Old 05-27-2009, 02:04 AM   #1
Send a message via AIM to kenshinS14sks
engine knock q sr20 blacktop
Subject:
SR20DET s14 black top (no internal mods)
basic mods - blitz fmic, apexi n1 exhaust, stock turbo, blitz bov
on the apexi power fc there's a feature in which you can gauge your engine knocks
i dont hear any noticeable knocking under idle or fot but on the fc commander it says there are. . . so~
what would be considered a safe range under normal driving versus fot?
kenshinS14sks is offline   Reply With Quote
Old 05-27-2009, 10:59 AM   #2
slider2828's Avatar
PFC knock sensor is a POS.... You gotta get a wideband, but knock for stock should be under 40 max knock.... Anything more you are really detonating. Check your spark plugs...
Turn and Burn!
Old 05-27-2009, 11:17 AM   #3
You love to hate me!
landins13's Avatar
^^^ pretty much
turbo lag is my way of giving you a head start !!NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 05-27-2009, 01:41 PM   #4
djcobra's Avatar
I have to agree with slider2828 also... as long as your car is stock ie, internals, turbo etc... then knock levels should be below 40. However, if your car has upgraded internals ie, cams, valve springs, head gasket, turbo, etc... then knock readings will be wierd or high even though you don't hear any knock.
My knock readings are stupid, on idle i get about 1-5 knock, on light load/cruise i get about 25-30 and if i start to give her it can go high as 60 yet there is no audible ping/knock. Car has been dyno'd with good AFR also with a conservative tune.
Mods include, HKS Step 2 cams, 256in/264ex, Apexi head gasket, HKS Valve Springs, Retainers, GT28RS, HKS 555cc injectors bleh bleh bleh.... RPS Max Street clutch.
Heck, even a clutch could be picked up as knock, due to its harmonic crap... lots of variables especially if your not stock like me.
Anyawys, hope this helps.
Steve.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO
djcobra is offline   Reply With Quote
Old 05-27-2009, 01:49 PM   #5
slider2828's Avatar
Yup I have about the same, but like 15 on light cruise and 60 or 70 on load, but I think that is cause of the tranny, but my motor is built so 60 max knock ain't so bad.
Turn and Burn!
Old 05-27-2009, 02:23 PM   #6
thanks a lot guys this really helps. . i know im running lean but one time i saw that my knock was upwards at 86 and my jaw just =OOOO and ive been meaning to get my engine tuned so hope that'll do the trick
Old 05-27-2009, 03:28 PM   #7
slider2828's Avatar
2 things you can do, dial back timing at peak knock / power which is around 4500- 5500. I think that is where you knock is.... Sometime enriching the mixture does work either....
Turn and Burn!
SEO by vBSEO 3.3.0
