Old 10-09-2009, 11:41 AM   #1
Banned from the Marketplace
rb25det s1 wont rev over 3k starts bogging and keeps shutting off
need help asap....car misfiring like crazy, cant even rev above 3k starts bogging and turns off at idle ......thanks
ka-t_180sx is offline   Reply With Quote
Old 10-09-2009, 12:08 PM   #2
Insanity240's Avatar
clean ur maf and disconnect your battery and reconnect it after about 5 mins try that first
Insanity240 is offline   Reply With Quote
Old 10-09-2009, 12:14 PM   #3
ill try that tonite after work...thanks
Old 10-09-2009, 12:21 PM   #4
get maf cleaner n not throttle body cleaner btw lol.
Old 10-09-2009, 12:55 PM   #5
where jsxrjordan????
Old 10-09-2009, 01:07 PM   #6
LAID OUT
MELLO*SOS's Avatar
Most likely MAF related, because you mentioned a 3000rpm barrier... Do as above, if that doesn't fix it, test continuity between all your MAF wires from the ECU connector back to the MAF connector to be sure there are no shorts.
Don't forget to check out the basics, it's never a bad idea to do a boost/vac leak check with a leakdown tester or DIY pressure tester! I think I have a write up somewhere here on that topic, search my name for more info.
S13 + S14 + LS400
^ click pic to visit Garage Vegas on facebook
MELLO*SOS is offline   Reply With Quote
Old 10-09-2009, 01:08 PM   #7
yokotavia's Avatar
Send a message via MSN to yokotavia
jesus...no search man?
clean your maf, check maf wiring/connector, after that possibly is a bad maf, so it will need to be changed with a good one
Tryin to help people out and I get hassled.
MERRY CHRISTMAS
yokotavia is offline   Reply With Quote
Old 10-09-2009, 03:07 PM   #8
eh?
wiring wiring wiring
rbforums.org RB oem parts/wiring diagrams /fsm's
537whp/404wtq RB25
eh? is offline   Reply With Quote
SEO by vBSEO 3.3.0
