Old 10-03-2009, 04:26 PM   #1
jiggs's Avatar
high speed wobble?
what do i look for when theres high speed wobble? at first i felt it passenger front, so i rotated the tires to the driver side, now it shakes very little but still the steering wheel shakes at high speed but not as bad as before, so what do i look for? i assume balancing? and what else?
NIGHT WALKERS
jiggs is offline   Reply With Quote
Old 10-03-2009, 04:28 PM   #2
sil80 monster's Avatar
wheel bearing??
sil80 monster is offline   Reply With Quote
Old 10-03-2009, 04:33 PM   #3
lazysk8er2's Avatar
get your wheels balanced and check your front end for any play i.e. tierods wheel bearings anything loose or bushings worn out severly
Yea sure its a stock turbo...
lazysk8er2 is offline   Reply With Quote
Old 10-03-2009, 04:42 PM   #4
hub centric rings.
SidewayZ-s14 is offline   Reply With Quote
Old 10-03-2009, 04:45 PM   #5
SBCsx's Avatar
I use to have the same problem. I just replaced my whole rack and pinion tierods etc. Good luck.
SBCsx is offline   Reply With Quote
Old 10-03-2009, 05:19 PM   #6
240=180's Avatar
alignment?
Battlescars FTW
nor-cal240sx.com
240=180 is offline   Reply With Quote
Old 10-03-2009, 05:20 PM   #7
Ezel verkrachtende schijteter
!Zar!'s Avatar
Send a message via AIM to !Zar!
Wheelbearings, alignment, tie rids, tension rods, loose steering rack.
-=Mel=-
Old 10-04-2009, 04:38 AM   #8
jiggs's Avatar
thanks guys for the imput, also would a leaking power steering rack make the car have high speed wobble? just checking...
NIGHT WALKERS
Old 10-04-2009, 08:10 AM   #9
nathanong87's Avatar
from my other car....
if u jack up the car and can physically move the wheel (as in shake the wheel) , u have bad bearings. not only will it shake but u'll notice more camber in that wheel. Other things to check , like everyone has said, are alignment and/or worn bushings
nathanong87 is online now   Reply With Quote
SEO by vBSEO 3.3.0
