| | #1 |
| Leaky Injector | so in the last couple weeks i've been working on turboin my KA motor on my s14. list of major things I installed: -t25 turbo -turbo manifold -fmic -370 injectors -n60 maf So basically my problem is the car will not start unless I give it some gas. Once it's started you must hold RPMs or they will drop and car will die. While it's running I noticed there is fuel spitting out the tailpipe along with a lot of smoke. I've heard that with the N60 maf and the larger 370 injectors, a tune is not necessarily required. Is this incorrect? Is there anyone on here that runs a KA24DET without any sort of tune? Should I spend the money and buy an SAFC and wideband and attempt to tune it? Please any help is appreciated, I leave for school in two weeks and would love to take it with me. Thanks |
| Sponsored Links | |
| | #6 | |
| Leaky Injector | Quote:
ya I was going to try and run a blow through setup temporarily.. pm me a price for the ECU, kinda interested. | |
| | #7 |
| Leaky Injector | |
| | #8 |
| Leaky Injector | well i've done some research and A LOT of people end up having the wiring backwards on their MAFs. Tommorow I will try switching it and really crossing my fingers.. Also injector O rings will be replaced tommorow, I had one go bad on the first startup so I've decided I'll jus put all new ones in and lube them in engine oil ( i heard thats a good way to do it ). Will update tommorow |
| | #9 | |
| Zilvia Member ![]() | Quote:
my setup was exactly like yours but a stock maf can hold up no need to upgrade unless you have a t/t4 setup so suck in more air. but hey ppl have different perspectives anyway back to the point yes get a fuel management system apexi SAFCII or the NEOs or if your baller go to jim wolf technology and get a ecu tune to your setup. hmm as for the o-rings on the fuel injectors alot of ppl use vasaline hahah it works much better. turst me. good luck with your startup KA-T.org should have the numbers to insert into the safc or neo. GL again. keep us updated | |
| | #10 |
| Zilvia Addict ![]() | damn, i might go with the same setup too. but hopefully i wont run into any trouble. if i do looks like i'll have to do a ton of searching. heh. update us all!
__________________ Rust Loves Me. |
| | #12 |
| Deadpool is NOT dead! ![]() | The MAF is no way to tune your car at all, you have a stock ECU that thinks it's running a stock MAF, stock injectors, and a stock exhaust manifold. What kind of fuel pump do you have? Ghetto ass KA-T set ups is why people think the KA is such a shitty motor for turbo. |
| | #13 |
| Zilvia Addict ![]() | Also do not "attempt" to tune. Either do a lot of research so you know what you are doing, or pay someone to do it right. Buying an SAFC and getting a tune costs as much as a ROM tune, so ditch the SAFC. |
| | #14 | ||||
-MAF wires are backwards -Faulty injector O-rings or injectors themselves -People insert their injectors by screwing in the heads over them instead of twisting them in by hand, causing damage? -Coolant Temp sensor Quote:
and you smoke t28 SRs? how much boost you run? Quote:
as for the ghetto ass setup, it's really my first time turbocharging a car myself. I actually bought the car simply to learn more about cars themselves. The setup IMO is not that ghetto, I have the SR T25 turbo, turbo manifold, megan racing full 3" straightpipe exhaust, sr370 injectors, FMIC, n60 Maf, etc. I've seen setups A LOT more ghetto than that.. Ya, I have no experience with tuning. I know a local race shop that I could get it dynoed and tuned. Most likely I'll do that I just need to decide if I'm gonna go with a ROM tune or something like wideband & SAFC | ||||
| | #15 |
| Zilvia Addict ![]() | If you have a local place to get tuned, get it dyno tuned. If you know nothing about tuning, the purchase of a wideband and SAFC will be just a couple shiny lights for you. Not being rude, but your setup is ghetto. What is the point in installing all these parts when you don't tune. IMO, you took a step back from your NA KA rather than improving it. Also get a Walbro fuel pump, even on a basic setup. Im running 10PSI on my car. |
| Sponsored Links | |
| | #16 |
| Zilvia Addict ![]() | Yep id have to agree with everyone as well, you will encounter some problems along the way most of them pretty small problems. The tune is CRUCIAL without timing control your engine is toast. If i was you, and if i were to do it my ka-t again. I would save up for all new stuff and not cheap out on things. It will save you alot of headaches down the road trust me. |
| | #17 | ||
and i agree with you I took a step back from NA but all i'm waiting on is ultimately a tune. Quote:
| | #18 |
| Zilvia Junkie ![]() | Even if you get the car running right you still need a chiped ecu your stock ecu's timing map is tooo aggressive for turbo you motor will not last!!! You can run 15deg. btdc timing but still your motor wont last I recommend taking all the turbo parts off your car and do more research! Ka-t.org is your friend!! Im serious And im sure you might have a vacuume leak!!!!
