Old 12-19-2008, 03:57 PM   #1
How long do I have to wait for the gasket stuff to cure before I can put oil in the c
How long do I have to wait for the gasket stuff to cure before I can put oil in the car?
I replaced my dented oil pan.
I used the Super Black ATV.
Moon Ill is offline   Reply With Quote
Old 12-19-2008, 04:02 PM   #2
duffman1278's Avatar
Send a message via AIM to duffman1278
Should say on the instructions. If not I would give it like an hour. It should be fully cured by then but iirc its like 20min.
duffman1278 is offline   Reply With Quote
Old 12-19-2008, 04:18 PM   #3
The instruction say it cures in an hour, and fully dries in 24.
How long do I have to wait before driving on it?
Old 12-19-2008, 04:18 PM   #4
slider2828's Avatar
2-3 hours in winter I think pending where you live.... But depends how you applied it... You are supposed to apply wet wait like 2 minutes, then put the parts together with screws to hold in place finger tight, then wait 5 minutes, then torque to spec. Then wait like an hour before oiling.... Cure time depends on temp and right now in most places its freezing, or very cold so I would wait like 2-3 hours just in case... Its also very moist outside..... and in NC snowing probably? Wait awhile
Turn and Burn!
Old 12-19-2008, 04:28 PM   #5
F you SoCal and South Florida people with your comfortable winters :-P
No it's about 70 right now, it was misty this morning, pretty dry now.
I put the oil pan on about 3 hours ago, so hopefully I'm good. Though I did wait an hour before torquing.
Old 12-19-2008, 09:18 PM   #6
Def
Doctor Chips
3 hours is probably good. I waited a day on mine just to be sure, but it's never been my daily driver.
A trick I learned at work, slightly wetting RTV with water will cause the reaction to speed up and vulcanize faster.
Old 12-20-2008, 12:16 AM   #7
it doesn't say on the label?
wrxn240 is offline   Reply With Quote
Old 12-20-2008, 12:19 AM   #8
Def
Doctor Chips
Dry to the touch doesn't equal being ok to immerse in oil, so no, it doesn't tell you this on the label.
Old 12-20-2008, 05:54 AM   #9
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
i waited two days, still no leaks since august.
tre4s13 is offline   Reply With Quote
SEO by vBSEO 3.3.0
