| | #1 |
| Zilvia Member ![]() | KA-t trouble I just finish timing the motor and now its cranking and wont turn over. Im almost 100% sure the car isnt getting spark. I change my plugs since they were filled with fuel. I also cleaned my distributer. Any other reason the car isnt getting spark. Also the car was starting before I did the timing. its a 91 ka-t thank guys |
| Sponsored Links | |
| | #3 |
| Zilvia Junkie ![]() | check all of your injectors make sure they are not leaking fuel when the fuel pump is priming TDC the motor and make sure its on 1st on the distributor check the power transistor on the ignition coil make sure ohms is on spec and make sure ur grounds are proper good luck
__________________ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
