| | #1 |
| Zilvia Member ![]() | S13 driveshaft noise after clutch replacement help! I have a 92 with KA24DE. I just replaced my clutch, flywheel, pilot bearing and throwout bearing. The clutch kit is a 4 puck with chromoly lighten flywheel. After the install I started getting a humming/light vibration noise from the driveshaft but only on Deceleration and between 2k-3k rpm in all gears except reverse. I never had this problem before the install so Im thinking I didnt align the driveshaft on back right? So I rechecked it loosened it and realigned the bracket that holds the driveshaft up... Still the same noise. No fluids came out on the install so I didnt put any new fluids in. I searched the site for this problem but couldnt find one like mine.. most are noises in trans on accleration or in driveshaft. I read some on Deceleration noise but not within the 2-3krpm like mine Anyone have any idea? |
| Sponsored Links | |
| | #2 |
| Premium Member ![]() | I read something a long time that "Def" posted. I can't remember exactly what it was, so I'll probably fuck it up. But I think it had to do with a harmonic vibrations because of the springs (or lack of) on the clutch disk. Maybe you'll get lucky and he'll post. I have that vibration too, and it doesn't bother me. So I didn't do anything about it. If it's an easy fix though, maybe I'd fix it. |
| | #3 |
| Zilvia Member ![]() | the clutch disc is has springs on both sides of the disc.. kind of like a dual spring but not within each other. I dont remember if it was sprung or unsprung. Everything functions correctly it only makes that noise on decel at 2-3k rpms. Doesnt bother me much either I just dont know if its bad for the drivetrain or my clutch. |
| | #4 |
| Zilvia Junkie ![]() | well mine does the same thing, but thats cause the joint in the driveshaft is about toast and kinda shakes in the bushing.
__________________ No... no one stole my interior... its safely in my garage... |
| | #5 | |
| Premium Member ![]() | Quote:
| | #6 |
| Zilvia Member ![]() | I might removed my trans next weekend and check out the clutch. I notice today that when it makes the noise and i lightly push on the clutch pedal I can feel the vibration.. so I could have a problem with my pressure plate or the pitch fork. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
