Old 09-01-2009, 11:26 PM   #1
Rockda240's Avatar
Send a message via Yahoo to Rockda240
s14 Help!! rear hubs won't budge!!!
Ok, I removed the locknut, the 4 bolts on the backside, and tried using a hub puller but my rear hub just won't budge!!! Help please I already tried looking up the solution!
Rockda240 is offline   Reply With Quote
Old 09-01-2009, 11:30 PM   #2
palmdale_mob's Avatar
That happened to me when I was going five lug
I had to take out the whole assembly and throw it in a press, but before that try heating it up, or soaking in wd40
palmdale_mob is offline   Reply With Quote
Old 09-01-2009, 11:33 PM   #3
Shadowhunter's Avatar
An alternate rear hub removal solution for those stubborn hubs is to...
  • remove the four bolts on the back of the hub axle housing.
  • remove axle nut and washer.
  • unbolt the control arms from the rear suspension housing with the exception of the lower control arm...leave it bolted to the housing.
  • unbolt the rear shock from the housing.
  • lean the housing forward and remove the axle spindle from the hub.
  • at this point you should have the hub still pressed into the housing and the housing still bolted to the lower control arm.
  • lean the housing forward towards you, careful not to put too much stress on the ball joint.
  • get a large hammer (BFH) and distribute several well placed blows on the back of the hub while holding the housing with your other hand.
  • the hub should simply pop out.
http://en.wikibooks.org/wiki/Nissan_...lug_conversion
Shadowhunter is offline   Reply With Quote
Old 09-01-2009, 11:53 PM   #4
Sileighty_85's Avatar
OR
Leave everything on
break loose axle nut
thread all the way out until nut is flush with end of axle shaft
soak splines with PB blaster
take dead blow hammer
smack axle shaft until desired results are acheived
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 09-02-2009, 04:18 AM   #5
projectRDM's Avatar
Originally Posted by Sileighty_85 View Post
OR
Leave everything on
How does beating the shit out of the axle make the hub come off?
Take the axle out from the backside, then place an object against the back of the wheel bearing, preferably a piece of wood, something semi soft. Beat the shit out of that, the force will drive the bearing and hub assembly out of the upright.
FORMERLY R240NA
Old 09-02-2009, 09:20 AM   #6
Send a message via AIM to jholman05
I have never tried it but I have heard of people taking log chains and bolting them to the lug then giving it a flip of the wrist to give it that shock. For me I just used a BFH and a pipe so I could reach the back of the hub and still get a decent strike on the pipe.
jholman05 is offline   Reply With Quote
Old 09-02-2009, 11:06 AM   #7
haha I was thinking the Axle shaft was rusted inside the hub, causing the hub not to come off.
後輪駆動車1番
Old 09-02-2009, 02:39 PM   #8
essforteen's Avatar
or bolt your spare on and kick it until its loose, thats what i did and came right off!
essforteen is offline   Reply With Quote
Old 09-02-2009, 02:43 PM   #9
Domuhhhhhhhh
krisdeezy's Avatar
Send a message via AIM to krisdeezy
lol this sounds familiar, this happened with me i just connect the rotor back on but backwards. Put the lugs on and got a rubber mallet and hit the shit outta that !
92' 240sx ka-t
71' corolla 4age
72' rx-2 13b
www.myspace.com/krisdoma
krisdeezy is offline   Reply With Quote
Old 09-02-2009, 02:53 PM   #10
stinky_180's Avatar
mine was stuck too, this is EXACTLY how i got mine out.
ŞŦתٲКŷ180
Old 09-02-2009, 03:16 PM   #11
blackrms13's Avatar
damn this thread is gonna help me out on finishing up the rear 5 lug...lol
good shit..
91' 240sx Fastback
blackrms13 is offline   Reply With Quote
Old 09-02-2009, 03:31 PM   #12
hOngsterr's Avatar
mine came off with ease
89 FB DD/DELAYED PROJECT.
Old 09-02-2009, 03:38 PM   #13
clark's Avatar
take a midol or two, put some rocks in your purse, and have at it panzy mary.
clark is offline   Reply With Quote
SEO by vBSEO 3.3.0
