| | LinkBack (1) | Thread Tools | Display Modes |
| Leaky Injector ![]() | ****DYNO SHEET 800hp full street sr20det s13**** Whats up guys, This is a good friend of mines car Mike at SDR Miami that we have been working on. Went to the dyno yesterday and pulled some new numbers 796hp and 578tq @ 7600rpm with 30 psi on e85. We are sure that we could get allot more but had a few issues we were dealing with like spinning on the dyno and boost controller shutting me down at 30 psi .. The car is still a full street car with a/c and p/s and is drivin every day... Vidz will be up soon and will link them once they are ..
__________________ "Your only as fast as your weakest part" |
| Sponsored Links | |
| | #4 |
| I <3 LIZMO ![]() | cool, i would like some more specs on the setup though. turbo,fuel,motor mods,etc. |
| | #6 |
| Leaky Injector ![]() | Theres alot more left in the car we stoped all pulls very early at 7700RPM. The boost controller limited us to only 30PSI. The car is also running pig rich. The turbo is a billet 6765 once we crank it up to around 45PSI we should see 900 RWHP.
| | #7 | |
| Leaky Injector ![]() | Quote:
E85 DPR ported head, Brian Crower 272 cams Sleeved block with all the goodys!!!
__________________ "Your only as fast as your weakest part" | |
| | #8 | |
Heres a small list... lol.. VID------------------------>>vid------------>>>>>>>>>http://www.youtube.com/watch?v=Ge15FEE5zMQ Block:SR20DET Redtop Weisco Pistons 88.5mm 9.0:1 Benson Automotive Custom Sleeved and O-Ringed Block Crower Billet Rods Calico Coated ACL Race Bearings ARP Main Studs ARP Head Bolts SDR Fulley Blueprinted/Balanced bottom End With Polished Crankshaft ATI Crank Pulley Moroso Oil Pan Stock Engine Mounts Greddy Style Pulleys Head: Full Race Head Ported & Polished with Coated Compression Chambers, done by Dan @ DPR Racing Full Radius Valve Job Apexi 1.8mm Head Gasket Jun Style Intake Manifold 80mm billett TB Greddy Cam gears Tomei Solid Lifters JUN Valve Springs JUN Titanium Retainers Jun Valve guides Greddy Rocker arm stopper Moroso Catch Can With -12 Lines BC in/ex 272deg Cams Turbo/Exhaust: Precision 6765 t/3 billet turbo Peak Boost Top Mount Turbo Manifold SDR Custom Intercooler pipes 24x12x4 FMIC Greddy Type-R BOV Apexi N1 3inch full Exhaust Turbo Smart 38mm Wastegate SDR custom SS down pipe Trans: Z32 TT 5speed with Mazworx adapt kit Single Pice Steel Drive Shaft Exedy Twin Disk Clutch SDR Custom Rear End With 4.08 fd Suspension: Tanabe Sustec Pro-Sevens Tanabe Teas Controller FOOTWERKS Rear Adj Arms Tien Tie Rods Tien tension rods SPATS Front And Rear Strut Bars Wheels: Work VS-XX 18x9 Front Wrapped with Perreli 245/45/18 18x10.5 Rear Wrapped with Perreli 285/35/18 Brakes: SDR Custom Front Brembo 4 Pot Calipers with 14" rotors 300zxTT Rear Brake Upgrade 300zx TT rear Crossdrill and Slotted Rotors Kevlar Brake Lines Fuel System: RC Engineering 1600cc Injectors Aeromotive full race Fuel Pressure Regulator Weldon 2025 race Fuel pump. RCI 12 gal fuel cell Custom fuel rail -10 fuel feed line from tank to rail ECU: Microtech LT10-s Stand Alone With X4 Ignitor Box Custom Wire Harness MSD Baster Coils x4 10.2mm Spark Plug Wires Cooling KOYO Radiator Flex A Light dual Fans Radiator Hoses SDR Custom Oil Cooler/Oil Filter Relocation Kit Interior: Custom Wrapped Seats AEM Wide Band AEM Boost Controller 10pt Roll Cage Built By Chassis Engineering PYLE Double Din Radio/TV JDM Digital A/C Controls Carbon Fiber Glove Box MOMO Steering Wheel Greddy Turbo Timer Optima Yellow Top With Trunk Relocation Kit Apexi EL Oil Temp Gauge Apexi EL Oil Press Gauge Apexi El Water Temp Gauge Exterior: JDM S13 Silvia Front End Swap Piggy Front Lip JDM OEM Side Skirts JDM Rear Valance JDM OEM Power Fold Mirrors Carbon Fiber Door Pillers Carbon Fiber Gas LID Orgin Style Tail Misc Modds: SDR Wire Tuck Shaved Body Line Blended Door Handles SDR Brake Line Tuck Pulledfenders Full jdm digital A/C Full P/S Last edited by sdrmiami; 10-21-2009 at 11:27 PM. | |
| | #9 |
| Leaky Injector ![]() | Yeah!!! Shit gets crazy real fast.
