| | #1 |
| Zilvia Member ![]() | banjo bolts (block and turbo oil lines) Is there a difference between the oil banjo bolt going to the block and the one going to the turbo, I lost one of the bolts and need to get another one. Do they both have restrictors of just one? |
| Sponsored Links | |
| | #2 |
| Zilvia Addict ![]() | There is no such thing as a banjo bolt with a restrictor. A banjo bolt is a banjo bolt. Yes the coolant banjo and oil banjo bolt sizes are different. If you need the coolant banjo, I should have one. I don't think I have the oil banjo. Pm me if you want it. And are these stock lines or aftermarket lines you are talking about. Because you shouldn't need the coolant banjo if going to stainless lines. |
| | #3 | |
| Zilvia Addict ![]() | Quote:
but he garagelu is right, the size of the banjo bolt for the coolant going to the turbo (there are two of them, 1 in, 1 out) are completely different than the banjo bolt going into the block. the oil feed has a banjo bolt on the block end, and just a regular fitting attached to the hardline with a flare at the end of the line (Assuming you have stock lines) i have a bunch of the coolant banjos myself. | |
| | #5 |
| Zilvia Addict ![]() | |
| | #7 |
| Zilvia Addict ![]() | the oil banjo bolt restriction can only be seen if you look through the side oil ports. it can't be seen from the threaded end of the bolt because it tapers into a smaller port. since the oil comes from the block through the regular sized opening, then gets forced into a smaller and smaller chamber making better pressure. that kind of looks like the right bolt because of the zinc coating. I've rebuilt 3 turbos now and the coolant banjos never had zinc coating. |
| | #8 | |
__________________ Built 95' S14.... | |
| | #10 |
| I lost that same bottom oil banjo bolt going to the block..... I've looked everywhere for one. Even went to two nissan dealerships for grins and kicks.. All they could show me was a z32 bolt but couldnt tell me what size it was, i'm thinking of ordering it just to see. Can anyone direct me to somewhere to get one PLEASE. Its nissan part #16432-79E00 which is discontinued. Does any one know if #16432-40P00 off the VG30DETT z32 will work? Noone i can find in town has one in stock so i cant look at it Last edited by DrewWhite; 10-30-2009 at 08:35 PM. | |
| | #11 |
| Update! thankfully i found my banjo bolt, I'm noy sure it the z32 oil feed will work but i can tell you for sure its tread is M12x1.25, i forgot to measure how long it was but an inch or less. Also its oil restricted like the RH side of the vg30dett. If someone could verify it would be nice to know *update* just to let you know 16432-40P00 off a VG30DETT should work. Its the same M12x1.25 tread and oil restricted. ![]() Last edited by DrewWhite; 11-01-2009 at 09:59 PM. Reason: update | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
