| | #1 |
| In time-out for misbehaving. | Bolt on spacers ok so im rockin 16x8+10. i bought some 15mm bolt on spacers to let them sit nice. the stock studs prevent da rimz from fittin on, so im thinkin of shortening the studs. is this a good idea? anyone had similar problemz??? need suggestions |
| Sponsored Links | |
| | #2 |
| Zilvia Member ![]() | I just bought 15mill spacers, and have the same problem.. Searched around a bit, and seems like you can either A. Buy extended studs and get a slip on spacer B. Cut your stock studs. I think im gonna just cut my stock studs People said to put your lug nut on first, then cut it, then take the nut off so youll be able to put the nut on (cutting it might mess up the threads) |
| | #5 |
| motherfucker mike ![]() | you dont have a spacer, you have whats called a wheel adapter. if i were you, buy a quality hub-centric spacer from fred goeske (www.wheeladapter.com) and ditch the adaptors, just install longer wheel studs. ide avoid using a wheel adapter unless you need some SERIOUS space. and dont buy cheap shit, fred makes top dollar parts that are machined out of high quality metal. |
| | #6 | |
| Leaky Injector | get some spacers that require changing out the studs, rather then these bolt on kind. They are more of a pita to install, but you won't have this problem. I think Ichiba sells both now (v1 and V2) Quote:
(Don't mind the lug pattern in the pic.)
__________________ 2003 350z | 1995 Altima | 1989 240sx | |
| | #8 |
| Zilvia.net Advertiser ![]() | H&R or Eibach Hubcentric spacers FTW! I wouldn't gamble on anything that my safety rides on.
__________________ PERFORMANCE NISSAN IN DUARTE My Direct Line 626-739-1968 or TOLL FREE 1-866-211-7389 For All Your Nissan Parts Needs! 1434 Buena Vista St Duarte, CA 91010 Where the 210 & 605 Freeways meet, Buena Vista Exit! My Garage: 1990 Nissan 300ZX Twin-Turbo (modded weekend car) 2008 Suzuki GSX-R750 (Race/Weekend bike) 2003 Toyota 4Runner V8 Limited (Daily stock and boring) 2002 Honda VFR800 Interceptor V-TEC (Sport Touring Bike) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
