Old 07-20-2008, 11:49 AM   #1
s13 sr20. has fuel spark and cranks. but wont start.
i just put a new turbo in it. it started right up but the rear coolant pipe for the turbo leaked. drove it for a second then parked it due to smoking. the dipstick popped off and blew oil out the dipstick onto the headers. took the headers off fixed the pipe and rechecked oil level...its good. now it wont do much more than crank. sounds like its trying but wont start. any ideads??? like i said it has fuel spark and cranks. cam sensor? crank sensor? ingnitor chip? ecu? compression/headgasket? those are the option i have figured cud be causing it but idk what wud be the most logical starting point.
clv5045 is offline   Reply With Quote
Old 07-20-2008, 11:03 PM   #2
songs like the spark plugs are fouled out. try new plugs and see what it does
slideordie_240sx is offline   Reply With Quote
Old 07-21-2008, 02:46 PM   #3
adjusted timing for cas because it was oof about 30-50 degrees which made it sputter better but still not starting. i also tried new plugs too....they were a lil black. but still no luck... please any help guys. thanks in advance and thanks for the suggestion slideordie
91 240 cpe w/ sr SOLD
96 240 w/ sr
Old 07-21-2008, 04:45 PM   #4
i am going to go ahead and say that its my compression - head gasket/rings - since my compression test came up with 90-55-25-25 from #1-4. f*in a. i hope i dont have to put new rings in this ho ive had it for 3 months and driven it 3 hrs total. wat a headache this project is being. i'm begining to lose hope.....120hrs into it already
96 240 w/ sr
Old 07-21-2008, 04:55 PM   #5
does the motor have to be running in order to get an accurate reading for compression???
96 240 w/ sr
Old 07-21-2008, 04:59 PM   #6
corriganjoshua's Avatar
Send a message via MSN to corriganjoshua
Negative sir
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 07-21-2008, 05:53 PM   #7
KiLLeR2001's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
With compression numbers like that sounds to me like your cams aren't mechanically timed correctly. I had bizarre compression numbers like that when I was building my swap and I readjusted the cams following the FSM and I got like 150psi across all four, and then she started up fine.
KiLLeR2001 is online now   Reply With Quote
Old 07-26-2008, 09:21 AM   #8
thanx guys, yeah i asked a local mechanic yesterday and he said the same thing...so thats what im about to do. thanx again.
96 240 w/ sr
SEO by vBSEO 3.6.0 PL2
