Old 09-23-2009, 12:32 PM   #1
SR Recirc hose
Im trying to recirculate my greddy BOV which is in the stock position (s14 sr). None of the places local to me have anything large and long enough to reach. What is everyone else using?
I tried to order some samco xtraflex or whatever, but toguefactory said theres a 5-7 week backorder...
ryebreadz28 is offline   Reply With Quote
Old 09-23-2009, 12:40 PM   #2
96Turbo's Avatar
go to the hardware store and buy some heater hose
96Turbo is online now   Reply With Quote
Old 09-23-2009, 01:00 PM   #3
Wont that kink? Would that make a difference?
Old 09-23-2009, 01:06 PM   #4
96Turbo's Avatar
well how long of a piece do you need to run? It usually comes on a roll, so it might have a tendency to kink.... but if you're using a piece under like 1.5 ft I think it would be ok. A slight kink is OK, as long as it doesn't block the airflow. There isn't a whole lot of airflow going through the hose, just make sure it isn't blocked completely.
Also...at my hardware store they had some reinforced/braided stuff that you see used for catch can setups. That might be better since it won't kind as easily. Good luck
Old 09-23-2009, 01:13 PM   #5
About 2 feet. If i can get away with a slight kink, so be it.
Old 09-23-2009, 01:18 PM   #6
96Turbo's Avatar
give it a try. the kink isn't going to do any damage. When the BPV opens up and pressurizes the line it will probably just blow the air right through the kink anyways. You could also try some powersteering line. I know that wouldn't kink, but it's going to be thicker and heavier.
Old 09-23-2009, 02:21 PM   #7
slider2828's Avatar
Kragen or something as for diameter and look for something with a bend... not hard
Turn and Burn!
SEO by vBSEO 3.6.0 PL2
