Old 12-19-2008, 01:29 AM   #1
In time-out for misbehaving.
420sx's Avatar
ls1 wiring s14 ignition
ok this is frustrating, im way tired but i have to know before tomorrow.
i got 2 wires to splice into stock s14 ignition under the column.
the wires can't be right from FSM since my friends ls1 s14 thats in my shop too has wires differently than what FSM suggests.
i got 2 wires to hook up.
1) Starter wire. by fsm starter wire is BLACK/yellow. he hooked his up to black/white.
2) Switched 12v. im assuming i have to hook up to white/blue which is ACC since its ON when key is turned and on when car runs.
his is hooked up to red/black i think. i wired those wires in for pcm/inejector/fuel rail.
any input peeps?
Old 12-19-2008, 01:53 AM   #2
you want the wire that is on whenever the key is in "on" or "run" position, as true ACC power is accessory, which de-energizes while cranking, the re-energizes as the key is sprung back to "on". you want "IGN" power, the one that stays on in the "on" position and also stays energized while cranking.
starter wire will only engage when key is to start position, and will no energize at any other time. grab a multimeter. have fun!
theslows13 is offline   Reply With Quote
Old 12-19-2008, 02:07 AM   #3
420sx's Avatar
that explains why his is hooked to black/red. hmmm
black and white is also a 12v switched thats on with the key on run and on with the car running. so that solves that.
now the starter wire has to be wrong because his is untaped and it runs. FSM got to be wrong on the color
Old 12-19-2008, 02:32 AM   #4
silviav8.com
all the info you need is there..
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 12-19-2008, 03:10 AM   #5
420sx's Avatar
yea i know but nothing useful there as far as this question
SEO by vBSEO 3.3.0
