Old 03-30-2011, 08:38 PM   #1
Power door locks just stopped working
Ok, my power door locks in my 97 Kouki just stopped working all of a sudden. They have functioned properly for the past year and a half. The other day when I was getting out of the car I hit the door lock switch twice and I heard a click from the driverside kick panel. After that the locks haven't worked. I know nothing about the locking system, what could this be?
Now, neither one of my door lock switches will lock or unlock my doors.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 03-31-2011, 12:58 AM   #2
Send a message via AIM to Eramo323
check the fuses
Eramo323 is offline   Reply With Quote
Old 03-31-2011, 01:31 AM   #3
is mad.
mad-ass's Avatar
the door locks are controlled by relay's, and that's the click sound you were hearing. check the relay's by driver side foot panel, you should see 3~4 relays in there. not sure which one is the door lock relay, but you can find out what is what from FSM.
Old 03-31-2011, 10:32 AM   #4
Yeah, i've checked the fuses that I figured could relate to the door locks. I also checked the 4 relays next to the fuse box in the driverside kick panel.
Old 03-31-2011, 02:04 PM   #5
dking240sx's Avatar
I'm having the same issue I just hear the click from the anti theft box crap under the dash click and click but no function what relays did u look at I haven't gotten far. And fuse I tried searching for a fuse that would relate to the door locks no luck yet!
getting sidewayz in LA
dking240sx is offline   Reply With Quote
Old 03-31-2011, 04:02 PM   #6
At least your getting the click. I'm not even getting that anymore. When the malfunction started a heard a little clicking, but now when I press the door lock button I get nothing.
Old 03-31-2011, 07:18 PM   #7
is mad.
mad-ass's Avatar
how did you check the relays? applied power to it and see if it still works?
switch out the relay with the one that you know works for sure and see if that helps any?
Old 03-31-2011, 09:04 PM   #8
I tried swapping out the relays with 1 of the other relays in the kick panel, but I guess I really don't know if the other ones work.
1 thing I just noticed as well, is it seems every since my door locks stopped working the alarm that warns me when the headlights are still on and the ignition has been turned off has stopped working too.
Old 04-01-2011, 10:45 AM   #9
dking240sx's Avatar
What relay are u talking about the brown ones. Wick is the one thatch as anything to do with the power door locks
Old 04-01-2011, 12:30 PM   #10
Yeah, I have 3 brown relays and a light blue (I think) relay. My understanding it the 2nd relay down is the ACC relay which includes doors. Is that right??
Old 04-01-2011, 04:10 PM   #11
dking240sx's Avatar
damm i dont know imm look it up im tired of having to unlock the passenger door all the time... or lock...
Old 04-01-2011, 04:56 PM   #12
is mad.
mad-ass's Avatar
Ok, I was looking at the FSM for something on my car and I stumbled upon this..
I checked my car with this option and that control unit is the one that powers the door locks and has internal relay in the unit. it's right above the driver side kick panel fuse box.
hope this helps
edit: only thing else I can think about if your unit still makes the relay noise when you hit the door lock/unlock, the door lock actuator maybe dead. I ordered mine from amazon and been using it for a while.
power door lock actuator - Google Search
Old 04-01-2011, 05:32 PM   #13
dking240sx's Avatar
Yea that was what I was talking about the secure entrace bs box mine still clicks but it wOnt unlock or lOck
Old 04-01-2011, 05:34 PM   #14
is mad.
mad-ass's Avatar
take your door panels off, and locate the door lock actuator and test the sucker out.
Old 04-01-2011, 06:20 PM   #15
dking240sx's Avatar
ok so long story i pull the pannels off and i come acrros the plugs that acctuate the door lock mechanism unplugged,but beffore i got to that the factory seal was still on the doors chassi so no one has never pulled it off how did the plugs get unplugged or wait im thinking the factory were the car was put together never plugged them in.no i d0ont know what number owner i am like 1st 2nd or 3rd but this car is a 1995 se and no one tried to fix this..well anyways i get to the passenger door take it apart and i come to the same thing the plug was unplugged from the actuator,, what the hell happen here..... but my power door locks now function properly
Old 04-01-2011, 11:20 PM   #16
is mad.
mad-ass's Avatar
good to hear! now the OP needs to get his fixed. LOL
Old 04-02-2011, 12:10 AM   #17
dking240sx's Avatar
I think if the OP doesn't hear the click at all the issue is at the smart entrance control unit that was were my clicking was coming from!
Old 04-02-2011, 01:32 PM   #18
Ok, I'm back. Sorry, I've been working on a tuning program for my setup.
So, yeah. I don't even hear a clicking sound, so maybe I need to pull this whole box out. But, would my headlight chime be affected by this also or is it just coincidence that they went out about the same time?
Old 04-02-2011, 02:37 PM   #19
dking240sx's Avatar
Ok, I'm back. Sorry, when workinng on a tuning program for my setup.
Try to borrow one and swap em out it's a plug and a 2 bolts
Old 04-03-2011, 09:46 AM   #20
Is there a way to unplug the harness from the smart entrance control unit and jump the wires in the harness to activate the door locks? I assume that if I can do that and the locks function it would solidify that the control unit is the issue.
What pins would I need to jump?
Old 04-03-2011, 10:06 AM   #21
dking240sx's Avatar
I domt know the pin layout but if u pull apart your door panel and apply positive and negative u will see the locks do something. To unplug thenharness u have to lift the black colored Swith lever thing sittingnaround the harness
Old 08-01-2011, 08:40 PM   #22
I guess I better update this thread with my results, I see there's a link to this from the Zenki thread.
Anyhow, I finally got around to fixing my power door lock issue and apparently it was the Smart Entrance box located next to the fuse box in the driverside kick panel. I ended up pulling the box out and inspecting the circuit board and relays. Apparently there was a break in solder on the board itself, so I pulled out the soldering iron and re soldered it. Locks are back to working like new.
Old 05-28-2012, 12:10 PM   #23
gtstwincam's Avatar
Send a message via AIM to gtstwincam Send a message via Yahoo to gtstwincam
power lock problem
im having a similar problem with my 95 240sx se
The following stopped working at the same time:
1. Driver door lock
2. Power mirrors
Any ideas?
gtstwincam is offline   Reply With Quote
Old 05-28-2012, 02:29 PM   #24
Agamemnon's Avatar
1. Driver door lock
2. Power mirrors
Any ideas?
Is your sunroof and warning chime still working?
Old 05-29-2012, 01:18 AM   #25
gtstwincam's Avatar
Well I solved part of the problem. I found that the harness plug that goes from the driver door into the fender well was unplugged on the driverside. I plugged it in and now my driver side mirror works!
My main lock switch also works now and I can lock/unlock the passenger door but the driver door still does not lock/unlock.
Old 06-24-2012, 03:03 AM   #26
gtstwincam's Avatar
Update.
I got the power mirrors and passenger door lock to work.
However, the driver side door lock doesn't lock/unlock.
I pulled the panel and tested the harness that goes into the actuator. I get 12v when I press the unlock switch. I get 0v when I press the lock switch.
WTF?
If I'm getting power from the harness when I Press unlock, it should trigger the door lock.
My guess is that both the actuator AND the smart entrance unit is bad.
Any pics of the soldered area (repair) on the smart entrance box?
SEO by vBSEO 3.6.0 PL2
