| | #4 |
| Post Whore! ![]() | It looks like you're missing the bleeder bolt for the clutch slave cylinder. You can get a replacement one from just about any auto parts store. It's the same size as your brake bleeder bolts. |
| | #5 |
| Post Whore! ![]() | You've lost us. The slave cylinder has both a banjo bolt and a bleeder bolt. You must have both, not using a bleeder bolt, all the fluid will leak out. Not using a banjo bolt, the fluid can't even get in.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #7 |
| Premium Member ![]() | |
| | #8 |
| Leaky Injector ![]() | the bolt holding the fluid line on is called a banjo bolt. It should have a hole in it to allow fluid to travel through it, just like a brake line. then you should also have a seperate bleeder which is basically a bolt with a passageway all the way down the shaft that will allow you to bleed it, also just like brakes. do yourself a favor and before doing anything more to your swap or more mechanical work go get yourself a book on the subject and sit down and read it. |
| Bookmarks |
| Tags |
| 240sx, bolt, clutch |
| Thread Tools | |
| Display Modes | |
