Old 05-28-2009, 02:35 PM   #1
Violent Running Asshole
Om1kron's Avatar
Send a message via AIM to Om1kron
Removing the Vent Canister on the rear of your S14
I don't know if an s13 has an emmisions vent can at the rear, i'll safely assume it does. I want to remove this with no possibility of it backfiring on me say (fire) for instance.
I have this line in my engine bay that runs back to the vent can that used to get vacuum from the EGR on the KA, now that I have an SR20 and no black can, there is no reason for that line to come into my engine bay.
I will post pictures, of the whole process and whats needed, but I would love some advice. Searching for any posts related to this as I hit submit.
here's one thread.
EVAP removal! NEED HELP
W.E.
Wayne T. Edwards
Violent Running Tribe News Blog <---Peep This
Old 05-28-2009, 02:40 PM   #2
s14unimog's Avatar
Send a message via AIM to s14unimog
I just pulled the hose and left the hard line. I haven't investigated where it leads but to my understanding its the way Nissan chose to evacuate the fumes from the tank... I'd like to follow along...
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 05-28-2009, 02:50 PM   #3
Om1kron's Avatar
I just don't want gas vapor building up in my engine bay. Is my point!
Wayne T. Edwards
Old 05-28-2009, 02:58 PM   #4
s14unimog's Avatar
I hear that, but mine isn't bad or there at all... If you do remove the hard line lets see some pictures! Like I said, I'll follow along
Old 05-28-2009, 06:25 PM   #5
Still Useless
alzahakar's Avatar
I believe you can cut the hard line from the tank and just run some rubber hose into a frame rail. Think that's how older cars are setup anyway.
alzahakar is offline   Reply With Quote
Old 05-28-2009, 07:11 PM   #6
Om1kron's Avatar
yeah from the looks of it, there really is no way to remove the hard line without dropping the tank, so if I cut the hard line right above the gas tank it or mid rail, I can prevent water from going into the line because it will still be pointing down.
sweet.
Wayne T. Edwards
Old 05-28-2009, 07:32 PM   #7
WoolyS14DET's Avatar
Send a message via Yahoo to WoolyS14DET
I took mine out a long time ago and have never had any problems at all
Originally Posted by DTC SUPERSTAR View Post
I love milk duds and penis.
WoolyS14DET is offline   Reply With Quote
Old 05-28-2009, 07:43 PM   #8
CBS
charcoal box - vent canister same thing?
so removal of the hardline and rubber hoses plus the rear box won't affect what exactly?
CBS is offline   Reply With Quote
Old 05-28-2009, 07:50 PM   #9
AFC #1
S14DB's Avatar
OBD I cars have the can in the front. The hardline comes right from the tank.
OBD II cars have the Can in the rear. The hard line goes to a solenoid on the can.
Do you have a 95 or 96+?
Comments should be taken as Opinions not as Statements of Fact.
Old 05-28-2009, 08:53 PM   #10
Om1kron's Avatar
I have the can in the back (no homo) but I took the car off of the stands, I don't have anything to cut the hardline and you gotta drop the tank to get that damn line out. w/o cutting it.
Wayne T. Edwards
Old 05-28-2009, 09:17 PM   #11
AFC #1
S14DB's Avatar
No you don't. There shouldn't be any gasses coming up if you have the rear tank. Rubber soft line goes from the tank to the box. Rubber line goes from the box to the hardline in the wheel well.
To remove:
Behind the passenger side wheel is the Box.
Unbolt it and let it hang.
Unplug the 3 connectors and feed them back into the trunk.
Pull the rubber hose off the hardline and cut the rubber line off from the tank.
Old 05-28-2009, 10:00 PM   #12
CBS
To remove:
is there any downside from doing this?
since its just a un used piece
Old 05-30-2009, 04:11 AM   #13
hpipro4's Avatar
Trader Rating: (39)
isnt the charcoal canister part of the visual inspection during smog? cause its shows it on the V.E.C.I. label.
hpipro4 is offline   Reply With Quote
Old 05-30-2009, 05:15 AM   #14
Om1kron's Avatar
Not the one by the rear bumper unless they actually get under your car and check that too.
Wayne T. Edwards
SEO by vBSEO 3.3.0
