| | #1 |
| Leaky Injector ![]() | Hi I was wondering when using a 350z clutch with a rb20 flywheel are we suppose to use a 350z throw out bearing or a regular 240sx throw out bearing? Thank you. |
| Sponsored Links | |
| | #2 | |
| I don't like you or your mama ![]() Join Date: Sep 2002 Location: No, I do not have an opinion. Age: 30
Trader Rating: (5) | Throwout bearing as applicable to the transmission used is the way it usually is. I have the White Bunny setup in my car and that is what I did with no problems. I'm not sure how far from that what you're doing is, but I cannot imagine it being too too different.
__________________ Quote:
![]() "Ask PHLIP a question, ask me anything" | |
| | #3 | |
| Leaky Injector ![]() | Quote:
| | #4 |
| Zilvia Addict ![]() | Random Fact... The 97+ 240SX got the TOB sharing the same part number to that of a Z32, while the 96- got a diff part number. (info per my friend the parts manager at my local nissan dealer) I don't know if one is better than the other though... |
| | #6 | |
I used a 350z TOB and now I am having slipping issues on my brand new clutch. Guess I gotta take out the transmission again and stick a 240sx throw out bearing in there. | |
| | #7 | |
| Doctor Chips ![]() | Quote:
__________________ 06 Infiniti G35 Coupe 6 MT - Diamond Graphite/Stone 92 Nissan 240SX S13 Hatch GT2876R - Constantly tinkering and lots of garage naps... Safety Red/Gloss Black | |
| | #8 | ||
Trader Rating: (5) | Quote:
I'd also understood that the TOB was to be used based upon the transmission, and it so happened that the one from the clutch kit I used (mid-grade NAPA one) was identical to the KA one from my 1995 transmission anyway. I had not cared to look into THIS setup until this morning, and even then only did so to make sure the 24-splines was similar. I know nothing about the RB flywheel though, as this is the first time I had heard of it mentioned for this setup.
![]() "Ask PHLIP a question, ask me anything" | ||
| | #9 | |
| | #10 | |
Trader Rating: (5) | I did not use the Z33 clutch, I used the Z31/32 clutch, and the flywheel I used was from the 1993 D21 pickup, which has the KA bolt pattern because it has a KA as well. Usable exchange part numbers are named in the thread I linked in my first response in this thread.
| | #11 | |
.I also called competition clutch since they offer a 350z pressure plate with a 240sx clutch disk and they use a 240sx throw out bearing as well! which leads me to believe the issue HAS to be with the TOB as the only things that can make a clutch slip are the clutch assembly, the tranny, oil, or trany linkage which the TOB is part of. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
