| | #1 |
| d r i f t w o l r d ![]() | engine misfiring when hot don't have much time to explain it have to go take a final but when i got the car in october it did this too then it went away once winter started now today it came back seems to only happen when 70+ degrees out or the engine is really hot bogs a bit at idle and misfires all the way through at operating temps i thought it was a damaged boot before because i had a bad valve cover gasket which was damaging it and causing the spark to arc early replaced that it wasn't doing anything STUPID anymore but now its back possible CTS? don't think its fuel injectors because it was running fine in the winter thanks for any help you can give me i can provide more info later today
__________________ It's like going crazy when you're already nuts. driftwolrd | blog | stickers | youtube |
| Sponsored Links | |
| | #2 |
| d r i f t w o l r d ![]() | nothing??? wow okay new question how the fuck can i get the rubber tip of the boot out that is stuck in my cylinder 3 tried fire and screwdriver
| | #5 |
| d r i f t w o l r d ![]() | s13 ka24de i took out all the plugs they all appear fine i looked at all the pistons 1 2 & 4 are dry but 3 looked black and wet does that mean that cylinder 3 is the one that is misfiring?
| | #7 |
| d r i f t w o l r d ![]() | it could also be my third ignition wire too if that was bad i would still get the wet and black cylinder right?
| | #9 |
| Its all the governments fault. ![]() | If the plug wire on cyl 3 was bad, wouldn't the plug be wet? |
| | #10 |
| d r i f t w o l r d ![]() | steve told me that it makes a circuit so the injector is probably bad going to test it with an ohm meter ryan you have any extra injectors laying around hahha
| | #11 |
| d r i f t w o l r d ![]() | pretty sure third injector is out i unplugged all of them and nothing happened when i took out the third same thing happens when i take out the third plug nothing and the top of the piston head is black and wet doesn't really explain why it only started happening when it got warm out ?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
