| | #1 |
| Zilvia.net GB Vendor ![]() Join Date: Apr 2006 Location: Philly Burbs
Trader Rating: (52) Feedback Score: 52 reviews | z32 maste upgrade--need cylinder with fitting-Found now i have for sale-with fitting ok I am going to use the 17/16 master and want to know what brands to order that come with the flare middle fitting pre-installed this is need when putting the master cyl on a non-abs s13..i do not feel like cutting my stock s13 master apart and putting the fitting in my z32 one, or paying $240~ for a master cyl from other dist....i heard some part brands came with the fitting in them after u took out the hex middle plug...also i own a shop and can get aftermarket masters from like autozone type dist and others since we use them for parts. thanks Jim Last edited by JTunedMotorsports; 06-19-2008 at 05:56 AM.. |
| Sponsored Links | |
| | #4 |
| Post Whore! ![]() Join Date: Apr 2004 Location: Virginia, USA
Trader Rating: (5) Feedback Score: 5 reviews | http://www.zilvia.net/f/showthread.php?t=159124 Specify 17/16" and non-ABS when you order. Sidenote: I have braided lines, which means in a pinch I can use ABS BMCs if needed, with the appropriate fittings of course to distribute to front left/right calipers. |
| | #5 |
| Zilvia FREAK! ![]() | |
| | #7 |
Trader Rating: (52) Feedback Score: 52 reviews | JUST in..i just got off the phone with my parts dist and have a few that arrived to my shop...brand new....cheap and with fitting installed...if anyone needs any let me know $135.00 SHIPPED !!!! |
| | #13 |
| Zilvia Addict ![]() | ImportNut's website......it will answer all your questions about the Z32 swap. http://importnut.net/300zxbrakeswap.htm ID
__________________ Weekend Mechanic for my not so mechanically inclined buddies.... |
| | #15 | |
| Premium Member ![]() Join Date: Jun 2003 Location: north san diego county, ca Age: 31
Trader Rating: (95) Feedback Score: 95 reviews | Quote: | |
| Sponsored Links | |
| | #16 | ||
| Nissanaholic! ![]() Join Date: Feb 2007 Location: Socal Fontana Age: 34
Trader Rating: (37) Feedback Score: 37 reviews | Quote: Quote:
| | #20 |
Trader Rating: (37) Feedback Score: 37 reviews | I throw some more info in here to as far as the flare fitting goes, since it has been a while I dont recall which is larger but if using a NABCO BMC make sure to use NABCO flare fittings, same holds true for TOKICO, they are different and in one combination of mix-matching them you will see it will not press in snugly. Also if you are going to hack up a BMC check to make sure its teh correct make TOKICO vs NABCO and second make sure that it has the press fitting flare fittings aka removeable type......not all TOKICO and NABCO has these type flares some are build cast into the master meanings its not removeable. IMO best thing is to buy a BMC with the middle flare already installed saves time and headaches. |
| | #22 |
Trader Rating: (52) Feedback Score: 52 reviews | [ update: here are pics of 17/16 master cylinder http://good-times.webshots.com/album/563819567qtxeTw |
| | #23 | |
| Hates you & your build thread ![]() Join Date: Sep 2002 Location: In the white house at the top of the hill Age: 33
Trader Rating: (12) Feedback Score: 12 reviews | This has gone way commercial, please view this: http://www.zilvia.net/advertise.html
__________________ Quote:
![]() "Ask PHLIP a question, ask me anything" | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
