Old 12-28-2009, 02:33 AM   #1
liquid gasket vs solid gasket for oil pan?
I was thinking that you might not have to take pan completely off if you used a solid gasket? maybe cut it in one spot and silicone the cut area.
yukon is offline   Reply With Quote
Old 12-28-2009, 03:01 AM   #2
why wouldnt you take the oil pan off completely?
s13gebala is offline   Reply With Quote
Old 12-28-2009, 03:22 AM   #3
Odysseus's Avatar
What the fuck are you talking about?
Odysseus is offline   Reply With Quote
Old 12-28-2009, 06:32 AM   #4
Shadowhunter's Avatar
I'm with this guy.
Shadowhunter is offline   Reply With Quote
Old 12-28-2009, 06:36 AM   #5
Has a Premium Member.
murda-c's Avatar
He's got an oil pan leak and is thinking of cutting the gasket to put it on so he doesn't have to take the pan all the way off.
Old 12-28-2009, 06:47 AM   #6
payne219's Avatar
it wont work. you cant stuff liquid gasket on top of an already leaking area in hopes that it will seal.
Do it right the first time. drop the pan. remove all old gasket material and replace with a new one.
payne219 is offline   Reply With Quote
Old 12-28-2009, 07:20 AM   #7
240sxfamily's Avatar
i used both, droped my motor in it still leaked...lol pulled the front of my oil pan down, and used an assload of rtv. and called it a day, no leaks now.
"We're not just a forum, we're a family."
240sxfamily . com
240sxfamily is offline   Reply With Quote
Old 12-28-2009, 07:32 AM   #8
AznDrftr.'s Avatar
Send a message via AIM to AznDrftr. Send a message via MSN to AznDrftr. Send a message via Yahoo to AznDrftr.
^LOL.
Well, i must say, if it has something to deal with the life of my motor, hell, i'll drop that oil pan every time to assure there is no leaks. Its not fun, but it'll save some money from burning a hole in your pocket.
just my
AznDrftr. is offline   Reply With Quote
Old 12-28-2009, 08:14 AM   #9
ManoNegra's Avatar
Trader Rating: (36)
I use a felpro gasket and gasket RTV
also torque bolts in sequence per FSM
I think this is one of the reason oil pan gasket always leak, people tend to over-torque those bolts.
Old 12-28-2009, 08:30 AM   #10
rb26man's Avatar
Send a message via AIM to rb26man Send a message via Yahoo to rb26man
use a gasket and rtv hasnt failed me yet...just take the time out and do it the right way...if u cut corners it will only bite u in the ass at the end..just giving u some friendly advice
rb26man is offline   Reply With Quote
Old 12-28-2009, 11:19 AM   #11
What's the right way to use a gasket and rtv? Does the gasket go on the block side and the rtv on the pan?
R33E8 is online now   Reply With Quote
Old 12-28-2009, 12:06 PM   #12
Ben G's Avatar
You should never use rtv as a gasket, when you press then pan down it squishes and goes on both sides and beads up when it dries... i dont know about you but little beads of dried rtv is not what i want in my oil pan, you know where it goes from there
Ben G is offline   Reply With Quote
Old 12-28-2009, 01:44 PM   #13
japslapsilvia's Avatar
^^ prime example of how NOT to use RTV....you are supose to let it get firm B4 ur tighten it.
RTV is what NISSAN uses and recomends for most of the gaskets on MOST if not all of its motors. which is y a tube of nissan RTV is included in a master gasket set.
So its true, asian women are tighter than usdm women!
japslapsilvia is online now   Reply With Quote
Old 12-28-2009, 02:06 PM   #14
initial_drifter's Avatar
If you have a steady hand and can maintain the size of the bead you will not have any issues when tightened down, especially with "over-beading" issues
As said earlier, DO NOT WAIT FOR THE RTV TO HARDEN
Even at our dealership we all set the bead and torque the bolts down. Wait an hour or two depending on the customer's schedule and then pour oil in
initial_drifter is offline   Reply With Quote
Old 12-28-2009, 02:30 PM   #15
240_fun's Avatar
I used an RTV from pepboys called "Hylomar" (i think) its blue and it worked with a felpro gasket no leaks, only downside was later on when i had to take the pan off it was almost impossible to get off
240_fun is offline   Reply With Quote
Old 12-28-2009, 03:43 PM   #16
g6civcx's Avatar
Some people don't know how to follow directions:
Originally Posted by Permatex
6. Assemble parts immediately while silicone is still wet.
7. Finger tighten flange only until material begins to seep
out the sides of the flange.
8. Allow to set for at least two hours and re-torque at
lease one quarter to one half turn.
9. For best results, allow to cure overnight.
g6civcx is online now   Reply With Quote
SEO by vBSEO 3.3.0
