Old 06-11-2008, 11:23 PM   #1
its_teddd's Avatar
car dies out at start up.
when i start up my car it runs for a while (about 10 seconds) then slowly dies out. but after it warms up or after i gas it up like about 4k rpm it runs decently. one of my friends told me it was the iacv. any other suggestions? car is completely stock except for the koyo rad and exhaust but it was doing this before the exhaust. and i already cleaned the maf and everything. and the injectors and sparks plugs are fine. any help would be nice. thanks.
its_teddd is offline   Reply With Quote
Old 06-11-2008, 11:37 PM   #2
drftmark's Avatar
check the timing.
drftmark is offline   Reply With Quote
Old 06-11-2008, 11:39 PM   #3
Send a message via AIM to rightcoastimports
which engine are you running?? ka, sr??
:::95 Zenki:::
rightcoastimports is offline   Reply With Quote
Old 06-11-2008, 11:57 PM   #4
its_teddd's Avatar
sorry its a ka24de. besides the timing any other ideas? its been like this for a wile and i decided to post for help today.
Old 06-12-2008, 12:53 AM   #5
cronux's Avatar
go to advance, buy a can of seafoam, and run it through the iacv piping at idle, if that doesnt help, check timing.
cronux is offline   Reply With Quote
Old 06-12-2008, 01:06 AM   #6
SoguRacing's Avatar
Send a message via AIM to SoguRacing
honestly..i dont believe in seafoam. you should try to pull codes from you ecu if you can. it might be the timing but i'd lean more towards the fuel system. how does the car sound when it starts up? could be a fuel pressure problem.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 06-12-2008, 07:55 PM   #7
its_teddd's Avatar
it sounds fine but my dad says it seems a bit "shakey." its not the mounts that are making it shake, though for sure, because we changed them.
Old 06-12-2008, 08:05 PM   #8
SoguRacing's Avatar
vacuum leak? a big one
Old 06-14-2008, 03:06 PM   #9
jinesz32's Avatar
Send a message via AIM to jinesz32
rough idle, check the distributor, after i did the 5 speed swap on my car, after messing with the timing etc, the car didnt start when we tried, messed with the distributor and got it to start but i had to gas it to keep it alive, and eventually it died, mess with the distributor some more and what do you know, we got it to start.
now im turbo'ing my ka24de, the motor shakes a lot because of rough idle.
good luck!
jinesz32 is offline   Reply With Quote
Old 06-14-2008, 03:18 PM   #10
when my KA did this it was a vacuum leak after the MAF other than that check grounds
jorge1190 is online now   Reply With Quote
Old 06-15-2008, 01:41 PM   #11
fcdrifter20's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
pull codes and go from there
fcdrifter20 is offline   Reply With Quote
Old 06-15-2008, 01:46 PM   #12
clark's Avatar
i had a similar problem with my SR. i would start it, it would take more cranks than normal, then die immediately. on the second try it started right up. i had to pull the CAS (distributor in your case) and i guess i didn't line it up correctly, even though i followed a guide. i reset my ignition timing using a timing light and lead on cyl # 1 to a tad bit advanced, and now it runs fantastic and starts right up.
clark is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
