Old 07-18-2008, 12:00 PM   #1
KA Unstable and random idle
s13 ka24de
Some reason I just CAN NOT get my car to idle properly. Its eratic and random! I can't figure out what the hell it is..
What I've tried to fix it:
Searched high & low for vacum leaks
Replaced TPS, calibrated correctly
Replaced lower collector w/ IACV off a running motor
MAFS is new
Checked grounds and fuses, all ok..
Yeah, so I'm out of ideas. Anyone else have some?
(Emissions removed) New rebuilt motor
Saviorsoul is offline   Reply With Quote
Old 07-18-2008, 12:06 PM   #2
Hates you & your build thread
Phlip's Avatar
I don't see anything suggesting that you've checked ignition (plugs/wires, coilm, etc.) or injectors... Have you?
Originally Posted by Ignignokt
"Getting it is easy... filling it with illegal substances and sending it across the border is not."
callmephlip.blogspot.com/
"Ask PHLIP a question, ask me anything"
Old 07-18-2008, 12:09 PM   #3
Banned from the Marketplace
could be exhaust leak thats what happend when i got mine
jyb116 is offline   Reply With Quote
Old 07-18-2008, 12:14 PM   #4
plugs new (took out and cleaned as well)
Checked wires (If I take them out they all produce a substancial loss in engine speed)
MSD Coil2 (new)
Injectors new as well O-rings installed correctly.
Old 07-18-2008, 12:16 PM   #5
... I have a penny sized exhause leak, but I can't see how that could cauase my idle to be eratic.. I'm trying to find pair of Hotshot 4-2-1 ceramic coated headers to fix my exhaust leak, and get better performance at once... (fuckn shity pacesetters)
Old 07-18-2008, 07:48 PM   #6
tryin running some seafoam, it help alot estabilizing my idle.
Also check ur ignition timing
osal is offline   Reply With Quote
Old 07-18-2008, 08:12 PM   #7
Try the EGR and try to run engine codes.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 07-18-2008, 08:15 PM   #8
I hate your "missile"
racepar1's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
I did a write-up on this, search for it!
"He's one of those "drift" guys, that's like ballroom dancing to me." -Paul Tracy
Need a mechanic in so-cal? PM me!
Old 07-19-2008, 11:46 PM   #9
Its a new motor, doesn't need seafoam, BUT I did it anyway. No help
Old 07-19-2008, 11:47 PM   #10
I don't have emissions. An I don't have a check engine light either.
Old 07-20-2008, 09:24 AM   #11
wow i didnt know an exhaust leak would actually cause this problem
blownoffvalve is offline   Reply With Quote
Old 07-20-2008, 12:26 PM   #12
racepar1's Avatar
Trader Rating: (79)
Like I told you SEARCH for my write-up! Stop being an idiot and listen! I'm not going to hold your damn hand, but I will point you in the right direction!
Old 07-20-2008, 12:51 PM   #13
Bigsyke's Avatar
Exhaust leak the size of a penny? Yea.......not good, And emissions are directly inline with your vac system, even when capped off. Isnt the Evac constantly purging?
Clean out the IACV, check the alternator load.
Bigsyke is offline   Reply With Quote
Old 07-20-2008, 01:05 PM   #14
pink godzila's Avatar
Trader Rating: (214)
Feedback Score: 214 reviews
Might wanna try to clean the Intake Manifold and replace a new Knock sensor.
Due to the old KA there will be alot of carbon stick inside the manifold so it could cause engine performace and idling problem. Also it could casue the EGR not working properly so try to clean the Manifold.
pink godzila is offline   Reply With Quote
Old 07-20-2008, 02:39 PM   #15
racepar1's Avatar
Trader Rating: (79)
I give up!
Irregular idle fix KADE
Old 07-20-2008, 02:41 PM   #16
phi_ho1's Avatar
Trader Rating: (56)
Feedback Score: 56 reviews
Send a message via Yahoo to phi_ho1
best is to check the MAF. 75 percent is will be it.
phi_ho1 is offline   Reply With Quote
Old 07-20-2008, 02:49 PM   #17
racepar1's Avatar
Trader Rating: (79)
WRONG! MAF's rarely go bad, especially on nissans. Is anybody going to read the damn thread that I wrote? I mean what the hell! People were bugging the hell out of me to write it, and nobody wants to read the damn thing!
Old 07-20-2008, 04:59 PM   #18
I read it,good job! Going to do it to as I have Idle problems with my s14sr
Mine runs fine for a few min. then stumbles then idles good again randomly
red240 is offline   Reply With Quote
Old 07-22-2008, 09:52 AM   #19
lol just listening to their ideas. I found your write up. I just haven't had enough free time when its not 103 degrees F in the shade out here. I'm going to try it, it makes sense and if its helped two of your friends I'll damn well try it.
Old 07-22-2008, 09:54 AM   #20
.90 percent of the time IF the MAFS goes out you encounter a 2300RPM (rev limiter) Your car pretty much won't allow you to rev past 2300. I don't know if its a saftey protocol, or just from it being fucked up, but I've encountered it on two 240s. My MAF did go bad, but I replaced it and its fine now. I can use my full rev band. Thanks for the idea though.
Old 07-22-2008, 10:01 AM   #21
Read my origonal post. Its a rebuilt motor. My intake was sandblasted. There is NO carbon build up and my knock sensor is fine, plus all the sensor does it retard your timing if it senses a knock, and when it goes bad it almost always throws a code. (Plus its new, OEM from Nissan)
Old 07-22-2008, 10:03 AM   #22
I don't live in So Cal. I have no emissions.
Old 08-01-2008, 11:31 PM   #23
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
No, actually we blew up the MAF.
And goddamnit Eric don't fucking post a million times. Ctrl+C is your friend when trying to quote multiple posts.
My idle is a bit erratic myself lol. But I've got more on my plate after that fiasco last night.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
