Old 03-31-2010, 08:54 PM   #1
yoinkAzenki's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
Send a message via AIM to yoinkAzenki
ka24de timing issue (pics)
ok car is a 95 s14 ka24de. ka24det if it really matters. so it was running perfect until oil pump went out. so i pulled the motor and replaced the oil pump along with a new timing chain kit. everything was installed according to fsm specs.
car starts and idles good. but as soon as i give it gas it kinda struggles. it doesnt rev up like it used to. so i check the timing with a timing gun. its obviously off but i have to turn the distributor fully clockwise just to get it close to stock timing which is 20 degrees btdc. now i know thats not normal but car runs a little better but its still not right. i can drive normally but as soon as i mash the gas pedal the car goes nowhere. power is not there... just feels and hears like the intake is sucking a lot of air.
i took top chain off and took pics putting it back together.
crank pulley set at tdc.
cam lobes facing outward.
timing chain marks lined up with cam sprocket marks.
cant really see it but silver chain link lined up with mark on idle sprocket.
distributor marks lined up before putting it in.
cant really see it but how the dizzy marks look when inserted.
dizzy rotor lined up with #1 wire
so did i do anything wrong?
"Drifting is the anticipation of disaster without the disaster"
yoinkAzenki is offline   Reply With Quote
Old 03-31-2010, 11:50 PM   #2
miravete's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
mines non T lol, but i had the same prob when you stepped on the gas.
the timing was all messed up. i did the same thing as you, pulled out the dis, and fixed it.
also changed the fuel pump, fuel filter, cleaned the sparkplugs, and sprayed some w40 on the maf.
buuut, you could start by checking the ecu if it flashes any codes
taking corners just as good as a drunken rhino..
miravete is offline   Reply With Quote
Old 04-01-2010, 07:16 AM   #3
orion::S14's Avatar
You're a tooth off, unless you've fixed it already...
As for no power - My money is on plugs wires out of order. It will start and idle fine if you mix up #2 and #3...
...i.e., firing order is 1-3-4-2 (going counter-clockwise on the distributor)
If you have it 1-2-4-3, it will start and idle just like normal...but drive for shit. No power.
So check that.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 04-01-2010, 01:02 PM   #4
Trader Rating: (29)
already checked for codes and its all clear
So check that.
- Brian
plug wires are in the right order.
so can you tell where im a tooth off? if i have all the marks lined up do i just move the chain a tooth over to the right or left?
Old 04-01-2010, 04:39 PM   #5
Send a message via AIM to chetacheese
what kind of maf are you running? just finished my ka-t. hopefully i can help you here.
chetacheese is offline   Reply With Quote
Old 04-01-2010, 06:05 PM   #6
Trader Rating: (29)
im using a z32 n62 maf
Old 04-02-2010, 06:08 AM   #7
orion::S14's Avatar
If you have to turn the distributor all the way to one side to get it close to 20 BTDC, you're a tooth off.
You need to move it whatever way it needs to be moved so that ~20 BTDC is in the middle of the adjustment. Set it to TDC on #1, and use the #1 plug wire as a reference...and move the dizzy so that the rotor is pointing towards ~11-o'clock.
- Brian
Old 04-02-2010, 05:03 PM   #8
Trader Rating: (29)
- Brian
now when i move the chain a tooth over, do i just move it over on the the cam sprockets only or idle sprocket only? or do i move the chain one tooth over on both the cam and idle sprockets all together?
Old 04-02-2010, 05:11 PM   #9
importdude's Avatar
Send a message via AIM to importdude
your a tooth off on the dis
restab the dis
when u stab it wiggle the rotor so it clicks
in your dis shaft picture
you need to line up the mark shaft with the mark on gear(DIMPLE) left of where it is in the picture
irrc
i will check to make sure from fsm when i get back on the computer for you
built ka-t
importdude is offline   Reply With Quote
Old 04-03-2010, 04:30 PM   #10
orion::S14's Avatar
^^^ What he said, kinda. You're a tooth off on the distributor. No matter what the marks show, it should be at 20-degrees when the dizzy is in the middle of the adjustment range.
(EDITED - NVM, reread)
- Brian
Old 04-04-2010, 07:53 PM   #11
Trader Rating: (29)
can anyone take a pic of their dizzy at tdc? i've tried putting the dizzy in many different ways but it still has to be adjusted away from the middle...
Old 04-06-2010, 01:33 AM   #12
importdude's Avatar
what timing kit are you using?
might be a tooth off the bottom chain?
built ka-t
Old 04-06-2010, 05:12 AM   #13
tdc on the rotor should point around 9-10 o' clock. and spark plug 1 on the distributor cap can be lined up right before the rotor. doesnt have to be right dead in the center. like everyone said you can be a tooth off, so try rotating the dizzy.
also...when you insert the dizzy, the rotor will rotate slightly clockwise. so make sure that prior to inserting the dizzy, the dot doesnt line up with the groove. have the dot line up a few mm to the left so that way once the dizzy is inserted and it rotates, it lines up when its in position.
Old 04-07-2010, 02:52 AM   #14
Trader Rating: (29)
timing kit is probably some generic brand. bottom was setup according to fsm. seems unlikely i could install the lower chain wrong... just lined up the marks. but not sure how or if it could skip?
i actually took a look at a friends ka24de and i couldnt get my dizzy to match up like his. his rotor was in between 9-10 o'clock but mine would always be either before or after. i would start the car on both positions and its either too advanced or too retarded.
Old 04-09-2010, 08:17 PM   #15
and you already rotated it 180*?
Old 11-20-2011, 12:15 PM   #16
sorry to revive this old thread but did you ever figure out the problem? same thing is happening to me
koopas14 is offline   Reply With Quote
Old 07-15-2012, 06:01 PM   #17
I'm having this same exact issue, what is the fix?
GearsofWarfare2 is offline   Reply With Quote
Old 07-15-2012, 07:13 PM   #18
Same here idle is fine but from idle to approx 3000rpms its bogs amd is dumping fuel, I got a new distributer from oreilly auto parts and im still having the same issue
jaxshawn is offline   Reply With Quote
Old 07-17-2012, 11:50 PM   #19
bump , I really wish I could know if it was anything before I start disassembling my motor..
Old 08-16-2012, 09:00 AM   #20
coupesallday!'s Avatar
Send a message via MSN to coupesallday!
Is there a new or different method of approaching this? I have the exact same problem and done everything this guy did. I am pretty sure i'm off a tooth any help will be appreciated. don't wanna start a new thread
coupesallday! is offline   Reply With Quote
Old 08-16-2012, 01:38 PM   #21
anyone....................???
SEO by vBSEO 3.6.0 PL2
