Old 02-01-2009, 05:53 PM   #1
MrFixIt's Avatar
Welded Dif. Will It Hold? PICS
Just picked up this welded diff. Cracked it open and had a look at the welds. Never ran a welded before, but I know that if the welds aren't good/strong enough it can break and cause problems. Here's a pic...
Click the image to open in full size.
Do you think these are beefy enough, or should I go over em' again with another bead?
Thanks in advance.
MrFixIt is offline   Reply With Quote
Old 02-01-2009, 05:59 PM   #2
That's kind of a crappy pic, but it looks like a welded diff
It could be better, and it could be a lot worse.
I would worry about it.
alexander500 is offline   Reply With Quote
Old 02-01-2009, 06:00 PM   #3
BillWatcher's Avatar
If you already have it open and you have a welder why not be safe and throw some extra love at it?!
I am tech A AND tech B!!
BillWatcher is offline   Reply With Quote
Old 02-01-2009, 06:04 PM   #4
bejota180sx's Avatar
people learn MACRO you know the little flower thingy on your camera...
but it does look like you could do with a bit stronger weld... is it because of the picture or do you have metal shavings and stuff there by the gears? or is that the fluid making it look like that?
ziptiedpanda.blogspot.com --> personal blog
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 02-01-2009, 06:07 PM   #5
Looks as if its spatter from the weld, never hurts to throw a few beads on there, i would those look small and week, clean the spatter up around the gears and such to, dont want that to get in the bearings and make a whinning noise...
1995 240sx SE (current)
Ceepo is offline   Reply With Quote
Old 02-01-2009, 06:09 PM   #6
MrFixIt's Avatar
Yeah, it's a camera phone. Sorry, only thing I've got...
That's primarially the fluid. When I drained it though the fluid was reeeeeally dark, and looked like it was filled with a mild/moderate ammount of metal shavings. As was the magnetic drain plug.
Just looking for some suggestions. I know I've seen pictures of other welded diffs with beads twice this big. Only reason why I ask.
Old 02-01-2009, 06:25 PM   #7
s13_kidd's Avatar
noooo
looks like you need to weld it a little more
11/88 - july 02, 2009. i miss you two-tone
s13_kidd is offline   Reply With Quote
Old 02-01-2009, 06:28 PM   #8
if it has shavings, i think it would be good if you cleaned it out and took it someplace so they sand blasted it to clean up the spatter and all that... but get it welded again first... better safe than sorry...
Old 02-01-2009, 06:52 PM   #9
like everyone else has said might as well throw another bead on it while its open and make sure you get the slag cleaned out of it before running it. Oh and have fun in the rain its a shit load of fun.
Banegraphix is offline   Reply With Quote
Old 02-01-2009, 06:59 PM   #10
hotlavaflow's Avatar
Send a message via Yahoo to hotlavaflow
I just did mine and the welds were def beefy. I would go over that again I wouldn't trust it.
hotlavaflow is online now   Reply With Quote
Old 02-01-2009, 07:02 PM   #11
MrFixIt's Avatar
Thanks for all the input guys.
A buddy of mine has a little flux-core welder. I'm gonna see if he wouldn't mind going over em' again real quick.
Haha, yeeeeeeeeah. Welded w/ 195's should be interesting.
Old 02-01-2009, 07:12 PM   #12
BoostedCoupe's Avatar
i would weld it up some more it that was me. When i had mine welded up i got the whole middle section full of weld, when you look down at my spider gear's you cant see therw them its solid, basically even if my welds break the gears will NEVER be able to spin like they are suppouse to be.
Originally Posted by cocainewhite240 View Post
weld more........be safe
This made me laugh, be safe in a welded diff thread.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 02-01-2009, 07:24 PM   #13
gotspins13's Avatar
Send a message via Yahoo to gotspins13
ya when i welded mine i didnt just weld the sides, i welded the whole centers and everything so it was completely solid
gotspins13 is offline   Reply With Quote
Old 02-01-2009, 07:48 PM   #14
DriftMUH's Avatar
yea man iono that might hold but to be safe id weld the gears to the side walls on both sides
nothing wrong with a little overkill
"Im invisible and impossible to touch" ~Mr. Lif
DriftMUH is offline   Reply With Quote
Old 02-01-2009, 09:53 PM   #15
ATLspeed's Avatar
weld some more in there...i busted 2 diffs with welds like that on my KA with just I/H/E lol. its scary as hell when it blows on you cuz you just hear a "CLUNK" and your like "wtf was that?!" then you find out the hard way that you are truely a one wheel wonder when the gear is only turning one axle
"Koukimonster139 - hes gonna have nightmares of you ThatGuy
with a combat knife screaming:
why do you need a 5th tow hook!?!?!"
