| | #1 |
| Leaky Injector | Rod bearing size I would like to know if any one knows what size rod bearings I need for a stock KA24DE. I don’t know if I need to get the STD size or a bigger size to allow for any rubbing. And I do not have a gage to measure the size of the rod or crank shaft.
__________________ |
| Sponsored Links | |
| | #2 |
| premium bullsh!t sifter ![]() | OMG are you serious? To allow for any rubbing? This is a great example of why you need to take your engine to a reputable shop and have it built for you. Yes, building any engine in this world typically requires the use of special tools, the knowledge of how to use them, a mechanic of some sort that has basic knowledge the type of engine and selection of parts. Yes, many people may be able to assemble an engine, but there is much more to assembling an engine correctly than just turning nuts and bolts... If anyone thinks differently, you're an idiot... turn your vehicle off, never operate an engine, motor or turbine ever again and walk for the rest of your life. To answer your question: If your journal is std and your rod is std, I would imagine you would use a std rod bearing. Use plastigauge (shutters at the thought...) to check the rod bearing clearance. Did you check the big end of your rod to see if its within specs? Did you have your journal checked for size, roundness and taper? pm me if you plan to have your engine built right. ~mario
__________________ Don't Know How To Install? IM/PM Read My Sales Review 626 Friday Nights San Gabriel |
| | #6 |
| Premium Member ![]() | i assembed my sr20det, i had a shop do all the machine work and he did the crank, rods, and block journals for me, i had a spun bearing on my 3rd cylinder, i had to go .75 over on the rods. and .25 over on my crank, i have never rebuilt a motor nor did i have any help besides the stated above and the car has ran great for a month, no rod knock, or anything, just take your time, and if you dont know how to do it, research it like a motherfer or take it to a shop, oh yeah, afinity times check everything if you do do it yourself, i did and im glad i did, i had my timing off a tooth on the crank pully... better safe then sorry... p.s. if your saying you need larger ones for rubbing take it to the shop, you dont want any kind of rubbing in your motor, you want it to turn over smooth and all your clearances to be right... you need standard i bet, the bigger size im assuming is for if you have to grind the crank(spun bearing, ect...)
__________________ 1995 240sx SE (current) |
| | #7 | |
| premium bullsh!t sifter ![]() | Quote:
I see factory specs as (Any S Chassis KA24DE): Journal Diameter Grade No. 0 as 1.9672" - 1.9675" Grade No. 1 as 1.9670" - 1.9672" Grade No. 2 as 1.9668" - 1.9670" Journal Limit Taper of Journal = 0.0001" Out of Round = 0.0002" Bearing Clearance Connecting Rod Clearance = 0.0004" - 0.0014" Limit Connecting Rod Clearance Limit = 0.0035" ~m
__________________ Don't Know How To Install? IM/PM Read My Sales Review 626 Friday Nights San Gabriel | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
