Old 11-22-2009, 06:55 PM   #1
89 240sx with a couple of problems
hey guys I just purchase an 89 and it is almost perfect just a couple of problems. The headlights don't move up or down. I have to manually move the headlights up or down. Unless the fuse is blown? Not sure I'll look more into it. Also It is an 89 that has a KA24DE conversion everything works except the tach. What should I do to get the tach working. Need to know where the rev's are at for drifting also the timing chain is getting really loud is it time for replacement. Finally the power steering works but when I'm at a stop the pump shuts off I guess I have to rev the engine to get the steering wheel turnable. Besides this awesome car. Thanks for all the help guys .
Deviousjet is online now   Reply With Quote
Old 11-22-2009, 07:11 PM   #2
sil80 monster's Avatar
you need a DOHC tach, remove the chain guides for the noise, get a new PS pump, learn to search
sil80 monster is offline   Reply With Quote
Old 11-22-2009, 08:47 PM   #3
stinky_180's Avatar
WHAT?
you need a SOHC tach. chain guides noisy or the timing chain? replace the timing chain either way.
"Don't be a parts changer, be a mechanic!"
Old 11-23-2009, 12:24 PM   #4
I have a sohc tach. the chain guide is noisy I'll have to waity for the timing chain. I hate doing that job done it once before. Also any help on the headlights?
Old 11-23-2009, 01:05 PM   #5
usajdm's Avatar
Things to check for the headlight are the fuse, relay and dash switch.
If you have a friend with a 240, use his car to swap out parts to see which is bad.
Need airline tickets?..... hit me up.
usajdm is offline   Reply With Quote
Old 11-23-2009, 04:55 PM   #6
g6civcx's Avatar
Before you do that, pull out the FSM and check every single wire, fuse, relay. And check grounds!
If you're sure it's 100% good then you can start swapping out parts.
Old 11-23-2009, 10:08 PM   #7
usajdm's Avatar
True the FSM is helpfull, but before checking "every single wire", wouldnt it be easier to pop out its designated fuse, a single relay and dash switch(which pops right out).
One of those three are more likely to be the culprit(although it could end-up being a wire) and should take no more then 5 minutes to check.
Old 11-23-2009, 10:15 PM   #8
g6civcx's Avatar
I didn't know we were spoonfeeding that much today.
I would pull each fuse and check them first. Then I would pull each relay and test the relays. Then I would check for continuity between all the connectors the way they're outlined in the FSM. Then I would check for shorts to ground and other wires.
Old 11-24-2009, 09:57 AM   #9
Thanks guys I just bought the FSM from autozone. Have a few friend with the headlights. I'll check it out. Thanks.
Old 11-24-2009, 09:58 AM   #10
Any ideas on the Powersteering pump?
Old 11-25-2009, 06:03 AM   #11
Thats probably not a FSM you have there expecially from autozone. Probably a Chilton or Haynes manual. You can find FSM's all over the internet if you searched.
KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's
ForcedNduction is offline   Reply With Quote
Old 11-25-2009, 12:23 PM   #12
I'm getting a theme here. Search. Thanks guys for all your help.
SEO by vBSEO 3.3.0