Racepar1 - To be a good mechanic you need to be able to take the car apart with your eyes before you turn a single bolt
ATLspeed is offline   Reply With Quote
Old 02-24-2009, 12:01 PM   #16
MrFixIt's Avatar
Well, little update.
I had my buddy weld it up a some more, but we used a cheap-o fluxcore welder. Slag got everywhere. I tried as best I could to clean it all out, but I'm pretty sure some still got in the bearings. When driving now, it makes a semi-audible whining noise from the diff. It's not noticable with the windows down, but with the windows up and the radio off, you know it's there.
Also, the tire squealing. Holy shit hahaha. I park in a parking garage and I set off a car alarm with the tire squeal haha. I switched to some wider / better quality tires though and the squeal was cut more than in half.
Ran it at my first event ever and man, it's 10 times easier to swing that back end out than with the open.
All in all I'm really happy I did it. The car feels so much more solid. The wheel hop going around corners isn't even that bad, but I've yet to take it out in the rain.
Old 02-24-2009, 08:46 PM   #17
Send a message via ICQ to Syncade
You're silly
rb neo>sr
s14>s13
Syncade is offline   Reply With Quote
Old 02-24-2009, 08:58 PM   #18
HPballer76's Avatar
Originally Posted by Syncade View Post
You're silly
this made me lol...
HPballer76 is offline   Reply With Quote
Old 02-24-2009, 09:01 PM   #19
MrFixIt's Avatar
You're silly
Haha. True story.
Old 03-03-2009, 03:53 PM   #20
Send a message via AIM to neukin
Looks like im too late..
Thats CRAP redo.. like this, dont just cake metal in there awh!
Here is a picture, its done very very well along with a few tricks to make it even stronger.
In fact if you want me to do it... $55 with core or $85 no core, ship included. No drive gear attached.
Funny when i busted my open diff unwelded the drive shaft just spun and made awesome noises... no wheel moved anywhere.
-Alex
Neukin Motor Development llc
399 River Bend CT Fort Wayne IN 46803
www.neukin.com
neukin is offline   Reply With Quote
Old 03-03-2009, 04:17 PM   #21
S13 curtis's Avatar
you need to get a diff from taftboy on florida drift. people have beat them to shit for 2 yrs and still never break.
its $30 bucks and your open diff.
S13 curtis is offline   Reply With Quote
Old 03-03-2009, 04:25 PM   #22
spacedog's Avatar
Send a message via AIM to spacedog
gusset plates do wonders
spacedog is offline   Reply With Quote
Old 03-03-2009, 09:46 PM   #23
Location: Pomona, CA (2 houses down from the dead body)
Send a message via AIM to Soooshi
or, if you want safety in terms of many happy users, not ONE has broken, blu808, aka Luke, aka WizardSleeves. haha.
<imgsrc="http://img134.imageshack.us/img134/6123/siggyx.png">
Soooshi is offline   Reply With Quote
Old 03-03-2009, 10:10 PM   #24
Otto347's Avatar
I welded mine like neukin, made two .250" plates and went to work.
silviav8.com
Otto347 is online now   Reply With Quote
Old 03-04-2009, 04:09 AM   #25
s13dan's Avatar
Gussets and laying down some good welds. Shit cant be broken.
89 FB #933-hot rod///91 coupe #130,603-dd
s13dan is offline   Reply With Quote
Old 03-04-2009, 10:29 PM   #26
-Alex
That sure isn't going to break......
Jmac39 is offline   Reply With Quote
Old 03-07-2009, 04:36 AM   #27
We manage to break everything so we try to make it better, failure is success.
www.neukin.com
Old 03-07-2009, 10:24 AM   #28
drifterken's Avatar
Send a message via AIM to drifterken
screw welded... thoes things are weak sauce... buddy had it in his s14 went drifting for 3 days on it and popped a whole in his casing. if anything weld the SH*T outa it..
drifterken is offline   Reply With Quote
Old 03-07-2009, 10:37 AM   #29
ZX88's Avatar
your going to want to weld that thing alot more if you want it to last.
BATTLE-HATCH 5000
Old 03-07-2009, 11:13 AM   #30
the steel pumpkin cracked?
www.neukin.com
SEO by vBSEO 3.3.0
