| | #1 |
| Zilvia Member ![]() | Car smells like gas/bad mpg. about 3-4 days ago my car started smelling like gas. i rarely smell it when im in the car. windows down or up. after having it parked for 2-3 hours in the garage it starts smelling like gas. it was coming from under the hood. the smell was near the intake manifold. i also get VERY bad mpg. it was about 5-7 mpg. i would pour 20$ and would only be able to get couple of miles. help please. |
| Sponsored Links | |
| | #2 |
| my name is Nigel Bakerbutcher ![]() | Fuel Pump - $50 - $100 (Depending on whether you get a Walboro or a Stock Pump) Fuel Filter - $5 - $15: This filter's definitely going to give you better MPG Fuel Tank/Pump Gasket - $10 I'd say replace your fuel hoses or check for a leak in any of them. if the smell is coming from the intake manifold, it is either a leaking hose, or filter, or the hardline that comes from the chassis that goes into the filtration system for the dual cam. If you're STILL having problems, you've got an injector problem, time to replace O-Rings OR the injectors themselves. |
| | #3 |
| Premium Member ![]() | I would go ahead and replace the giant o-ring at the gas tank. You should also look into replacing the feed and return lines at the gas tank. Mine were cracked from old age and it caused fuel to leak from there. |
| | #4 |
| Zilvia FREAK! ![]() | check what the said above and since you said from the engine bay check the feed and and return line in the engine bay make sure when you buy a replacement hose that its a fuel line 5/8" and maybe a new gas cap
__________________ infinitwheels.com pitgarage.net |
| | #6 |
| my name is Nigel Bakerbutcher ![]() | If yours is frm the trunk, then it's either the gas tank/fuelpump gasket AND OR a cracked/leaking fuel line coming from the fuel pump, I'm 100% sure either of those will be the problem. Funny thing about this is that when I had my tank/pump gasket missing, I opened up the tank to see if it was there (which it wasn't), I pulled the pump out and sure enough the gasket was wrapped around the pump. |
| | #8 |
| my name is Nigel Bakerbutcher ![]() | well a leak is PROBABLY not your problem. 'canister'? what 'canister' |
| | #9 |
| Zilvia Addict ![]() | I'm having similar issues, could an old fuel pressure regulator be to blame? I have replaced the fuel pump and the fuel filter, mabye I should look at injectors
__________________ That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd ![]() Boycott Berkeley and code pink |
| | #11 |
| bukkakedrift420 ![]() | Most all of your problems are the soft line. In the front, it will be the one right under the fuel filter canister thing. these are cracked on half the old 240's you tech at the track. just reach under the canister thing and rub your hand along the bottom of the rubber line there. Bunch of moist dirt and crap on your hand huh? replace it. In the rear, its one of the 2 lines coming out of your fuel pump. you can get a look at most of it by looking at it from underneath with a flashlight. Or take the cover off and look at it from above. Its probably cracked where it hooks onto the fuel pump. Both are extremely common. The other problems are more rare.
__________________ The Famous ZIPTIED is taking applications for members right now. www.ziptied.com, PM me if you need, and use my name for your VOUCHE ![]() |
| | #12 | |
| Nissanaholic! ![]() | Quote:
1) Stop farting in your car 2) Ease off the gas. Just playing man.
__________________ WTB: Clean, uncracked black S14 dashboard Last edited by jspaeth; 12-07-2009 at 01:48 PM. | |
| | #13 | |
Your fuel lines run from back-to-front on the passenger side, so you're leaking fuel from a bad hose/clamp. Worse case it's your injector seals. You need to start your car, have the front end lifted up, get under there with a flash light and look for the wet spot on the fuel lines. It shouldn't be hard to find if you're getting only 5-7 mpg, you've got a bad leak. As for the stuff that others mentioned for you replace, that's all fine and good for improving MPG, but not a leak. The only way your fuel filter is going to be the culprit is if it's been punctured somehow. (runaway screwdriver?) Also someone else mentioned fuel smell coming from inside the car, if this is the case, you've got a leaking fuel pump cover gasket, or it's improperly sealed. simple. Get to checking and save that Petrol! GL
__________________ Don't mess with my monkey...he's loaded. | |
| | #14 | |
| bukkakedrift420 ![]() | Quote:
Let us know the results. Takes 5 minutes to look
__________________ The Famous ZIPTIED is taking applications for members right now. www.ziptied.com, PM me if you need, and use my name for your VOUCHE ![]() | |
| | #15 |
| Zilvia Member ![]() | thanks guys. just bought another fuel filter (300zx) and i found a cut in one of the hoses. replaced it. imma see if the mpg improved or not thanks alot guys |
| Sponsored Links | |
| | #17 |
| Zilvia Junkie ![]() | |
| | #18 |
| Zilvia Member ![]() | check under your car for gas leaks, mine leaked under where the gas tank was at, it was the fuel pump lines to the gas tank if i remember, and yea it smells of gas and bad gas mileage. look under the car if it leaves a puddle of gas or see if you can catch it dripping mine did!
__________________ |
| | #19 | |
| Post Whore! ![]() | iambape I would like to meet you one day for dealing with all the bullshit you've been through in that damn car.
__________________ Quote:
| | #20 |
| Zilvia Member ![]() | LOL.. ever since i lefted NCD there would be a problem everyday. but rather than before i did research first lawlz. finally smell is gone. edit* there was no leak besides the one near the fuel filter. i never see any liquid on the ground. |
| | #21 | ||
| Post Whore! ![]() | Quote:
If you have visible gas leaks, you shouldn't be driving that thing around.
| | #24 |
| bukkakedrift420 ![]() | Good work mang ![]() always feels nice to get the problem on the 240 on your first try, lol
| | #26 |
| Zilvia Junkie ![]() | I had a hard time trying to find metric sized fuel line, but the closest size I could find was 5/16th's ID. Personally I would try to keep the hoses I use to as close the diameter of the hardlines/filter as possible. |
| | #29 | |
| S14 Reaper ![]() | Quote:
gee...i dunno...i just wish car makers would supply parts for there own cars... ![]() there 10 bucks...
__________________ LOL 240... whats better than 1? 5 1's ...lolXBL GT : Wh0pp3r68 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
