, all I could find at the time and needed it ASAP.
Then car sat for 6 years in storage. I got everything hooked back up and now I'm having issues with starting and idling with mafs plugged in.
Old 02-02-2012, 06:42 PM   #7
HATchTRICK's Avatar
Any other suggestions?
Old 02-03-2012, 11:22 AM   #8
HATchTRICK's Avatar
tried a new mafs today. Same results.
here is the updated version to what happens.
the motor ran great. Installed new 660cc injectors,z32 mafs and rom tune. Now it wont idle.
tried 2 seperate mafs and still wont idle without unpluggin mafs. with mafs unplugged it idles perfect, but will not rev past 2000-2500 rpm.
is it possible my rom tune was not done for a z32 mafs????
would that caue these problems?
Old 02-03-2012, 11:40 AM   #9
Sounds like a bad rom tune to me. As soon as you plug in the maf, the fuel map isn't doing the correct fueling. Try with a regular sr maf.
snafupossum is offline   Reply With Quote
Old 02-03-2012, 12:20 PM   #10
HATchTRICK's Avatar
thats what it seems like it boiling down to.
I would try a stock mafs, but i do not have one, and my harness is now wired for Z32 MAFS.
Old 02-05-2012, 06:30 AM   #11
HATchTRICK's Avatar
Old 02-05-2012, 02:33 PM   #12
cotbu's Avatar
Assuming you have no vacuum leaks and everything is working correctly(timing), I'd say the k is wrong and so is the latency. Did enthalpy know the type of injectors? specifically DW660 cc's.
I don't know if these are modified stock 370's or a generic re drilled set. It makes a difference and you could call DW to get that info. Or you could dump the bin and send me a copy and I'll look. In the meantime check for codes and vacuum leaks.
You want to know the injector latency.
Old 02-05-2012, 08:48 PM   #13
HATchTRICK's Avatar
There is not me problem. I do not have my paperwork for the injectors anywhere!
I told him the exact injectors when I did the tune.
Derek's can find a record of me buying the injectors either. So I am kinda stuff as of right now.
I'm hoping t get ahold of enthalapy soon hopefully. I am oping he keeps records of his tunes, and possibly it overlooked and not tuned for the mafs.
I will continue to look for the injector paperwork too in the meantime.
Cotbu.....Are you a rom tuner as well?
I went over every vac line with no leaks already. The car idles perfect without the maf plugged in.
Old 02-05-2012, 09:44 PM   #14
cotbu's Avatar
Yes I am, but here I'm just Tech Support.
When you start the car with the mafs plugged in or out is the check engine light or the ecu diagnostic light on while the engine is running?
Take a look at your chips, send me some pics.
I can write you a quick kvalue change just to see if it starts.
It wouldn't surprise me if you have an s13 sr tune!
Old 02-06-2012, 07:56 AM   #15
HATchTRICK's Avatar
There is NO diagnostic light in my ecu anymore. And i am not sure the engine light is connected to the ecu either because it never comes on saying there is a problem either.
Old 02-06-2012, 08:33 AM   #16
cotbu's Avatar
I would really like to see the tune, but if you have no means of dumping it, You would have to pull the chips and ship them to me, but then again you could just ship them to enthalpy and he could already have your purchase on file and know what to send you. Thus cutting the downtime. Try to contact Enthalpy, and if you still have no luck hit me up!
Call or Text
302-eight9eight-23sixsix Snoop
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/tech-talk/433315-s14-sr20det-wont-run.html
Posted By For Type Date Hits
Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 02-01-2012 07:08 PM 1
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
