Old 01-11-2010, 02:43 PM   #1
NewYorkCoupe's Avatar
Send a message via AIM to NewYorkCoupe
Help!! Welded differential (How not to)
I'm gonna start off by saying that I try to do everything myself because I like to know its done right. When it came to welding a differential, I just didnt have the right welder to do the job.
A friend who is a professional welder said he'd be happy to help and thats where I ran into issues.
Box Weld came out great.... OR SO I THOUGHT!
-The welds are fantastic
When I looked a little harder, I found that the plate that got welded in was a little to small and was resting on the pin running through the center of the differential ( the one the axels rest on).
PROBLEM: The plates wont let the axels go all the way in. (see below pictures)
SOLUTION: Well at the moment I'm looking for you guys to maybe help me out. My thoughts at the moment are...
1. Cut off the beveled end of the axels, so that the axels rest flat on the plates sticking in from each side.
2. Machine out about 3/8" - 1/2" on each side of the end of the axel, so that it fits between the plates and touches the center pin. Kind of a tongue and groove idea.
So what do you guys think would be the best approach?
Im trying to salvage this shitty situation.
NewYorkCoupe is offline   Reply With Quote
Old 01-11-2010, 04:45 PM   #2
I </3 VA
fliprayzin240sx's Avatar
Get another open diff and start from scratch...fuck cutting corners. Shit like this is how you blow something up and make it worst for yourself.
CLICK HERE!!!
FS: Topline Aragosta Coilover, Zenki Sideskirts/Valence and Tial V44 gate
Old 01-11-2010, 04:49 PM   #3
s13 @ fullboost's Avatar
I have an open diff for sale if you wanna pay shipping its yours.
Old 01-11-2010, 04:52 PM   #4
I really dont see where I "CUT CORNERS" on this.
Old 01-11-2010, 04:52 PM   #5
Hey I should know by the end of the week if I need a new one. Ill keep you in mind. Thanks man
Old 01-11-2010, 04:53 PM   #6
yeah no problem
Old 01-11-2010, 05:22 PM   #7
bardabe's Avatar
Send a message via AIM to bardabe Send a message via MSN to bardabe
Throw it away, and try again.
bardabe is online now   Reply With Quote
Old 01-11-2010, 05:25 PM   #8
RPS13-604's Avatar
welded diff= ghetto
Go and buy a real LSD thats the right way
RPS13-604 is offline   Reply With Quote
Old 01-11-2010, 05:37 PM   #9
Originally Posted by RPS13-604 View Post
welded diff= ghetto
This is not a welded vs vlsd vs 1.5/2 way differential bullshit thread. Lets keep this focused please.
Old 01-11-2010, 05:41 PM   #10
DJDANGER24's Avatar
personally i'd go with 3. toss this and try it again, dont go messing with the axles and throwing the balance off, it may cause more problems for you in the future you know ?
DJDANGER24 is online now   Reply With Quote
Old 01-11-2010, 05:42 PM   #11
is there any way to take the diff apart and cut out the offending metal? if not, i say get another diff and start again.
on another note, let me know if you need a hand. i'm in rochester also.
gsxr141 is offline   Reply With Quote
Old 01-11-2010, 05:48 PM   #12
UPDATE
I will be using a mill to remove rectangle sections that will easily allow me to remove the offending metal. Ill update with pictures when possible.
In the meantime, any other ideas throw em out.
Old 01-11-2010, 05:50 PM   #13
Hey man thanks for the offer, if I get hung up on anything Ill hit you up. Where abouts are you at?
Old 01-11-2010, 05:53 PM   #14
i live near the beach in charlotte.
Old 01-11-2010, 05:56 PM   #15
Thats a riot, I worked at pier 45 at the port for a while, and will be back soon.
Old 01-11-2010, 05:59 PM   #16
open diffs are pretty much free...i dont see why your going to mill your diff out instead of just welding another one
Trevor87 is offline   Reply With Quote
Old 01-11-2010, 07:50 PM   #17
ericcastro's Avatar
Start new or very carefully remove the metal from the plate in the diff.
Dont mess with the axles.
if you break one, you cant just toss another one on in 15 minutes.
It will take you several days to make the new axle fit.
i didnt use a plate.
I just had the neighbor weld up the 4 corners and turn it over and the 4 corners.
The plate is overkill/insurence imo.
Just get some deep and slow heat on the corners and it will hold fine.
Old 01-11-2010, 08:35 PM   #18
orion::S14's Avatar
Juts cut the axles shorter...it will be fine.
