Old 10-25-2009, 02:05 PM   #1
S13Sr Transmission won't come off.
Im trying to replace the throwout bearing, but I can't get the transmission off. I have unbolted the slave cylinder, The starter, the driveshaft and all the bellhousing bolts. It will slide off a little bit then get stuck.
Ive tried lowering the front subframe, but I don't know how far it will go. My theory is that because I have solid motor mounts, the engine won't tilt and let go of the transmission.
Im stuck and the tranny is stuck. I will pay someone 50 bucks to come fix this.
All help is appreciated,
Jake
Jaketenpointo is offline   Reply With Quote
Old 10-25-2009, 02:27 PM   #2
ROIDMONKEY's Avatar
kinda have to loose the nuts on ur motor mount.. that way u motor tilt
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 10-25-2009, 04:05 PM   #3
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
You sure you got all the bolts off? Try pull and rock it up and down from the tail shaft. Just make sure somebody's ready to catch it when it does come off. Once its off, thats when the real fun begins. You'd have to play around with it and spin the housing to get it completely off since itll more than likely catch on the firewall.
Old 10-25-2009, 04:45 PM   #4
ecuastyle84's Avatar
Send a message via AIM to ecuastyle84
One thing I tried also is get pieces of wood and jack up the motor from the edge of the oil pan so you can get more tilt, also make sure your car is jacked up high enough so that you don't have to work in a tight space.
ecuastyle84 is offline   Reply With Quote
Old 10-25-2009, 04:50 PM   #5
slow92's Avatar
are you sure the top of the bellhousing isn't hitting the firewall. when I did my clutch I had to unbolt it, separate it from the block and then rotate it 180* so the top of the bellhousing wouldn't hit the firewall or trans tunnel
S13 Coupe SR20 400whp
slow92 is offline   Reply With Quote
Old 10-25-2009, 05:25 PM   #6
Martino's Avatar
With SR's, once it's slid about an inch or so from the motor you have to turn it so housing won't hit the firewall.
That's how it is with my 180 anyways :S
I'd assume it's the same for SR swapped 240's.
Shake 'N Bake
VisualSugar.com - Media and Design
Martino is offline   Reply With Quote
Old 10-25-2009, 06:32 PM   #7
VIPremium Member
S14_Kouki's Avatar
Who the fuck turns there tranny bang the shit out of your firewall
S14_Kouki is offline   Reply With Quote
Old 10-25-2009, 10:39 PM   #8
Yep its stuck on the firewall. Im gonna rotate 180* and try again. Then Im gonna bang the shit out of my firewall so it will be easier next time.
That or pul the whole motor/tranny.
This is probably the biggest pain in the ass ever. Worse than changing an alternator in an MR2......
Old 10-25-2009, 10:44 PM   #9
design240sx's Avatar
Trader Rating: (31)
just wiggle that shit out. just make sure you have room for you and the tranny when drop. just keep turning left to right while wiggling the tranny. just be carefully.
In the Zone...
design240sx is offline   Reply With Quote
Old 10-25-2009, 11:59 PM   #10
azndoc's Avatar
Loosen the motor mounts
use a block of wood and jack and jack it up the front of the motor
wiggle it out and done
The fun part is putting it back in.
GL
Old 10-26-2009, 12:08 AM   #11
hey this might be a stupid comment but did you take off the shifter lever. cuz if you didnt maybe its getting hung up. by the shifter. just a thought.
sidewaysonmy180 is offline   Reply With Quote
Old 10-26-2009, 12:45 AM   #12
Umm...people who didnt bang the firewall when they did the swap...
Old 10-26-2009, 03:13 PM   #13
pleasseeee dont bang the fire wall...
just loosen the lower engine mount bolts ( kinda pita) but make sure you leave the nuts on. then take a jack and small peice of wood and jack up on the front of the oil pan. This will tilt the engine more than enough to get the tranny off..
i like to take a nice beefy flat head and slip it in the crack between the block and trans and work my way around it while someone wiggles the hell out of the tail of the trans. works like magic every time
boostbyyou is offline   Reply With Quote
SEO by vBSEO 3.3.0
