| | #1 |
| Leaky Injector ![]() Join Date: Jul 2010 Location: Virginia Beach Age: 26
Trader Rating: (-1) Feedback Score: -1 reviews | OK i have a question for all you RB techs? i am wanting to do some power upgrades to my RB20 im tuned right now at 419hp with 378tq, now i have tomie poncams 252's, custom side intake manifold with a 90mm throttle body, 450cc injectors, hybrid turbo wit a 60ar. and a full 2.5 HKS exhaust, and niztune for computer system... and as far as everything else its all stock. now i was thinking about putting some 272 cam in it but i could only find some for a RB25. also i would like to know if anyone has any opinions on what else i could do other than getting a RB25 and doing a motor swap? can i use other performance parts from a RB25? ![]() ![]() |
| Sponsored Links | |
| | #2 |
| SR/RB Guru ![]() Join Date: Dec 2006 Location: Misawa, Japan
Trader Rating: (5) Feedback Score: 5 reviews | Buy an RB25 so you can buy the cams and put them in it
__________________ 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
| | #3 |
| Zilvia Addict ![]() Join Date: Apr 2008 Location: Calgary Canada Age: 23
Trader Rating: (3) Feedback Score: 3 reviews | water meth is always a good idea. thats the thing with the rb20. if you wanna put out more power then you already have ( which are some impressive numbers btw ) you're gonna need water meth because the cylinder bore is rather small so its prone to detonating whats you go big power. water meth stops this from happening
__________________ 1992 240sx (RB20. 362whp@16psi) |
| | #5 |
Trader Rating: (-1) Feedback Score: -1 reviews | HERE IS A LIST OF EVERYTHING THAT HAS BEEN DONE TO MOTOR. -Rb25det transmission -Stock ECU with Nistune Real time tunning board -Top speed tubular top mount exhaust manifold -Hybrid turbo a/r 60 comp and a/r 50 exhaust 20 pounds no smoke -Z32 maf -450 dsm injectors -Tial wastegate -Aem wideband -spec stage 2 clutch -Megan FPR/ SARD Fuel Rail Adapter -Walbro 255 fuel pump -2.5 down pipe and full 2.5 hks hi power exhaust -Front mount Intercooler –HKS BOV -Aluminum radiator wit dual slim fans (pushers) -Nismo Thermostat -Aluminum Intake Manifold with velocity stacks inside -90mm aluminum throttle body Just recently installed tomei pon cams, new cometic hg, arp head studs, new crank seals, new timing belt, tension and pully, new water pump, custom dump pipe, catch can/breather system. Now if i do go with a bigger turbo what size should i get? i dont wanna get something to big where i aint going to have a butt ton of lag... |
| | #6 |
| I </3 VA ![]() Join Date: Aug 2002 Location: Ass Crack of Hamptin Vagina
Trader Rating: (17) Feedback Score: 17 reviews | If you decide to get a bigger turbo, you're definitely gonna need bigger injectors too. Honestly, I think you're about close to what RB20s can handle. I'd upgrade to an RB25 if I were you.
__________________ If you think Zilvia has too many assholes... CLICK HERE!!! FS: Topline Aragosta Coilover, Zenki Sideskirts/Valence and Tial V44 gate |
| | #7 | |
| Premium Member ![]() | ...................... Quote:
__________________ | |
| | #8 |
| Zilvia Junkie ![]() Join Date: May 2008 Location: Eastern shore, MD-VA/DC Age: 25
Trader Rating: (0) Feedback Score: 0 reviews | How about a RB25/26 swap but nah more power you should start looking up internal parts imo.
__________________ "Today's society is full hatred, war, greed and deception which is sad." |
| | #9 |
| Zilvia Member ![]() | Do not do this! There is a 14 page thread on Ausiskyline about this. There are a few who have been able to successfully place rb25/26 cams into a rb20 head and it work. All others have bent the cams, damaged the valve train etc. To the OP I am pretty much at the same point with my rb20. Like said earlier you can up the turbo and the injectors and turn the boost up. Cost efficient route would have been to just get a rb25/26 but of course that is hindsight now.. |
| | #10 | |
Trader Rating: (17) Feedback Score: 17 reviews | Quote:
__________________ If you think Zilvia has too many assholes... CLICK HERE!!! FS: Topline Aragosta Coilover, Zenki Sideskirts/Valence and Tial V44 gate | |
| | #11 |
| Zilvia Member ![]() | The way he stated it was as if he was telling him to put the rb25/26 cams into a rb20 head. There is a whole debate about weather that is possible or not. The few that have successfully done the swap have said they gained 20-30hp out of simply taking a rb25/26 cams and putting it into a rb20 head. If that was what he was suggesting then it is a bad idea. |
| | #12 |
| Premium Member ![]() | RB25 head has no VVL, it has VTC like the S14 SR's.
| | #14 |
| Zilvia Addict ![]() | bigger turbo, bigger downpipe and exhaust, bigger injectors, upgraded ignition system, and a retune. we used to race a 2.1 liter non variable cam timing, 4 cylinder early 80`s ford cortina 4 cylinder engine that made about 900 horse power.we used a t72 size turbo. yes it probably had some serious boost lag(we had anti lag that let us leave the line at 40 psi of boost). the point i`m trying to get across is, bigger turbo will give you more power. yes, it is only a 2.0, but you have 6 cylinders that would help spool a bigger turbo much faster than a 2.0 4 cylinder engine will. if the exhaust a/r is sized properly and the ecu tune is right on, you can have a big turbo with minimum lag. |
| | #16 |
| Premium Member ![]() | ...................... Whats a 990 throttle body?
| | #17 |
| Leaky Injector ![]() | if your really just looking to squeeze a little more out of it you may want to consider a 3in exhaust. That 2.5 is prob a restriction at over 400whp
| Bookmarks |
| Thread Tools | |
| Display Modes | |
