Old 09-18-2008, 07:18 PM   #1
jkjunior's Avatar
Send a message via AIM to jkjunior
S14 Cluster Temp Gauge Reads OVERHEATING But Sr20det is perfect Temp HELP!
Ok guys heres what im dealing with. S13 Sr20det swap into 95 S14 Chassis. Harness done by Wiring Specalites etc etc. Just completed swap, Runs like a champ. I noticed when i went into the cabin for a test drive, My s14 gauge cluster was basically reading the car would be overheating. So we used a infared gun and started testing the temps around the motor and all were in perfect operating temperature. So we decided lets swap coolant temp sensors, So we did and bang the same thing, temp rises on the cluster, but the motor is in perfect temp. My question is do i need a ka temp sensor instead of the jdm sr20det sensor? Or is it more problems than that? Any help guys please!
91 Hatch- Old Lady Hit Me -Junk Yard
91 Coupe Se- Junk yard
95 S14 Zenki Current
95 Zenki Converted to Kouki Current
97 S14 Kouki - Junk Yard
Feedback - http://www.zilvia.net/f/showthread.php?t=130589
jkjunior is offline   Reply With Quote
Old 09-18-2008, 08:44 PM   #2
I have a built ka in my 97 and my temp randomly goes up like that too. A friend of mine has a s14 sr in his 98 and it does the same thing...I would just ignore it or get an aftermarket temp. gauge.
turbo98 is offline   Reply With Quote
Old 09-18-2008, 08:53 PM   #3
jkjunior's Avatar
It just stays pinned at high temp after start up. Anymore thoughts guys?
Old 09-18-2008, 09:11 PM   #4
I had a s13 sr in my s14. It did the same thing when I started the car within a min. it would read that the car was over heating. The way I fixed it was I got the temp sensor from a s14 KA and it fixed it.
muerte is offline   Reply With Quote
Old 09-18-2008, 09:13 PM   #5
ho1ywars's Avatar
yeah, im not sure if its cause of the jdm sensor, or cause is an s13 sensor in the motor. but it you go to your local automotive store just grab a s14 ka sensor, and it will fix your problem. sensor is down by your thermostat.
ho1ywars is offline   Reply With Quote
Old 09-19-2008, 03:11 AM   #6
illvialuver's Avatar
not bad, youve been on here almost 4 years and you have 14 post? and I know you are on here eveeeeeeeeeerrrrrrrrryyyyyyyyyyyy day!!!!!
Old 09-19-2008, 11:57 AM   #7
TTrx7Pete's Avatar
Wiring is wrong.... Double check the wiring.. I know it sounds like a pain in the ass, but if it is shooting up to "H" when you key on or are running the car, the wiring is incorrect. Trust me. I had the same problem while doing a swap.
1993 AW Mazda RX-7
1997 Nissan Silvia
TTrx7Pete is offline   Reply With Quote
Old 09-19-2008, 12:05 PM   #8
Send a message via AIM to adictd2b00st
You have to match the cluster with the sensor.......so if you have an s14 you need the s14 sensor
95 s14.5 FOR SALE
adictd2b00st is offline   Reply With Quote
Old 09-19-2008, 01:13 PM   #9
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Yups water temp sensor. S13 water temp sensor in the S13 SR sends a different reading compared to an S14 sensor. Swap the smaller water temp sensor and it should be good to go.
Old 09-19-2008, 02:05 PM   #10
Need KA water temp sensor.
tukn9s is offline   Reply With Quote
Old 09-19-2008, 02:59 PM   #11
kuruptR's Avatar
Send a message via MSN to kuruptR
+1 always match the sensor with cluster.
kuruptR is offline   Reply With Quote
Old 09-19-2008, 09:08 PM   #12
TTrx7Pete's Avatar
Not true. He just needs the S14 sensor for S14. Cluster is no difference.
1993 AW Mazda RX-7
1997 Nissan Silvia
Old 09-19-2008, 10:01 PM   #13
YucA's Avatar
Send a message via AIM to YucA
While everyone is correct, i wouldnt even waste my time with the oem crap.
Get an aftermarket gauge that will save your ass if anything were to happen, instead of relying on the oem POS gauge. Once it actually starts moving up if you have an issue, its usually too late.
YucA is offline   Reply With Quote
Old 09-20-2008, 07:53 PM   #14
Send a message via AIM to srpowereds14
yes you need the s14 ka sensor
Vertex-USA | Speed Alliance | Memory Fab | Preferred Auto Body | One Ton Garage
srpowereds14 is offline   Reply With Quote
Old 09-20-2008, 09:16 PM   #15
g6civcx's Avatar
Or ignore the sensor and run a full wideband coolant temp gauge.
Old 09-20-2008, 10:43 PM   #16
You need your stock KA temp sensor like everybody says. But I would get a aftermarket one.
chituntang is offline   Reply With Quote
Old 04-19-2009, 07:38 PM   #17
did you ever figure this out? i have same problem..
iammikeol is offline   Reply With Quote
Old 05-27-2009, 12:26 AM   #18
In time-out for misbehaving.
whats the solution to this?? did u change ur water pump by chance???
kushlivin is offline   Reply With Quote
Old 05-27-2009, 12:30 AM   #19
AFC #1
S14DB's Avatar
You run the water temp sender(single wire) that matches your cluster (S14 or S13).
Comments should be taken as Opinions not as Statements of Fact.
Old 05-27-2009, 03:54 AM   #20
Violent Running Asshole
Om1kron's Avatar
Send a message via AIM to Om1kron
i'm jealous, my car doesn't even read the temp. =(
Wayne T. Edwards
Violent Running Tribe News Blog <---Peep This
Old 05-27-2009, 12:02 PM   #21
u need a s14 KA temp sensor. i just recently swapped mine out cause i was having the same problem like you. it works.
midnight_rex is offline   Reply With Quote
Old 05-27-2009, 12:04 PM   #22
Om1kron's Avatar
I put an s14ka temp sensor in mine, but I guess it's bad LOL! womp womp womp. I gave away my other intake manifold so nothing to fall back on there.... Gotta pony up and buy new ones.
Wayne T. Edwards
SEO by vBSEO 3.3.0