| | #10 |
| Zilvia FREAK! ![]() | What other mods are done? Bottom end? What cams/spring? Solid lifters? What kind of manifolds? EDIT: You added the list as i was writing this haha.
__________________ Picture Me Rollin' |
| | #13 |
| Zilvia FREAK! ![]() | So how high do you think you can rev it? What type of RPMs are those cams rated for? The power comes in so late, that it would really be nice if you could at least rev it to 8500 or 9K. What do you think is the safe limit and what is the weakest link that is keeping it at that limit?
| | #14 |
| Zilvia FREAK! ![]() | pretty fu*kin nuts... that sure will surprise some people.
__________________ Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
| | #15 | |
Built for 9500 but i never take it that high unless im doin top end. (z06 cough cough)...lol weakest link.. really dont think i have one and dont wanna find out... LOL | |
| Sponsored Links | |
| | #16 | |
| I <3 LIZMO ![]() | Quote:
i don't see any mention of that, unless that's your "custom" rear end. | |
| | #18 | |
| Zilvia FREAK! ![]() | Quote:
When I said weakest link, I meant what is the component in the motor that sets the upper limit on how high you can REV it? Also, just wondering how you can REV it to 9500 RPMS? Are those BC cams really safe to 9500 RPMs?
__________________ Picture Me Rollin' | |
| | #19 |
| Leaky Injector ![]() | Havent had any issues with the cams, they are actually not even dialed in yet. with all my Jun products,solid lifters and the fine work done by dan over @ DPR Racing in assembling the head it is solid. |
| | #20 |
| SLINKY + ESCULATOR = Fun Times ![]() | The problem with making an SR rev pass 9k is the oil pump cavitating. If theres no power being made pass 9k, theres no point of making it rev pass that.
__________________ |
| | #23 |
| 승리를 위한 남한 ![]() | that dyno sheet is fake. lol jk. awesome man, holy crap, numbers off the charts geez.
__________________ Central Texas Auto Forums NEED A COMPANY BANNER TO ADVERTISE YOUR SERVICE!? PM ME! ![]() R.I.P - Thomas Sane - Lorezno Ponce DeLeon - Maurice Moore - Jorge Lopez |
| | #24 |
| Leaky Injector ![]() | The power was still going up at the end of the pulls. Theres power to be made in the upper RPMs. We were just limited by stupid shit.
| | #27 |
| Leaky Injector ![]() | Mike doesnt build cars for autocrossing or drifting. We mailny do topend/ rollracing. Lets say your doing a 60ROLL drop a gear break boost the fuck out of it and your in powerband. We also having something to fix that lag!!! It comes in bottle!!!
| | #29 |
| Post Whore! ![]() | Good Game .
__________________ http://codysarem.wordpress.com/ |
| | #30 |
| VIPremium Member ![]() | Damn man awesome. Wheres the vids at?? |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/tech-talk/285625-dyno-sheet-800hp-full-street-sr20det-s13.html | ||||
| Posted By | For | Type | Date | Hits |
| MySpace.com - External Link Alert | This thread | Refback | 10-22-2009 01:05 AM | 1 |
