Old 10-11-2009, 07:04 PM   #1
Renelovesnike's Avatar
e-break line problem
i just did an s14 4lugg to 5 lugg and changed the rear caliper too. but i cant seen to connect the e-break line to the caliper either the hole is too far away to connect the bracket to the caliper or i take off the clip to the line and the bracket connects to the caliper, but the cable is too far to connect to the bracket!!!
sounds confusing!! i know
is there a way to connect it?? any tricks?? =] any help is helpfull and thanks in advance
Renelovesnike is offline   Reply With Quote
Old 10-11-2009, 07:10 PM   #2
^fraktal^'s Avatar
Trader Rating: (22)
*ebrake, 4 lug, 5 lug*
it sounds confusing because you typed it that way...what rear caliper did you swap to?
^fraktal^ is offline   Reply With Quote
Old 10-11-2009, 07:17 PM   #3
just the stock caliper its just my rear driver side was seizing so only need to change that one!
Old 10-11-2009, 07:19 PM   #4
^fraktal^'s Avatar
Trader Rating: (22)
did you compare the "new" caliper to your old one? obviously the ebrake cable worked with the old caliper right?
doesn't sound like the same caliper or something else is messed up.
Old 10-11-2009, 07:21 PM   #5
Shadowhunter's Avatar
Is the Ebrake up or down at this point? Stupid question, but you never know with some of these internets people.
Shadowhunter is offline   Reply With Quote
Old 10-11-2009, 07:25 PM   #6
negrosx13's Avatar
Send a message via AIM to negrosx13
problem solved^^^^...i dont think the caliper changed unless its s13 to s14 or vise vs.
i meant be wrong tho
negrosx13 is offline   Reply With Quote
Old 10-11-2009, 07:34 PM   #7
e break is down and that was a duh!!
and there the exact same thing its just i would have to force the hell out of it to make it fit!! (become hulk)
also when my old caliper was connected, where the two e-break cables connected to the e-break handle line (on top of the drive shaft) one of the cables seemed to be more pulled than the other and the looked like this ----/===
Old 10-11-2009, 07:36 PM   #8
negrosx13's Avatar
pics could help us??
Old 10-11-2009, 07:40 PM   #9
=[ dont have camera
Old 10-11-2009, 07:42 PM   #10
can an e-break cable get streched out?? cuz when my car was jacked up my rear driver side wheel was harder to spin freely compared to the rest!!
Old 10-11-2009, 07:48 PM   #11
negrosx13's Avatar
with the parking brake up??
Old 10-11-2009, 08:12 PM   #12
now that i put newer caliper on it seems the / has gone away (park brake up and down) but it might happen once i connect the wire to the bracket!!
so right now the bracket is connected to the caliper but the wire is not connected to the bracket!!
the gap is about half an inch to connect up!
Old 10-11-2009, 09:46 PM   #13
^fraktal^'s Avatar
Trader Rating: (22)
ok try this:
pull the parking brake up so you can access the adjustment nut. loosen that nut almost all the way.
now release the parking brake handle. you will have more slack to attach the 2 lines to the single parking brake handle line.
then double check that you can fit each cable to the calipers and mount them as they are supposed to.
does this fix your problem? if it does hooray and then don't forget to readjust the parking brake handle. tighten the nut. like 6-7 clicks when you pull up the handle should engage the parking brake.
Old 10-12-2009, 12:50 AM   #14
ill try that tomorow =] and i hope it works!! ran into a diff problem!!
since i couldnt figure out the rear i started on the front and got everything connected EXEPT for the nut on the steering rack/arm!! the nut tightens only for like one turn and then the whole thing spins cuz its on a bearing!!
any way to get this bolt on??
Old 10-12-2009, 12:55 AM   #15
also when i put the front caliper on i bleed it and pushed the piston in and then connected it to the hub, presed on the brake pedal couple times"i know theres still air in the line but i was bymyself so..." but then i went to spin the whole front rotor and it didnt move!! like the piston it pushing out to much!
Old 10-12-2009, 01:06 AM   #16
oh yeah if you guys are wondering y my steering rack/arm would be disconnected, is when i got my 5 lugg it came with under arms and "uh hum" newer tension rod's so yeah......
Old 10-12-2009, 01:14 AM   #17
^fraktal^'s Avatar
Trader Rating: (22)
why did you disconnect the tie rod from the spindle? that wasn't necessary...
well unless you have speedbleeders you pretty much need a second person to help you bleed the brakes. sounds like you're wasting your time, especially when you're going to have to rebleed them here shortly...why not just do it right the first time and be lazy?
edit: nm just read why you disconnected the tie rods...
OK learn the proper terminology of the suspension parts PLEASE, it's making it difficult to help diagnose your problems bro.
Old 10-12-2009, 01:38 AM   #18
ok sorry for this being so unorganized!!
and the ill get back at you with the e break problem after i try and fix it tomorow..
and im having trouble connecting the nut to the steering rod/spindle "dont know exact name" hhahahah
everytime i try putting the nut on it just turns the whole ball bearing!!! X[
Old 10-12-2009, 08:08 PM   #19
meh fixed the e-brake problem. just saif F*(K it and grew a pair and made it work =D
Old 10-12-2009, 10:03 PM   #20
projectRDM's Avatar
No one can help you if we can't read your posts. Learn how to type, spell, punctuate, and then call things by their right name.
Your posts look like a 3yr old with a seizure got hold of the keyboard.
FORMERLY R240NA
Old 10-13-2009, 12:30 AM   #21
Thanks for commenting on my nice writing, i now know that the tie rod end on the driver side needs to be replaced.
is that better? =D
Old 10-13-2009, 01:24 AM   #22
meh this ended BLAH how do u close a thread?
SEO by vBSEO 3.3.0
