Old 01-02-2009, 08:32 PM   #1
Bigsyke's Avatar
Exhaust studs. Water jacket?
Anybody know how much depth I have before I break through the head into the water jacket?
Im still fighting with this snapped stud, tried to drill it out with $100 worth of stud extractors and reverse drill bits, but Im off center.
So im thinking of just using a helicoil? However I dont know how deep I can truely drill, and the FSM is undetailed.
Bigsyke is offline   Reply With Quote
Old 01-02-2009, 08:38 PM   #2
Zilvia Hesh!
burnsauto's Avatar
Just so everyone knows...what engine are we talking about?
Support Innovation.
WTB: ARC titanium spark plug cover for S13SR!!!!!!!
Old 01-02-2009, 08:50 PM   #3
if you couldn't drill it out with an extractor set you're doing something wrong.
fueled by hate is offline   Reply With Quote
Old 01-03-2009, 05:33 PM   #4
Bigsyke's Avatar
KA24DE, s14.
Yea I did something totally wrong, used the header stud hole as a guide, but missed horribly. Im using the square stud extractors from craftsman, the good kind. It just strips the hole I drilled, so I need to drill the whole stud out. However im affraid there is not enough aluminum surrounding the stud (stud closest to the distributor)
Old 01-03-2009, 06:27 PM   #5
Def
Doctor Chips
If you've got most of the stud drilled out, then I'd just helicoil what's there and chop off a little of the new exhaust stud if it bottoms out on the old stud.
I'm amazed you can't get it out though, it should have no tension on it now. I snapped a stud off on my SR and it was pretty simple to remove it.
Old 01-03-2009, 06:41 PM   #6
importdude's Avatar
Send a message via AIM to importdude
did u use a punch?
your spose to use a punch and indent the most center part
then start drilling so its guided in the middle
then hammer in extractor(square ) and visegrip turn
heat+soaking it in pbblaster helps
importdude is offline   Reply With Quote
Old 01-03-2009, 06:45 PM   #7
if you have a wire feed welder you can fill it in with weld and add a bolt at the end and it will bring out your stud. since the head its aluminum the weld wont stick to it. I learned the hard way i drilled all the way to the water jacket but on the new head i got i just did the welding thing and it worked.
Flaco S14 is offline   Reply With Quote
Old 01-03-2009, 07:07 PM   #8
Bigsyke's Avatar
Yea I used a punch, but the drill was angled.
Then tried drilling 2 holes, and using a screw driver. That just enlarged the aluminum opening and reuined the head.
I dont have a welder, but that shoiuldve been my 1st thing I did was fill it with weld, then weld on a nut.
Oh and I soaked the stud in both candle wax, and pb blaster 3x a day for 1 week, and it still wont budge.
I wonder if I have enough threads left. I could probably get it to a welder, have him weld a nut on and remove the excess stud, maybe a few mm left of threads. I ruined probably 80% of the threads in drilling.
Old 01-04-2009, 12:27 AM   #9
JRas's Avatar
Send a message via AIM to JRas
I drilled a hole through my air bleeder bolt that broke
used an easy out, ended up snapping it just by hand tightening it with a crecent wrench, no power tool...
couldn't get it out..
friend comes over with his mig places a nut on top of the bolt, welds on the inside of the nut... first one doesn't penetrate, second one does.. comes right out
moral of story, get someone with welding skills to do it, if you break an easy out you're FUCKED.
JRas is offline   Reply With Quote
Old 01-04-2009, 10:04 AM   #10
Bigsyke's Avatar
Yes, but on an exhaust stud about 5mm deep into the head, wont this warp the head?
Agree'd that it IS the best and possibly only way
Old 01-04-2009, 10:51 AM   #11
sillyvia13's Avatar
no it will not warp head.
I have had some happen to me. I gave up.. lol.
I will replace head cuz i am in love with my ka.
but yea bro. weld it up.
homedepot sells decent welders $500 You'll make your money back right away.
sillyvia13 is offline   Reply With Quote
Old 01-04-2009, 11:00 AM   #12
cc4usmc's Avatar
Send a message via AIM to cc4usmc Send a message via MSN to cc4usmc Send a message via Yahoo to cc4usmc
My dad trilled too far.. ended up taking the head to get the hole filled and redrilled. ended up working in my favor cause the head needed to be decked and they did that too.
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government" -Thomas Jefferson
cc4usmc is offline   Reply With Quote
Old 01-04-2009, 11:45 AM   #13
Bigsyke's Avatar
what about this welder?
welder at sears
Ive got a new head on the way, but thats more downtime.
Would I be able to weld this thing out with the engine still in the car?
SEO by vBSEO 3.3.0
