| | #31 |
| Zilvia Member ![]() Join Date: Sep 2005 Location: Binghamton, NY Age: 32
Trader Rating: (0) Feedback Score: 0 reviews | Ok. So I saw everything that he removed. But he also had his motor out for all that. I, unfortunately, don't have that luxury. I'm just looking to cap the egr (correctly) and get the car running with the rest of the emissions intact I guess. At some point however, I wouldn't mind pulling off the intake manifold and cleaning it all up. Maybe sometime over winter. But until then, I just want to drive my car. That's why I'm trying to get the rest of this worked out. But it just seems that I'm not as proficient as a lot of you. That's why I'm asking for help. Unfortunately, again, I don't have anyone or any shops local that can help me troubleshoot and answer the questions that I have.*mike* |
| | #33 | |
Trader Rating: (0) Feedback Score: 0 reviews | Quote:
Can you tell me what the hose next to the radiator goes to and what I should do with it? ![]() *mike* | |
| | #34 |
| Post Whore! ![]() Join Date: Dec 2002 Location: Atlanta Age: 39
Trader Rating: (12) Feedback Score: 12 reviews | Secondary resonator for the intake, mounts to the shroud. You can leave it or remove it, it's screwed to the shroud at either end.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com |
| | #35 | |
Trader Rating: (12) Feedback Score: 12 reviews | Quote:
If the smell is strong you should be able to tell where it's coming from, down by the frame rail.
__________________ FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com | |
| | #36 | |
*mike* | |
| | #37 | |
*mike* | |
| | #38 | |
| Post Whore! ![]() Join Date: Sep 2004 Location: above your level Age: 32
Trader Rating: (15) Feedback Score: 15 reviews | Quote:
This is why my car reeks of gas, because I've been researching every possibility before putting it up on jacks and tearing it apart. Which pretty much is going to be my next move after I take it to a nissan dealer to look at.
__________________ People with a shittier car than me trying to give me their thoughts and opinions on my car is like a broke motherfucker giving me financial advice. - GFY... - the hnl | |
| | #39 | |
I REALLY appreciate everyone's help, ideas, and suggestions, but please understand that everyday that I get out of work, I go home and work on the car until it's too dark out. Then I come into work the next day and try to get more suggestions to try when I get home. So far I have checked the plugs, the injectors, the fuel rail for leaks, the MAF, the timing, the ecu for visual signs that the chip for the tune came loose, my fuel filter, etc. Tonight I'm going to check all the vacuum lines that I had plugged and make sure they're plugged correctly. I also have to UNplug the line that goes to the firewall from where the canister was. I just like to get as many possibilities through out the day so I have something to work on when I get home. I've just run out of my own ideas. PS...I truly apologize if I've frustrated you. I didn't mean to. I'm greatful for everyone's help. *mike* | |
| | #40 |
Trader Rating: (15) Feedback Score: 15 reviews | no problem man, good luck.
| | #41 |
| Zilvia Member ![]() | well i have EGR valve code 32 and 34 cant figure it out i press up against my egr valve and engine stumbles until it dies... sometimes it dies somtimes it doesnt... how do u know if the egr is good or bad or if its the solenoid... i serached around everyone has some what of a diferent problem. when i floor my caron freeway i smell ehaust fumes or some fumes in my car.... duno what it is anyone elese have this issue? also i tried serahcing how to remove EGR valve.. man im gona have to do a write up myself .. ,, ahhahaah once i figure it out
__________________ |
| | #43 |
Trader Rating: (0) Feedback Score: 0 reviews | Ok...I've seen/used that diagram. The 4 lines going across the front have all been capped. Good...bad? The egr pipe (which this does not show) is also being capped (it isn't yet as I'm waiting for the cap from JGS, it'll be here Tuesday). And the charcoal canister and that square black box thing (I don't know what it is) next to the canister have also been removed. Is that all correct? *mike* |
| | #44 | |
| Leaky Injector Join Date: Feb 2006 Location: santa clarita Age: 26
if you disconnected the canister, plug the purge and vacuum lines going to it. the hose that goes from the tank to the canister needs to be vented, or your tank may build up enough pressure to either burst or crack. im assuming the black box thing is the resonator for the stock intake. hopefully this next pic helps. | |
| | #45 |
Trader Rating: (0) Feedback Score: 0 reviews | ^ That black box thing is the box the PAIR solenoid valve and PAIR valve are hooked to. It's directly in front of the BMC and to the left of the power steering resevoir. I yanked that right the fuck out too. What's the deal with that? *mike* |
| Sponsored Links | |
| | #46 | |
SYSTEM PURPOSE The Pulsed Secondary Air Injection (PAIR) System is designed to send secondary air to the exhaust manifold to promote afterburning of the exhaust gases, reducing CO and HC. The exhaust pressure in the manifold pulsates in response to the opening and closing of the exhaust valves and decreases periodically below atmospheric pressure creating a vacuum effect. Pulsed Secondary Air Injection (PAIR/AIV) Input/Output Signals CIRCUIT OPERATION When the ECM senses the proper conditions suitable for PAIR operation, via the water temperature sensor, idle switch and crank angle sensor it supplies the ground circuit to the PAIRC solenoid allowing the system to operate. Fig. 6 AIV/PAIR Valve The vacuum being transmitted to the PAIR Valve acts upon a diaphragm opening the valve port allowing the system to operate. The exhaust flow then draws filtered air into the the manifold through the piping and PAIR Valve promoting afterburning of the unburned exhaust gasses. A set of reed valves are mounted in the PAIR Valve to prevent exhaust gas from being sent back into the unit when the exhaust pressure exceeds atmospheric pressure. Vacuum Control Solenoid PULSED SECONDARY AIR INJECTION (PAIRC) CONTROL SOLENOID The ECM supplies the ground circuit to the PAIRC solenoid. When activated, it redirects vacuum from the source and vent ports to the source and valve ports, applying vacuum to the PAIR. PAIR/AIV Solenoid Operation PAIR OPERATION CHART | |
| | #48 | |
| | #49 | |
What would happen if you tried driving with that egr pipe not attached to the exhausts manifold? *mike* | |
| | #50 |
Trader Rating: (0) Feedback Score: 0 reviews | not really. its just emissions garbage. just make sure the hole in the exhaust that the fresh air supposed to be getting sucked into is blocked, or its gonna give the 02 sensor a false lean, which in turn adds more fuel when you dont need it, and makes you run rich. |
| | #51 |
Trader Rating: (0) Feedback Score: 0 reviews | Where did it connect to the exhaust? I don't remember. Was it the exhaust manifold? If so, that's long gone too. Swapped it out for a turbo manifold. Where would I have to block off? Thanks so much man. I think you're seriously answering all my questions. *mike* |
| | #52 | |
| | #55 | |
| | #56 | |
| | #57 | |
*mike* | |
| | #58 | |
*mike* | |
| | #59 | |
| | #60 |
Trader Rating: (0) Feedback Score: 0 reviews | Correct. So I ordered this cap to remedy that. JGS Precision Turbo (click on 240sx products, it's almost at the bottom of the page) Would not having it attached to the intake manifold cause the stumbling and dying at idle you were talking about? *mike* |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
