| | LinkBack (1) | Thread Tools | Display Modes |
| Zilvia FREAK! ![]() | The Track Cat... Ran across this on a local forum; anybody running one of these? Apparently its a little shop down here in Georgia called Fat Cat Fabrication "The Track Cat" Nissan 240sx S13 Rear Suspension System
__________________ Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
| Sponsored Links | |
| | #4 |
| The 510 Post Whore ![]() | Is that an actual cantilevered coilover setup? Or is it just coilovers mounted to a trunk strut brace? It LOOKS like it's the actual suspension, which would mean it'd work just fine, but even on the web site, it doesn't show much detail...
__________________ |
| | #5 | |
| Zilvia FREAK! ![]() | Quote:
You're an idiot...
__________________ Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson | |
| | #6 |
| Doctor Chips ![]() | Been discussed a bit on Nissan Road Racing - my vote is stupid "race car" bling. The benefits are ridiculous, and the chance of those dampers being properly valved for the motion ratios and spring rates involved is pretty low.
__________________ 06 Infiniti G35 Coupe 6 MT - Diamond Graphite/Stone 92 Nissan 240SX S13 Hatch GT2876R - Constantly tinkering and lots of garage naps... Safety Red/Gloss Black |
| | #8 |
| The Dirty DINO ( )o( )™ ![]() | meow ....lol remind's me of this FIT from SS Extreme Dimensions 2007 Honda Fit Interior View Honda Cbr 600Rr Shocks Photo |
| | #9 |
| Zilvia Addict ![]() | you don't understand how suspension works yet. please, study.
__________________ "I'm a rage-aholic, I just can't live with rage-ahol!!!" |
| | #12 |
| The 510 Post Whore ![]() | It's not just a rear strut brace. The rear struts apparently travel up through the top of the strut tower and triangulate that pressure down through the coilovers mounted to the strut brace. At least... that's what I'm assuming.
| | #13 |
| that is a very accurate assumption. what they need to show is that there is a suspension "push rod" that comes from where a coilover would normally go to make the springs/struts they put there usable. either way, i'm with Def.
__________________ | |
| | #15 | |
| Zilvia Addict ![]() | Quote:
first you'd have to determine what a "good typical coilover" is. however as to the comments that this suspension setup is usless.... read a damn book, hell look at the guys in the little known race series F1. this suspension design has proven itself time and time again. and the physics behind it I don't know ( haven't found the info yet). but before you bash on me I'm not saying the track cat is a god send when it comes to suspension tuning, and I'm also not saying that this specific example is built the way it should be. I simply don't know. however that type of suspension setup is tits. Stop shooting down shit you don't understand.
__________________ That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd http://i100.photobucket.com/albums/m...c4a42a4332.gif Boycott Berkeley and code pink | |
| Sponsored Links | |
| | #16 | |
| Doctor Chips ![]() | Quote:
Pushrod suspensions are used in Formula cars for packaging/aero reasons. Fast door slammers use nice dampers mounted in the normal location(in the wheel well). Very slightly reduced unsprung weight is stupid at the expense of probably 40+ lbs way up high in the chassis.
__________________ 06 Infiniti G35 Coupe 6 MT - Diamond Graphite/Stone 92 Nissan 240SX S13 Hatch GT2876R - Constantly tinkering and lots of garage naps... Safety Red/Gloss Black | |
| | #17 |
| AFC #1 ![]() | I saw this a couple months ago when someone familiar with their honda applications showed me they came out with this. Cantilever set up is good when you want a lot of shock travel with little wheel travel. Damping really heavy spring rates. These seem to be motorcycle rear shocks designed for a vehicle with a lot less weight. I don't see how they could manage the weight of a car. Also, what do you run at the front of the car? Not going to be a balanced setup in travel, damping and spring rate.
__________________ Comments should be taken as Opinions not as Statements of Fact. |
| | #18 |
| Doctor Chips ![]() | Except the motion ratio between the wheel and shock is REDUCED very clearly in this "awesome setup."
| | #19 |
| Zilvia Junkie ![]() | What is purpose of this set up?
__________________ Visiting From UpNorthImports.com |
| | #20 |
| Zilvia Addict ![]() | by the looks of it this guys has no need for the cantilever setup however I still don't see how it could be a complete waste... having a cantilever setup frees up a lot of room from what I understand, and its benefits are minimal at least. as for the weight, how much are we really adding? removing the stock shock and spring.....20 pounds? tops? (each side)* correct me if I'm wrong here* installing the push rod setup including the cantilever pivot and coil......for shits lets say 25 tops. (each side) being that its only in there rear that's a net gain of 10 pounds (estimated) * I dont include the rear brace/mounting system because half of us have some sort of rear brace or some bar so I don't see how it could be held against the setup. if it were a track car than there would be other ways to shed the weight to make up for the suspension. in this specific setup the benefits of the altered suspension geometry outweigh the added 10 pounds. he may want to fit some super hot wheels, or likes the benefit of a cantilever, who knows. but it still remains the same mabye not for this specific app. but cantilever had been proven. it may not be for the street but on the track it performs. I'm going to e-mail them though and see if i can get a dyno on the coils I very much agree.
| | #21 |
| THIS, That was sorta my reason for considering it, however after looking at the pictures more I realized its not going to fit under the stock privacy cover. I was considering using it in hopes of fitting wheels with enough backspacing to get some 275/40/17's under the rear of my S13, without any sort of poking out or rubbing. | |
| | #22 |
| AFC #1 ![]() | I wonder if they even calculated the ratio?
| | #23 |
| fwuffy bunny rigor mortis ![]() | hey, i'm just glad to see that people are still developing new products for s-chassis. even if this version isn't practical, maybe v2 or v3 will be an improvement.... |
| | #24 | |
| | #25 | |
I guarantee you that bent bar is way heavier than the average eBay strut bar that most S-chassis guys run to handle all the suspension loads. You guys are ridiculous. You don't even have the faintest idea of why you'd really want a setup like this, and what would make it actually good. You just see something "neat" and get all butthurt when anybody logically critiques it. ![]() And do you even know what you'd be looking at on a damper dyno?
| | #26 | |
| Quote:
I'm not going to be willing to do a pull, i'll be cutting away as much of the lip as possible reasonably, and definetly would gain clearance using this suspension setup for additional offset/backspacing, as far as the tire size sucking, this will be for weekend use at the drag strip, and the availability of nice drag radials in 255 17" doesnt really exist, not to mention i'll be able to make use of a 275 ![]() | ||
| | #28 | |
| Premium Member ![]() Join Date: Sep 2006 Location: meet a giant fish....LIKE A BOSS!! Age: 33
Trader Rating: (4) | Quote:
thats gonna lead to headache and weaker metal along the edge there. do like they said and roll it. totally different than a pull, but both useing similar techniques so the confusion is understandable.
__________________ No, its not an SR, its a single cam.......... ![]() | |
| | #29 | |
| Dizzill-Dizzo ![]() | Quote:
edit: Just noticed also those pivot deals on the stock shock mount side look awful close to the blue contraption. If the car is sitting at ride height with the suspension loaded then one dip or bump and when the suspension rebounds................no good will happen. | |
| | #30 | |
Oh well, glad to see at least a few people realizing this is a pretty ridiculous "mod" that doesn't look like it has much thought or engineering put into the finer points.
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/tech-talk/288374-track-cat.html | ||||
| Posted By | For | Type | Date | Hits |
| Drift Utah :: View topic - This thread is for Josh. | This thread | Refback | 11-08-2009 11:11 PM | 8 |
