| | #1 |
| Been in this since Jan. 2003 ![]() | 100 octane KA I like riding in drift cars t hat run on race gas. 100/103/110 whatever... Well, those guys all have SRs and high power stuff. I have a stock KA. Is it ok to run a high octane gasoline like that in my car? I mostly want to do it for the smell. I like the aroma that comes off these cars. So, any negatives to running a high octane gas like these? |
| Sponsored Links | |
| | #2 |
| Zilvia Junkie ![]() | I have a feeling you're joking... but I want to ask anyway, are you being serious or just playing?
__________________ Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings?? |
| | #4 |
| Been in this since Jan. 2003 ![]() | I'm pretty serious. I don't think I'd want to run LEADED, right? Unleaded only. I still have the cat in my car. I don't want to use this gas everyday, but just put some in when I go to the track... |
| | #7 |
| Zilvia FREAK! ![]() | 100 octane will run worse. are you going for the scented race gas smell ? Like lavender or bubble gum? Cuz if thats the case you can just buy the additive and put it in your normal gas. Technically the lower the octane you can go without detonation is the best. |
| | #8 |
| Been in this since Jan. 2003 ![]() | I see.... Ok, I guess I won't run 100+ then. I don't want to make my car run WORSE just for the good smell. Maybe I could just spill a little around the car or something... give it a hint of race gas smell... |
| | #9 |
| can't knock the hustle ![]() | It will run less efficiently and you will lose a bit of power. You don't want to run any more octane than what is absolutely necessary. Higher octane = higher resistance to combustion = burns less efficiently = less power. I don't think it will permanently damage your engine though.
__________________ Disrespecting $20k + sports cars since 2007 -1989 nissan 240sx: uber track whore -1994 infiniti Q45t: daily baller NEED A MECHANIC IN SO-CAL? LOOK HERE: http://zilvia.net/f/south-western-st...-mechanic.html |
| | #10 |
| AFC #1 ![]() | You will be fine running any Unleaded Race Gas in your car. Leaded will kill your O2 sensor, Cat and leave deposits all over the spark plugs and the back of your valves. Negatives is that it burns slower then lower grades. May not get complete combustion and lower your MPG. If you run colder plugs then stock check them after the first time. May need a hotter set for race gas. These are all minor things.
__________________ Comments should be taken as Opinions not as Statements of Fact. |
| | #12 |
| Been in this since Jan. 2003 ![]() | Yeah, looks like I won't be using it. I have no desire to change things around. Putting gas into the gas tank is the most amount of work I want to do. And, seeing as I have a stock engine, I don't want to LOSE ANY power. Thanks guys. |
| | #14 | |
| Nissanaholic! ![]() | Quote:
advance timing all the way ????? profit | |
| | #15 |
| Been in this since Jan. 2003 ![]() | Lol lol Advance timing? I have no idea how to do that. |
| Sponsored Links | |
| | #17 |
| Premium Member ![]() | if you want a cool smell you could always run something like this Manhattan Oil 19769-32 - Manhattan Oil Fuel Fragrances - summitracing.com comes in grape and cherry ![]() 13 bucks will do 2 tanks of gas. and this shit is strong. we run it in our pressure washer...lol |
| | #18 | |
| AFC #1 ![]() | Quote:
__________________ Comments should be taken as Opinions not as Statements of Fact. | |
| | #21 |
| Wrinkle Red = Vtak ![]() | |
| | #22 |
| Post Whore! ![]() | Ya, the times I've ran 103 I just mix it, 3-4 gallons per tank, bump the timing a degree and go. Doesn't feel any faster but it smells nice.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #23 |
| Premium Member ![]() | There is permanent damage because at high end you will not have complete burn. Overtime that will cause some damage to the pistons and rings as it will seep through your rings into your oil and that destroys the lubrication properties of oil.....
__________________ |
| | #24 | |
It will just burn slower then a lower octane. As long as the AFR is good he will get a complete burn. It will just be later then normal. You won't get as much power. Why it was suggested he advance his timing.
| | #26 |
| BANNED ![]() | SOUNDS LIKE A PLAN!!!!! BRAIN I AM SEND A FUCKING ECU! to you... gimmie your address NOW! If you like it send me your ecu and $50! You gotta see the power from these... pm me well talk... you need more than that na ka oem ecu can do... hit me |
| | #27 | |
| In time-out for misbehaving. ![]() | Quote:
if i put 93 octane in my stock ka i'm actually losing power.. so putting 87 in my tank is actually better some one hit me with some knowledge | |
| | #28 |
| Doctor Chips ![]() | This thread is full of fail. Combustion rate is NOT directly related to octane rating of a fuel. There is some race gas that has a faster combustion rate than normal pump gas, and some that has a slower combustion rate of the gas. VP Import stuff in particular touts its higher combustion rate to enable a small increase in power at very high RPM(<8000 RPM). |
| | #29 | ||
| can't knock the hustle ![]() | Quote:
__________________ Disrespecting $20k + sports cars since 2007 -1989 nissan 240sx: uber track whore -1994 infiniti Q45t: daily baller NEED A MECHANIC IN SO-CAL? LOOK HERE: http://zilvia.net/f/south-western-st...-mechanic.html | ||
| | #30 | |
| Doctor Chips ![]() | Quote:
Tuning cars on different fuels, and learning a few things about combustion engineer makes this readily apparent. | |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
