| | #1 |
| S14 Dash Removal I was wondering.. When I remove my dash, does the passenger side air bag come out with it, or is it two seperate pieces? Basically I want to put in a new dash (mine is cracked all to hell) with a dash out of a parted S14. Their passenger air bag deployed so I will be leaving mine intact. Suggestions? Thanks in advance! AzBrewsky | |
| Sponsored Links | |
| | #4 |
| Zilvia Member ![]() | I took mine off without a FSM. Just take your time and check everywhere and behind everything for botls. They will surprise you where they are located. Esp the two at the top of the dash and the one behind the passenger side air vent that connects to the door. |
| | #6 |
| Post Whore! ![]() | If you don't mind the big, gaping hole left from the bag going off, it's fine.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #8 |
| Hey since we are on this topic,I need help to,on how to take out my s14 dash.How many bolts exactly are there to take out?I research and didn't find any results I really need advise on this.Will i really trigger the airbag if i ain't careful? ain't there like a harness u could detach so the airbag don't pop out? sorry guys I'm a to this. | |
| | #9 |
| Zilvia Addict ![]() | Just disconnect the battery, and your fine. Pop off all the plastic pieces and remove the screws in the vent area's. Its so easy its stupid. I've done it without even using the fsm. Just start doing it and you will be fine. Takes like 3 hours if your slow and taking your time.
__________________ S14 Kouki - any wiring guru's coming to vegas? |
| | #10 | |
| Quote:
| | #12 |
| Leaky Injector ![]() | Brewsky. S14 dashes are super easy to remove. I've removed mine 3 or 4 times and it takes me less than an hour. Start by removing all the plastics around the steering column then drop the steering column with the two 12mm bolts then take out the gauge cluster. Then just remove the radio and a/c stuff from the center and from there its really easy |
| | #15 |
| The Cook ![]() | disconnect the battery... |
| Sponsored Links | |
| | #19 |
| Zilvia Junkie ![]() | Well I can't say for sure, but I do know that I have taken out the dash, left the air bag there, turned on the engine, drove down the block and back. The aig bag did NOT deploy. If there is no problem with your car, I would highly doubt that the air bag will go off. |
| | #20 |
| Post Whore! ![]() | You're the worst fucking reader ever. Unless you turn your key on then beat the control unit with a hammer, how in hell do you think the bag will trigger?
| | #21 | |
| Quote:
| | #22 |
| Post Whore! ![]() | Fuck off. You're the same dumbass who assumed bolting wheel adapters to your existing hubs required new rotors of a completely different bolt pattern. It's readily apparent anything you attempt to do will be wrong anyway. Assuming you'll set off the airbag by just removing the dash is just plain retarded. I didn't think people could be that stupid.
| | #23 | |
| Quote:
but like I said I'm a ,so maybe your the dumbass for not reading Either way fine u win just to make u happy ![]() | ||
| | #24 | |||
| The Cook ![]() | Quote:
LOL Quote:
ur a dip shit for being a smartass to someone who doesnt typically just give an answer...have fun popping ur airbags...i have a dash for sale if u need it...and an undeployed airbag LOL Last edited by DALAZ_68; 09-02-2009 at 01:46 PM. | |||
| | #25 | |
| Zilvia FREAK! ![]() | Quote:
he has probably forgotten more info on 240's then you'll ever learn.
__________________ | |
| | #27 | |
| Zilvia Junkie ![]() | Quote:
doesnt matter if he knows absolutly everything about all and every 240 ever made on the entire planet..... if he is too much of an a@@hole to share it!!! RDM used to be a lot cooler of a person if you ask me. what happened did you get married or divorced?
| | #29 |
| The Cook ![]() | i just wanna laugh when his shit does pop... you cant read the information thats already posted, and im sure u dont know how to search info properly... |
| | #30 | |
| Quote:
and why the hell did u butt in the conversation?For a 23 year old guy u sure act like a 15 year old wuss. | ||
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
