Old 12-18-2008, 11:10 AM   #1
S14 Cruise Control with Aftermarket Steering Wheel
I found this on a S13 cause i accidently typed in s13 in the google search bar.
S13 Cruise Control w/ Aftermarket Steering Wheel
Well read it and all that, then swapped over to S14 and came up with zero. Also no one answered the question about S14.
Curious how would i do this on my 98 240sx
BoostGetsULaid is offline   Reply With Quote
Old 12-18-2008, 11:21 AM   #2
i would assume it would be the same procedure, all they did was remove the switch from the steering wheel and mount it somewhere else.
find the wiring for the CC switch(s) and run them to the re-located switch
done n done
So its true, asian women are tighter than usdm women!
japslapsilvia is offline   Reply With Quote
Old 12-18-2008, 11:29 AM   #3
[JEFE S14]
GSXRJJordan's Avatar
Send a message via AIM to GSXRJJordan Send a message via MSN to GSXRJJordan
It's the same! You can use the stock buttons, or you can wire up your own with momentary switches:
From here - good writeup.
TEAM SUS*PECT is alive.
www.JordanInnovations.com
Old 12-18-2008, 12:38 PM   #4
projectRDM's Avatar
I put the OE switch on the side of the column cover. You can also use an S13 switch and mount it virtually anywhere.
FORMERLY R240NA
SEO by vBSEO 3.3.0
