Old 09-06-2009, 02:56 PM   #1
Jonnyblaze's Avatar
Timing chain(?) rattle
Hey guys, just finished my 5 speed swap and when I started the car I heard a terrible rattling from (seemingly) the front of the motor. Now, I've had this problem before and it wasn't as loud. The last time around I removed both timing chain guides and that fixed the problem. I pulled of the valve cover and chain cover and it looks like the right side of the upper chain is a little slack. The top and the left is fairly taught though.
KA24de, not terribly high in mileage. What I don't get is how it started making this noise over night. The only thing I did was swap the auto out. Thanks for the help.
'91 Hatch - Work in Progress
Jonnyblaze is online now   Reply With Quote
Old 09-06-2009, 03:02 PM   #2
Jonnyblaze's Avatar
Damn, just checked the lower chain and it looks like theres a ton of slack on the upper right sight just above the tensioner... Is that normal?
Old 09-06-2009, 08:19 PM   #3
JRas's Avatar
Send a message via AIM to JRas
usually it's just the chain rubbing on the guides
remove the upper guides
JRas is offline   Reply With Quote
Old 09-06-2009, 09:19 PM   #4
Jonnyblaze's Avatar
Like I said, I did that about a year ago.
Old 09-06-2009, 09:33 PM   #5
Stupid Hippies!!!
Tom25666's Avatar
one of my pulleys had fucked bearings once and the "expert" thought it was the timing chain. i figured it out by accident
-car idling funny? check the continuum transfunctioner
Tom25666 is offline   Reply With Quote
Old 09-06-2009, 09:53 PM   #6
Jonnyblaze's Avatar
Hmm, we did mess with a few of the pulleys during the five speed swap. I'll check that out, thanks. Any other suggestions?
Old 09-06-2009, 09:57 PM   #7
Sometimes the tensioners can get stuck, caused by gunk buildup from dirty oil. You could try to clean the upper tensioner, you can do it on but I'd pull it off to do it(to get a better clean). When I pulled mine off it was stuck!!
How many miles does your motor have? If your motor has higher mileage it will need a timing kit eventually.
KrazyS13 is offline   Reply With Quote
Old 09-06-2009, 09:59 PM   #8
Jonnyblaze's Avatar
Yeah, I actually pulled it off and cleaned it twice today. And the motor has 160k on it but it was an auto daily driven by a middle aged woman for most of it's life. The motor is pretty strong and pulls harder than most KA's I've seen.
Old 09-06-2009, 10:06 PM   #9
That motor will still need a timing chain kit regardless of who was driving it. At that high of mileage, your tensioners are for sure out of spec and weak. It might not be your existing problem, but it will turn into one if neglected. Hell, I just did mine at 144K and it needed it bad!! lol
Get you a mechanics stethoscope if you can track it down. They're pretty cheap at Sears and work wonders!!
Old 09-06-2009, 10:49 PM   #10
Jonnyblaze's Avatar
I guess you're right but if it was the chain why would it occur overnight? One day it's perfectly fine, then I do the five speed swap, start it up and it's rattling like ass.
Old 09-06-2009, 11:29 PM   #11
89_240jdm's Avatar
Trader Rating: (60)
Send a message via AIM to 89_240jdm
Talking
i Had the same problem i install my new motor and clutch and started to rattling noise ,,,,, but the oil light turn on and off ,,,,i turn it off and change the oil pump and the noise went away....and also i change the timing chain guides because one was stock,,,,,,,
before i but the motor i turn it on and i dint make the rattling noise it was fine ......
89_240jdm is offline   Reply With Quote
Old 09-08-2009, 07:10 PM   #12
im actually having this problem as well, did you find any solutions?
sydewayz is offline   Reply With Quote
SEO by vBSEO 3.3.0