__________________ |
| | #19 | |
| In time-out for misbehaving. ![]() | Quote:
You cannot install larger injectors and MAF without using some sort of Engine Management System to tune for these MASSIVE adjustments... This is your problem. Please invest in an AEM standalone unit and then take it a registered Tuner / Dyno Shop to have tuned properly Do not buy the S-AFC it is a total waste of your money. If you have more questions on why I can tell you in every technical detail via PM. | |
| | #20 |
| Leaky Injector | Todays Update: So I pulled the injectors yesterday and took a look at the O-rings. Two of them were garbage as you can see (bottom two) ![]() and i also notiuced one of the brass buttons on one of the injectors was missing so I picked another one up this morning and put all new O-rings on all of them. Heres a pic of the injector with missing brass button (left) next to the good one (right) ![]() I also put in new spark plugs: the others were toast and seemed like they haven't been changed in awhile.. Also messed with the MAF wiring and that didn't do anything.. i think it's pretty obvious I need a tune.. I've already decided I'm gonna get an ECU tune of some sort. I know some one selling an enthalpy for pretty cheap thats already tuned to my setup. Well i talked to the seller on the phone and it was tuned for a t3t4 turbo with 370 injectors and n60 maf, but he says it will work for my t25 with 370s and n60 maf. Is this accurate? I've heard the enthalpy tunes are pretty good ones and the price is decent. Let me know, any feedback is appreciated |
| | #22 |
| Zilvia Addict ![]() | I'd honestly go with JWT and do it right the first time. or fly steve shadows over to do your standalone lol but seriously. JWT. buy a used ka ecu that's already been tuned by JWT off of someone for 250 and then spend 100 getting it reflashed. cheaper than spending 550 on a newly tuned ecu.
| | #23 | ||
| | #24 | ||
| Deadpool is NOT dead! ![]() | Quote:
When I am talking about a ghetto set up, I'm talking about the fact that you don't have any tuning or anything to make it run correctly, you're using the parts on the car hoping that they'll equal each other out. Quote:
As for the plugs, what plugs did you get? I got BK7RE when I finally noticed my spark plugs were the reason my car ran like trash. It made a world of difference. If that guy is telling you that Enthalpy can tune for your set up, he's lying to you. I had an N60 MAF, 370cc inj and enthalpy does NOT tune for that. So I had to upgrade to some 450cc inj and a Z32 maf. | ||
| | #25 | |
Here is the link to the guy advertising that the enthalpy tune would work for a t25 with 370s and n60 maf. check it out for yourself.. if its a scam thats pretty shady..Enthalpy's making advances pretty fast, maybe they jus didnt make a tune for 370s and N60 maf when you were looking for a tune? KA-t parts *NEED MONEY BEFORE SCHOOL SALE!* I want to get an ECU tune before I go back to school. I'd like to take the car but I don't want to spend 200$ on a useless ECU thats not even tuned for my setup. Let me know what you guys think... | |
| | #26 |
| Deadpool is NOT dead! ![]() | You should just contact Enthalpy yourself, although he is usually hard to get in touch with. If you want to know what he will and won't tune for contact him instead of going through hearsay. I got my tune almost a year ago now, but I doubt he's changed his mind. |
| | #27 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