There will be PLENTY of spline engagement...same as stock, actually...since all you'll need to cut off is the pointed end (or a little of the splines...but any amount of spline you'd cut off wouldn't be engaged anyway - it would be just in the center section).
Seriously, how is that half-assed at all? It's a perfectly acceptable solution.
??? - Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 01-11-2010, 08:44 PM   #19
apparently welding a diff is ghetto. muscle car guys have been doing it forever. i think it's a perfectly acceptable low dollar upgrade. i've had mine done for 8 months and it's holding up fine. the best part is if it breaks, you can get another diff for cheap.
Old 01-11-2010, 09:18 PM   #20
iROYAL's Avatar
??? - Brian
Yes, finally someone said it. I agree with orion and shave off the tip of the half shafts since they stick out inside the differential. The end that's smooth after the splines does not engage and therefore can be sacrificed in a situation like this.
Racepar1 and I were in the same situation with my car. This was the solution we came with.
iROYAL is offline   Reply With Quote
Old 01-11-2010, 09:27 PM   #21
roboticnissan's Avatar
I can get it done lifetime guarantee for 50
roboticnissan is online now   Reply With Quote
Old 01-11-2010, 09:30 PM   #22
ericcastro's Avatar
exactly.
My Rat Rod neighbor was like,
"you mean a locker?"
they have done it forever.
drifting can break axles though, so it shouldn't be a permanent solution.
I havent changed any axles, but i have one freind thats gone through 7 or so.
just know your risk
Old 01-11-2010, 10:32 PM   #23
I dont understand why you want to spend the money to machine new axles when it could probably be cheaper to acquire another diff and reweld it.
Baling Wire-The Duct Tape Of Champions
Rabboni is offline   Reply With Quote
Old 01-11-2010, 11:02 PM   #24
codyace's Avatar
Trader Rating: (50)
Feedback Score: 50 reviews
Winner winner, chicken dinner.
Seriously, I'm not sure where this 'rage' over a bulllshit plate came into the equation, but it really doesn't make a damn difference.
Welded diff secret, Ace Trucking style:
1. Brake Clean the diff...get that oil off there. Use a hole can, they are only like 3 bucks.
2. Torch. Get the motherfucker nice and warm, and burn any leftover oil.
3. Let it cool
4. Torch it again, get er hot
5. Break out the welder, and on the cooldown, get some weld in there. Ain't gotta be prettry, just gotta stick. Do this as needed on all spider gears, and you'll be good as pie.
I dunno where this 'secret art' came from, but following my abov emethod will last an entire demo derby heat, as well as a final, and then another demo later. That works for me!
Old 01-11-2010, 11:12 PM   #25
duffman1278's Avatar
Send a message via AIM to duffman1278
It came from PBM when people saw how they did it, people on zilvia started wetting themselves and saying "this is the right way to do it, don't tack it"
I got mine welded exactly like ericcastro's, welded the 4 corners, front and back, never had an issue.
duffman1278 is offline   Reply With Quote
Old 01-11-2010, 11:35 PM   #26
I LUV MY S13's Avatar
Trader Rating: (34)
Feedback Score: 34 reviews
??? - Brian
first thing that popped in my head...but i would honestly go with a new one
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 01-12-2010, 12:12 AM   #27
ericcastro's Avatar
3. Let it cool
Ive been on mine for 3 years like that.
I also personally feel that 2 metal plates like that throw off the balance.
(also a consideration in notching the axles).
although, such a small amount might be nill, look at how small the counter weights on tires and drive shafts are.
(probably more of a mental thing for me)
Old 01-12-2010, 10:07 AM   #28
Wow guys I fall asleep and you guys go at it! The idea of the welded differential is some serious old school muscle...they called it the Lincoln Locker.
I figured if I was gonna have someone else weld it, they might as well plate it aka overkill on welds, but its a little more peace of mind on my end.
Old 01-12-2010, 10:35 AM   #29
I hate your "missile"
racepar1's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
I had the same problem with a customer's diff the he supplied. After getting a couple other welded diffs that were both bad, cracked welds and such, I just machined the stub shafts to clear. The way yours is welded is pretty strong, but you just need to clearence the stub shafts. Just make sure that the snap ring groove in the stub shafts are not disturbed...
"He's one of those "drift" guys, that's like ballroom dancing to me." -Paul Tracy
Need a mechanic in so-cal? PM me!
Old 01-12-2010, 03:14 PM   #30
fcdrifter20's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
3. Let it cool
YES!!! this is my procedure exactly lol. i have been doing them like this for the las several years, and have not had a problem yet
fcdrifter20 is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
