| | #1 |
| Zilvia Member ![]() | Disabling knock sensor. Keeping knocklite Im pretty sure my knock sensor is picking up fasle knock so I want to disable it. But I want my knocklite to work still. Ive heard about the 1 megaohm resistor, but im not sure exactly how it works. From what ive gathered the resistor has to go in between the signal wire which goes to the ecu and a ground. Like this ground---------resistor----------knock sensor pin on ecu So can I just cut the knock sensor wire right by the ecu and put a resistor in between a ground and the ecu. Then leave the knocklite wire hooked up the the original knock sensor wiring. This is on an s13 ka by the way
__________________ '91 240sx hatch: ka-t t3/t04e '93 240sx coupe: stock dd |
| Sponsored Links | |
| | #2 |
| I'm old enough to be ur daddy ![]() | You can turn it off on your bin... But that is the correct way to hook it up. Do not trust the knocklite without a set of headphones or chassis ears or something to listen to it.
__________________ MY FARTS STILL SMELL LIKE C16 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
