Old 11-01-2009, 06:20 PM   #1
RB20 boost leak?
My friends RB20 has a boost leak, he turned up the boost to about 18psi and then the manifold came loose.
Can anyone help with the problem? Where would be the couple of places to check?
Thanks
SilS13Coupe is offline   Reply With Quote
Old 11-01-2009, 06:41 PM   #2
In time-out for misbehaving.
the manifold maybe. intercooler piping/mount.bov,etc,etc...
kushlivin is offline   Reply With Quote
Old 11-01-2009, 06:52 PM   #3
Yeah, pain in the ass to check every single place. He says the boost gauge will read its boosting, but its not boosting at all.
Old 11-01-2009, 06:56 PM   #4
Sileighty_85's Avatar
Thanks
I dont understand your question/ Problem... Which manifold? intake or exhaust????
so the manifold came loose cuz of boost causing a boost leak?
Maybe you should tighten the manifold back down..... sounds crazy but that just might fix your manifold
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 11-01-2009, 07:02 PM   #5
He says exhaust mani came loose and when he bolt it back on it wouldnt boost anymore.
Old 11-01-2009, 07:14 PM   #6
what turbo is he running?
Im gonna ROTFL if you say stock.... please say stock
後輪駆動車1番
Old 11-01-2009, 07:18 PM   #7
Lol yup stock turbo. I guess we solved the issue? A new turbo is in need?
Old 11-01-2009, 07:25 PM   #8
BINGO!!!
The Stock turbo exhaust wheel is ceramic so anything over basically 12psi (some say 10 some sy 14) with destroy the exhaust wheel= No Boost
Tell your buddy hes a dumbass
後輪駆動車1番
Old 11-01-2009, 07:31 PM   #9
BINGO!!!
thats too fu*king funny^^
Old 11-01-2009, 07:33 PM   #10
BINGO!!!
hahaha, well hes selling it because he doesnt know whats going on.
Maybe i should pick it up and just replace the turbo.
Old 11-01-2009, 07:38 PM   #11
lol maybe...
FYI same goes for the RB25 Turbo too.
後輪駆動車1番
Old 11-01-2009, 07:41 PM   #12
lol maybe...
So most likely, just replacing the turbo will be ok right. If that is the case, i'll definitely pick it up. Hes selling it for cheap.
What kind of turbos are on the RB's?
Old 11-01-2009, 07:43 PM   #13
Unique's Avatar
Send a message via AIM to Unique
I remember one of my boys having a similiar problem, his brake booster took a crap which caused a vaccum leak which caused the car to run lean and not letting the car boost regularly.
Unique is offline   Reply With Quote
Old 11-01-2009, 07:54 PM   #14
Not sure on the turbo's Numbers but they can be compared to the SR's turbos
RB20=T25
RB25=T28
RB20 Right RB25 Left
後輪駆動車1番
Old 11-01-2009, 07:58 PM   #15
RB20=T25
RB25=T28
Thanks alot! But before i pick it up, i just want to make sure that IS the problem..
Old 11-01-2009, 08:02 PM   #16
right the problem will be oblivious due to no exhaust wheel/broken fins
i can pretty much gaurentee you thats the problem
後輪駆動車1番
Old 11-01-2009, 08:16 PM   #17
If he turned it to 18psi on the stock turbo how much u want to bet he has a stock pump in it too. Could have hurt the motor or head gasket too.
protech-fabrication.com ftw!!
Old 11-01-2009, 08:18 PM   #18
well he said that the car starts up fine, no smoke or anything. And he said you can still hear the turbo wheels spinning.
Old 11-01-2009, 08:24 PM   #19
Thats just the Ball bearing CHRA, the wheel is destroyed so it wont build boost at all cuz it cannot spin fast enough.
Like Yellow said check that pump
後輪駆動車1番
Old 11-02-2009, 01:05 PM   #20
Would i just need to the replace the turbo itself? I want to pick it up, but i dont wanna risk buying it, replacing the turbo and find out the motor is gone.
It if doesnt blow any smokes, the gasket should be ok and the motor should be ok too right?
Old 11-02-2009, 05:06 PM   #21
cant really say for certian that is the only problem but i would check the turbo first.
If he still has a cat (doubtful) pull the cat and look for little ceramic pieces
後輪駆動車1番
Old 11-04-2009, 12:06 AM   #22
It has cutouts.
SEO by vBSEO 3.3.0
