| | LinkBack (1) | Thread Tools | Display Modes |
| Help new build won't start. Finally got kat finished but it wont turn over. got my e-mance ecu in. Got spark and fuel but does not seem to be popping. timing is good as well as dizzy could this be the coil? spark seems very weak. | |
| Sponsored Links | |
| | #3 |
| Zilvia FREAK! ![]() | Is the battery fully charged???...+12.5volts (weak spark will come from a low battery, when the starter is sucking up all the current to turn the motor over). How did you determine the timing was good, if it hasn't started? That's probably the #1 messed up thing on KA builds/rebuilds. If you just lined up the dots and popped it in there, then that's MOST LIKELY your issue. I've done it countless times, and still get it wrong sometimes. - Brian
__________________ www.KA24DEvelopment.com |
| | #4 |
| Zilvia Addict ![]() | what i have to say will most likely have nothing to do with the starting but your mistake is the E-Mance ECU. my ka-t blew and do you have a built ka? if you do then good luck on building another motor. as for the start up, double check your wires and make sure you installed them correctly. do yo have the msd blaster coil ss? |
| | #5 |
| oem blaster. Timing was done by have set timing chain to TDC along with cam lobes being properly positioned along with motor being in correct stroke. I'm having trouble finding good right up on timing. had alink but lost it. FSM beats around the bush and is fair at best. Yes fully built motor and yes e-mance. Anyone can blow a motor for any odd number of reasons. I don't play the blame game, just play the game. | |
| | #7 | |
| Zilvia Addict ![]() | Quote:
Technical Articles: 240sx Distributor Timing if i were you i would get a msd blaster ss coil. my stock one went out couple of miles after i got my ka built. it wouldnt let me start up when hott (which has nothing to do with your problem) anyways, as for the ecu, who spends all that money building a motor and then buys a cheap ass tune ? good luck with the tune.lmk how your car turns out after you double check everything | |
| | #9 |
| Zilvia Addict ![]() | timing timing timing timing. have seen this problem many times. 9 times outa 10 when i go check it out timing is off. u gota make sure that rotor is before #1 not on it.so if u have to pull cap off, install dizzy and see wher the rotor ends up then adjust as needed. this is most likely ur issue. |
| | #10 | |
my built ka never started too but then i remember it was the builders fault by installing the cams wrong, intake on exhaust and exhaust on intake but then he got the car started without switching them around so i still think it was timing. anyways check it out CIMG4670.flv video by 91240sxfastback - Photobucket | |
| | #11 | |
| Zilvia Member ![]() | Quote:
same base map you were running, i have running on my best friends ka for over 2 years.. never a hickup/never a glitch just 12 psi daily.. i think there was something wrong with your setup somewhere else and that is why your motor blew up. i guess its easy to blame a tune and not shitty used injectors or maybe a dying fuel pump, incorrect base timing or 10 year old waste gate that could be going out... the list goes on a tune is only as good as the build it is supporting.. i guess i need to put a disclaimer about using used parts and my tunes. i have sold hundreds and hundreds of tunes and have only a few complaints, you're one of the biggest complaints i have had. cant please everyone and i know this but i do stand 100% behind my tunes and wouldnt sell anything that i didnt feel was safe. hell how do i have a 720whp ka-t? it should of blown up years don't you think? anyhow back to subject at hand, OP: check your cam timing it sounds like your timing is off
__________________ S14 KA-T 720whp / 568 wtq @ 40psi | |
| | #12 | |
| Quote:
| | #13 | |
| Quote:
| | #14 | |
HA! first off i had brand new wal-bro fuel pump and injectors from d-werks. when i got your tune it wouldnt start up in the morning (cold start) til couple of tries. when it started my car would idle alot better but then would run like crap. it was jerking on the begining or 1st, 2nd, and a little on 3rd gear til a certain RPM then it would stop. i remember you said that you tuned my 450CC injectors at 460cc on the tune because it was flowing at that rate. and then about 1 week later when i was boosting BOOOOOOOOM! motors gone. so my question here is was it my brand new parts that caused my motor to blow? or was it the tune being tuned for 460CC instead of 450CC like the chart says when i purchased the injectors from d-werks? i dont know but this is a easy answer. remember all the parts i had were BRAND NEW except the turbo (turbo wasnt messed up). all im doing here is trying to save people from going through what i had been through. now i have a built KADE with a Enthalpy ECU and i love it! been running for almost a year now with no problems since the day i installed it. ![]() goodluck in your business jason | |
| | #15 | |
you are running same injectors on your setup right now? im impressed if you are. how was your cam timing then? was it checked and double checked? what blew on your motor? ring lands? if so its from too much timing, boost spike or both (granted your injectors were flowing what they claimed and fuel pump/fpr were doing their job) like i said that tune has been going strong on my best friends car for over 2 years no hiccups so something is wrong here. im reviewing your tune right now you have 14 degrees total timing up top under boost so i highly doubt my tune blew your motor unless your compression is somehow above 10.5:1 from carbon buildup or something else. Also, importdude was running my 450cc tune on his ka-t for a while and his motor never blew up until he upgraded to 850cc, turned the boost up and get a retune from me and he's been rocking that ever since may... wonder why his motor didnt blow?
