Old 10-06-2009, 06:27 PM   #1
You got me runnin up the walls
zenki.life's Avatar
Send a message via AIM to zenki.life
key stuck in ignition
so i went to start my car today to see if the battery was dead....it was.
on top of that fiasco my key now seems to be stuck in the ignition. it still will turn to all the setting( on, acc, ect) however when you go to pull it out it will not release.
YES I PUSHED THE RELEASE BUTTON.
so are my tumblers all of a sudden worn out? and if so how do i go about replacing. i have never done this before.
thanks
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 10-06-2009, 06:29 PM   #2
In time-out for misbehaving.
EDacIouSX's Avatar
Send a message via AIM to EDacIouSX
thanks
GOOD LUCK!
i know for my car, 95 nissan, they stopped making keys not too long ago. i got a set that was suppose to be for my ear but ended up being the wrong last s14 set in stock... so good luck on getting a key set for your car! the whole set was about 200 for me...
Old 10-06-2009, 06:36 PM   #3
HYPNOTIK's Avatar
Was your car an auto and been swapped?
HYPNOTIK is offline   Reply With Quote
Old 10-06-2009, 06:37 PM   #4
VIPremium Member
S14_Kouki's Avatar
This happen to me once I just wiggled and pulled till it came out. Has not happen since. There might be something wrong with the release bottom.
S14_Kouki is offline   Reply With Quote
Old 10-06-2009, 06:44 PM   #5
We're watching you.
CrimsonRockett's Avatar
Trader Rating: (73)
Get the battery charged then pull it out?
-Angry Panda Fabrication -
Fixing iDesigns shitty work since 2008.
CrimsonRockett@blogspot
Need body work/paint? PM me.
Old 10-06-2009, 06:57 PM   #6
sil80 monster's Avatar
yep happen to me, battery was dead and the key wouldnt come out, charged the battery and it came out....hope that helps you
sil80 monster is offline   Reply With Quote
Old 10-06-2009, 06:58 PM   #7
For Automatic:
Is it in "parking"? lulz... usually ppl dont realize taht the car may be in drive...
Good Luck =]
s14savyChawlay is offline   Reply With Quote
Old 10-06-2009, 07:27 PM   #8
druthafoo's Avatar
Wow, I just read this in the driver's manual and someone needs the answer. Today is your lucky day, well I hope I'm right .
Anyways, around the key ring there's a plastic trim. Pop it off with a flat head or something and there is a metal piece wire/spring looking thing. I think if you fiddle with it, it'll manually let your key free.
If that doesn't work out, I'll go get my manual from my glove box. Lemme know suh!
***PM for Stereo Help***
Eclipse55090CrystalSSCS6SIMAG
druthafoo is offline   Reply With Quote
Old 10-06-2009, 08:15 PM   #9
Yes pull the ring out like druthafoo said. If you look where the push tab is, there is a red or orange (square I think ?) button. You press that and your key will come out.
Mine did that for a while and for whatever reason started working again. Hope this helps.
DRIFTING_SIL_EIGHTY is offline   Reply With Quote
Old 10-06-2009, 11:18 PM   #10
zenki.life's Avatar
yes it is. does that have to do with my problem? has it happened to you before? thanks
ok ill try that
Originally Posted by s14savyChawlay View Post
For Automatic:
Good Luck =]
look at my mod list and or post count. who in their right mind would have an auto 240sx! lolz. but yes thanks anyway.
im not that nubish
ok thanks again ill check tomorrow. ill see what happens
Old 10-06-2009, 11:25 PM   #11
zenki.life's Avatar
EDIT. i just followed what druthafoo suggested. AND THERE IT POPPED OUT! fiddled with it some more and it works fine now!
thanks so much guys for the quick suggestions. i appreciate it!
-adam
SEO by vBSEO 3.3.0
