| | #1 |
| Zilvia Junkie ![]() Join Date: Dec 2007 Location: Washington Age: 24
Trader Rating: (1) Feedback Score: 1 reviews | thumping coming from under my car after lowering??? ok. So i recently lowered my S13 hatch with agx struts and Eibach sportline springs. now when i sit at an idle i hear/feel this loud thumping right beneath the center console. it also happens when i turn to the right. are my tranny mounts causing this? thankyou Deven |
| Sponsored Links | |
| | #2 |
| Zilvia Addict ![]() Join Date: Oct 2003 Location: Florida Age: 42
Trader Rating: (0) Feedback Score: 0 reviews | being it's center console, it could be. It could be a combination of motor mounts and tranny. I didn't notice my tranny mount bad until I did my suspension. Then every speedbump I could feel it in the stick shift.
__________________ Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
| | #6 |
| Post Whore! ![]() Join Date: Jun 2007 Location: Where ever there is free beer
Trader Rating: (0) Feedback Score: 0 reviews | Well, having a stiff subframe and stock tranny/ motor mounts, you could be having somewhat of a see-saw effect, with the tranny moving up and down, while the subframe is stationary. You'd be suprised how bad tranny and motor mounts can get in those old 240's.
__________________ BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
| | #9 |
Trader Rating: (0) Feedback Score: 0 reviews | If you drive hard I'd go Nismo, SPL, etc...I like my Nismo.
| | #12 |
| Premium Member ![]() Join Date: Sep 2006 Location: Hollywood Age: 36
Trader Rating: (7) Feedback Score: 7 reviews | I think Its your carrier bushing. Yes, you said you feel it at idle, but I would check it out too, since your gonna be down there. If it is, one piece driveshaft for an extra $100.00 more than the carrier bushing job will cost. Eitherway, you should jack it up and have a look, its easy enough. |
| | #14 |
| Nissanaholic! ![]() Join Date: Dec 2002 Location: Inland Empire, California Age: 34
Trader Rating: (8) Feedback Score: 8 reviews | Sounds like you got a mount problem. check your engine mount bolts to make sure nothing has come loose. Also to see if you need new mounts: check the engine mounts by grabbing the sides of the engine and try rocking it. Do this while to car is shut off! Does the engine rock alot? Pretty easily? Also can you mimic the thumping sound by doing this? For the tranny mount, if you've got no gap in the center between the two sections, get a new one. Nismo is the best IMO for daily driving and track use.
__________________ Don't mess with my monkey...he's loaded. |
| | #16 |
Trader Rating: (0) Feedback Score: 0 reviews | My sway bar touches the body sometimes on a hard turn.
| | #17 | |
Trader Rating: (8) Feedback Score: 8 reviews | Quote:
The main cause for the driveshaft to be thumping against something is due to a bad tranny mount allowing the tranny to sag, thus allowing the front drive shaft to sag. Even if the carrier bearing is bad, the carrier mounting brackets will not allow that part to sag while stationary. Unless the two bolts holding those brackets are loose. The rear drive shaft piece would sag due to bad subframe bushings. And if you've replaced those with upgraded bushings, you've raised the drivetrain UP. bringing it closer to the frame. Can create all kinds of rattles. Good luck.
__________________ Don't mess with my monkey...he's loaded. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