| Sponsored Links | |
| | #16 | |
first off you tune the ecu at 460cc instead of 450cc and you told me that on the phone and even said that you did it because it was flowing at that rate on the paper and it would be fine. btw, before i bought your tune my car wasnt giving any hiccup or problems. it was tuned by my afc neo, and the only reason why i decided to go with a ECU tuned was to make my car run at 100% power. remember this, when my car was still tuned by the NEO, it ran for over 2 months if i can remember with absolutly no problems and it was with the 450cc from d-werks. as for my timing it was done by me and my mechanic and not just that, when i took my car to get tuned before i purchase your ecu tune, the person who dyno tuned my car checked my spark plug gaps and recheck my timing. i know FORSURE it wasnt wrong. my rings blews in the same week of the tuned installed. one more thing is my motor was completly stock and perfectly running good before i turbocharged it. | |
| | #17 | |
how much boost were you running? any spikes? how big was your intercooler? what injectors are you running with your enthalpy tune? there are tons of variables of what could of happened but i still stand by my tune i might have a few unhappy customers but i have hundreds who are happy and its just not right how happy people dont go on fourms like yourself to complain. glad your car is running good and you're happy. if you have anything else to say please take it to PM so we don't threadjack this guys thread OP call me 619-467-5446 if you need any help.
| | #18 | |
it was a stock wastgate and it wouldnt let me go any higher than 8 PSI, no spikes at all, and i had a GREDDY TYPE M FMIC again it was BRAND NEW! as of rite now i have tomei/nismo 740cc on built KADE i would of never complain on forums but then just had too because it really sucks when you spend up to $2,000 on parts and then one thing caused everything to go down the drain. just when i thought eveything went well it completly turned around. im not trying to put you out of business, just letting everyone how my experiance was. btw im not even sure if i still have your tune. again goodluck in your business (E-Mance) respond to me in pm | |
| | #20 |
| Zilvia Addict ![]() | |
| | #23 | |
| Quote:
adjusted the rotor and lined up perfect. Them I cranked but no spark this time. tried another coil and it started right up. now the bad part, tried starting again and now no spark again. I might be burning coils is this possible. Easy fix or not oem coil current but upgrading to msd. still need help. | ||
| | #24 |
| Premium Member ![]() | are your fuel lines backwards.... i know you said you got fuel, when i tried to start my sr it wouldnt fire, i had spark, fuel, compression, and timing, my problem was i had fuel, but no fuel pressure, it wasnt misting out the injectors, i swapped the fuel likes around and it fired up the first time...
__________________ 1995 240sx SE (current) |
| | #25 | |
| Quote:
not fuel just no spark.blew 2 coils just ordered bkr7e and msd blaster coil. Lets see what happens when i install these. only code i get now is 34 (detination)knock sensor bad? Still no clue why i blew 2 coils. Harness is untampered with.![]() | ||
| | #26 |
| Premium Member ![]() | bad grounds?
| | #28 |
| 'hood Garage ![]() | Everyone said timing so I'll leave that alone. I have an MSD coil got rid of the stock one during KA-T build. Did you use a spark tester to actually make sure your not getting spark? Do you hear the fuel pump prime before attempting to start? If it keeps turning over strong but not starting it wouldn't be a ground issue. BTW Running an Emance tune for quite a while with no problems at all.
__________________ ![]() ![]() It's never too early |
| | #29 |
| I checked all the grounds. Will look at the igniter, resister, and hook up new coil. Coil came in yesterday just waiting on new bkr7e plugs coming in today. So will this weekend and see whats up when i try to start it. ![]() | |
| | #30 |
| Here we go again... Installed msd coil...great Installed new plugs BKR7E...great and now lets crank it over.....result It had a rough start,idles like shit,I cleared the ecu for codes and intalled a new knock sensor cuz i was getting code 34 and it still will not idle on its own. It's running pig rich on 850cc denso injectors.help.. not happy with this mess at all. the timing is spot on. i'm fouling plugs at start up. way too rich. | |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/tech-talk/287104-help-new-build-wont-start.html | ||||
| Posted By | For | Type | Date | Hits |
| www.ka-t.org :: View topic - E-mance NEW 2-step Vid =] | This thread | Refback | 11-05-2009 12:00 AM | 11 |
